    328 Posts 27 Posters 740.6k Views 24 Watching
    • Mykle1M
      Understood, thanks. :-)
        Added some reporting of current version and version upgrading to.
        Also had path that did a live merge when u were just testing. Fixed that
          another update… i was reporting ALL the files that changed between versions, but who cares (things are SUPPOSED the change!)… we only care if there is a conflict… fixed that
            potts-mike
            I am getting the below errors when trying to run your installer script, thoughts?
            bash: line 18: $‘\r’: command not found
            bash: line 20: $‘\r’: command not found
            bash: line 27: $‘\r’: command not found
            bash: -c: line 28: syntax error near unexpected token $'{\r'' 'ash: -c: line 28: trim() {
              sdetweil @potts-mike
              @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
                potts-mike
                it ran with the following errors and magic mirror did not start.
                install log being saved to /home/pi/MagicMirror/installers/install.log
                Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                Fetched 25.4 kB in 1s (22.4 kB/s)
                Reading package lists... Done
                Building dependency tree
                build-essential is already the newest version (12.3).
                curl is already the newest version (7.52.1-5+deb9u9).
                git is already the newest version (1:2.11.0-3+deb9u4).
                unzip is already the newest version (6.0-21+deb9u2).
                wget is already the newest version (1.18-5+deb9u3).
                  coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15
                Use 'sudo apt autoremove' to remove them.
                (node:4945) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                npm is already the newest version (1.4.21+ds-2).
                (node:4979) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                npm WARN package.json path-is-inside@1.0.2 No README data
                npm WARN package.json sorted-object@2.0.1 No README data
                /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                npm WARN package.json config-chain@1.1.12 No license field.
                npm WARN package.json cyclist@0.2.2 No license field.
                npm WARN package.json json-schema@0.2.3 No license field.
                npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
                npm WARN package.json qrcode-terminal@0.12.0 No license field.
                npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
                npm@6.11.3 /usr/local/lib/node_modules/npm
                  @potts-mike can u send me the install.log, /home/pi/MagicMirror/installers/install.log
                  same userid as here at gmail
                  or post it here
                    @potts-mike also, try again… fixed a messaging problem
                    but… you have MM already installed… (if the folder exists, cause the log is put there)…
                    so, you should be using the update-script to bring to next version…
                      satsatt @sdetweil
                      @sdetweil Can You help me please with this, running Your script gives me this
                      doing test run = false
                      saving custom.css
                      upgrading from version 2.6.0 to 2.8.0
                      fetching latest revisions
                      error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                      überschrieben werden:
                      	package-lock.json
                      	vendor/package-lock.json
                      Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                      Abbruch
                      there were merge errors
                      you should examine and resolve them
                      using the command git log --oneline --decorate
                      de57daa (grafted, HEAD ->
                      how do i commit or stash?
                        sdetweil @satsatt
                        @satsatt can u post the contents of /home/pi/MagicMirror/installers/upgrade.log
                        to stash, it is git stash
                        but it should have prompted you to do that… so, please wait til I look thru the log
                          satsatt @sdetweil
                          @sdetweil ```
                          Upgrade started - Sa Sep 14 09:01:30 CEST 2019
                          doing test run = true
                          downloading dumpactivemodules script
                          saving custom.css
                          remote name = origin
                          current branch = master
                          no files different from github version
                          test merge result rc=‘’ if empty, no conflicts
                          skipping merge, only test run
                          processing for module MMM-SystemStats . please wait
                          skipped processing for MMM-SystemStats, doing test run
                          processing for module MMM-DWD-WarnWeather . please wait
                          skipped processing for MMM-DWD-WarnWeather, doing test run
                          restoring custom.css
                          Upgrade ended - Sa Sep 14 09:01:33 CEST 2019
                          Upgrade started - Sa Sep 14 09:02:16 CEST 2019
                          user requested to apply changes
                          saving custom.css
                          executing merge, apply specified
                          merge result rc= 1 Aktualisiere de57daa…a31546b
                          Upgrade ended - Sa Sep 14 09:02:18 CEST 2019
                          Upgrade started - Sa Sep 14 14:50:08 CEST 2019
                          saving custom.css
                            sdetweil @satsatt
                            @satsatt great thanks…
                            can u show me the results of
                            git status
                            thanks
                              satsatt @sdetweil
                              @sdetweil ```
                              pi@raspberrypi:~/MagicMirror $ git status
                              Auf Branch master
                              Ihr Branch ist zu ‘origin/master’ um 2639 Commits hinterher, und kann vorgespult werden.
                              (benutzen Sie “git pull”, um Ihren lokalen Branch zu aktualisieren)
                              zum Commit vorgemerkte Änderungen:
                              (benutzen Sie “git reset HEAD …” zum Entfernen aus der Staging-Area)
                              geändert:       package-lock.json
                              geändert:       vendor/package-lock.json
                              Unversionierte Dateien:
                              (benutzen Sie “git add …”, um die Änderungen zum Commit vorzumerken)
                              installers/dumpactivemodules.js
                                sdetweil @satsatt
                                @satsatt english word search…
                                can u show me output of
                                locale
                                  satsatt
                                  pi@raspberrypi:~/MagicMirror $ locale
                                  LANG=de_DE.UTF-8
                                  LANGUAGE=de_DE.UTF-8
                                  LC_CTYPE="de_DE.UTF-8"
                                  LC_NUMERIC="de_DE.UTF-8"
                                  LC_TIME="de_DE.UTF-8"
                                  LC_COLLATE="de_DE.UTF-8"
                                  LC_MONETARY="de_DE.UTF-8"
                                  LC_MESSAGES="de_DE.UTF-8"
                                  LC_PAPER="de_DE.UTF-8"
                                  LC_NAME="de_DE.UTF-8"
                                  LC_ADDRESS="de_DE.UTF-8"
                                  LC_TELEPHONE="de_DE.UTF-8"
                                  LC_MEASUREMENT="de_DE.UTF-8"
                                  LC_IDENTIFICATION="de_DE.UTF-8"
                                  LC_ALL=de_DE.UTF-8
                                    satsatt
                                    you want git status in english i suppose?
                                      sdetweil @satsatt
                                      @satsatt yes, working on that…
                                        satsatt
                                        I try
                                        "your branch is regarding to origin/master 2639 commits back and can brought forward
                                        use git pull to make your local branch actual
                                        registered changes for Commit
                                        ( use git reset for deleting from Staging-Area )
                                        changed: package-lock.json
                                        changed: vendor/package-lock.json
                                        files not in version:
                                        ( use git add for preparing files to commit )
                                          sdetweil @satsatt
                                          @satsatt ok, was gonna ask for this
                                          alias git='LANGUAGE=en_US.UTF-8 git"
                                          git status
                                          unalias git
                                            satsatt
                                            @sdetweil said in new update/upgrade script, ready for testing:
                                            unalias git
                                            uh not ok
                                            pi@raspberrypi:~/MagicMirror $ alias git='LANGUAGE=en_US.UTF-8 git"
                                            > git status
                                            > unalias git
                                            • 16
                                            • 17
                                            • 2 / 17
