    328 Posts 27 Posters 716.6k Views 24 Watching
      @sdetweil said in new update/upgrade script, ready for testing:
      can u do a git status, and git remote -v
      It’s very likely that this was a manual installation of MM (in case that matters)
      pop@E8300:~$ cd MagicMirror/
      pop@E8300:~/MagicMirror$ git status
      fatal: not a git repository (or any of the parent directories): .git
      pop@E8300:~/MagicMirror$ git remote -v
      pop@E8300:~/MagicMirror$ ^C
        sdetweil @Mykle1
        @Mykle1 is it possible u might have downloaded the code as a zip file, instead of doing git clone?
        Only way I can think of to get into this state
          Yes Sam, that is what I meant by a manual installation. :-/
            sdetweil @Mykle1
            @Mykle1 cool. Thanks for the test. Updated script to handle
              I wish I would have waited for the updated script. I went ahead and installed a new MM because I couldn’t move forward with what I am doing. Again, thanks for your scripts. I will continue to use them. They’re awesome. :thumbsup:
                sdetweil @Mykle1
                @Mykle1 I think u did the right thing. The “handle” is to bail out gracefully if there is no git repo locally (zip file install doesn’t provide any path forward, that I have found)
                  Understood, thanks. :-)
                    Added some reporting of current version and version upgrading to.
                    Also had path that did a live merge when u were just testing. Fixed that
                      another update… i was reporting ALL the files that changed between versions, but who cares (things are SUPPOSED the change!)… we only care if there is a conflict… fixed that
                        potts-mike
                        I am getting the below errors when trying to run your installer script, thoughts?
                        bash: line 18: $‘\r’: command not found
                        bash: line 20: $‘\r’: command not found
                        bash: line 27: $‘\r’: command not found
                        bash: -c: line 28: syntax error near unexpected token $'{\r'' 'ash: -c: line 28: trim() {
                          sdetweil @potts-mike
                          @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
                            potts-mike
                            it ran with the following errors and magic mirror did not start.
                            install log being saved to /home/pi/MagicMirror/installers/install.log
                            Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                            Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                            Fetched 25.4 kB in 1s (22.4 kB/s)
                            Reading package lists... Done
                            Building dependency tree
                            build-essential is already the newest version (12.3).
                            curl is already the newest version (7.52.1-5+deb9u9).
                            git is already the newest version (1:2.11.0-3+deb9u4).
                            unzip is already the newest version (6.0-21+deb9u2).
                            wget is already the newest version (1.18-5+deb9u3).
                              coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15
                            Use 'sudo apt autoremove' to remove them.
                            (node:4945) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                            npm is already the newest version (1.4.21+ds-2).
                            (node:4979) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                            npm WARN package.json path-is-inside@1.0.2 No README data
                            npm WARN package.json sorted-object@2.0.1 No README data
                            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                            /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                            npm WARN package.json config-chain@1.1.12 No license field.
                            npm WARN package.json cyclist@0.2.2 No license field.
                            npm WARN package.json json-schema@0.2.3 No license field.
                            npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
                            npm WARN package.json qrcode-terminal@0.12.0 No license field.
                            npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
                            npm@6.11.3 /usr/local/lib/node_modules/npm
                              @potts-mike can u send me the install.log, /home/pi/MagicMirror/installers/install.log
                              same userid as here at gmail
                              or post it here
                                @potts-mike also, try again… fixed a messaging problem
                                but… you have MM already installed… (if the folder exists, cause the log is put there)…
                                so, you should be using the update-script to bring to next version…
                                  satsatt @sdetweil
                                  @sdetweil Can You help me please with this, running Your script gives me this
                                  doing test run = false
                                  saving custom.css
                                  upgrading from version 2.6.0 to 2.8.0
                                  fetching latest revisions
                                  error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                                  überschrieben werden:
                                  	package-lock.json
                                  	vendor/package-lock.json
                                  Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                                  Abbruch
                                  there were merge errors
                                  you should examine and resolve them
                                  using the command git log --oneline --decorate
                                  de57daa (grafted, HEAD ->
                                  how do i commit or stash?
                                    sdetweil @satsatt
                                    @satsatt can u post the contents of /home/pi/MagicMirror/installers/upgrade.log
                                    to stash, it is git stash
                                    but it should have prompted you to do that… so, please wait til I look thru the log
                                      satsatt @sdetweil
                                      @sdetweil ```
                                      Upgrade started - Sa Sep 14 09:01:30 CEST 2019
                                      doing test run = true
                                      downloading dumpactivemodules script
                                      saving custom.css
                                      remote name = origin
                                      current branch = master
                                      no files different from github version
                                      test merge result rc=‘’ if empty, no conflicts
                                      skipping merge, only test run
                                      processing for module MMM-SystemStats . please wait
                                      skipped processing for MMM-SystemStats, doing test run
                                      processing for module MMM-DWD-WarnWeather . please wait
                                      skipped processing for MMM-DWD-WarnWeather, doing test run
                                      restoring custom.css
                                      Upgrade ended - Sa Sep 14 09:01:33 CEST 2019
                                      Upgrade started - Sa Sep 14 09:02:16 CEST 2019
                                      user requested to apply changes
                                      saving custom.css
                                      executing merge, apply specified
                                      merge result rc= 1 Aktualisiere de57daa…a31546b
                                      Upgrade ended - Sa Sep 14 09:02:18 CEST 2019
                                      Upgrade started - Sa Sep 14 14:50:08 CEST 2019
                                      saving custom.css
                                        sdetweil @satsatt
                                        @satsatt great thanks…
                                        can u show me the results of
                                        git status
                                        thanks
                                          satsatt @sdetweil
                                          @sdetweil ```
                                          pi@raspberrypi:~/MagicMirror $ git status
                                          Auf Branch master
                                          Ihr Branch ist zu ‘origin/master’ um 2639 Commits hinterher, und kann vorgespult werden.
                                          (benutzen Sie “git pull”, um Ihren lokalen Branch zu aktualisieren)
                                          zum Commit vorgemerkte Änderungen:
                                          (benutzen Sie “git reset HEAD …” zum Entfernen aus der Staging-Area)
                                          geändert:       package-lock.json
                                          geändert:       vendor/package-lock.json
                                          Unversionierte Dateien:
                                          (benutzen Sie “git add …”, um die Änderungen zum Commit vorzumerken)
                                          installers/dumpactivemodules.js
                                            sdetweil @satsatt
                                            @satsatt english word search…
                                            can u show me output of
                                            locale
                                            • 16
                                            • 17
                                            • 2 / 17
