    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @Mykle1
      @Mykle1 is it possible u might have downloaded the code as a zip file, instead of doing git clone?
      Only way I can think of to get into this state
      • Mykle1M
        Yes Sam, that is what I meant by a manual installation. :-/
          sdetweil @Mykle1
          @Mykle1 cool. Thanks for the test. Updated script to handle
          • Mykle1M
            @sdetweil said in new update/upgrade script, ready for testing:
            I wish I would have waited for the updated script. I went ahead and installed a new MM because I couldn’t move forward with what I am doing. Again, thanks for your scripts. I will continue to use them. They’re awesome. :thumbsup:
              sdetweil @Mykle1
              @Mykle1 I think u did the right thing. The “handle” is to bail out gracefully if there is no git repo locally (zip file install doesn’t provide any path forward, that I have found)
              • Mykle1M
                Understood, thanks. :-)
                  Added some reporting of current version and version upgrading to.
                  Also had path that did a live merge when u were just testing. Fixed that
                    another update… i was reporting ALL the files that changed between versions, but who cares (things are SUPPOSED the change!)… we only care if there is a conflict… fixed that
                      potts-mike
                      I am getting the below errors when trying to run your installer script, thoughts?
                      bash: line 18: $‘\r’: command not found
                      bash: line 20: $‘\r’: command not found
                      bash: line 27: $‘\r’: command not found
                      bash: -c: line 28: syntax error near unexpected token $'{\r'' 'ash: -c: line 28: trim() {
                        sdetweil @potts-mike
                        @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
                          potts-mike
                          it ran with the following errors and magic mirror did not start.
                          install log being saved to /home/pi/MagicMirror/installers/install.log
                          Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                          Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                          Fetched 25.4 kB in 1s (22.4 kB/s)
                          Reading package lists... Done
                          Building dependency tree
                          build-essential is already the newest version (12.3).
                          curl is already the newest version (7.52.1-5+deb9u9).
                          git is already the newest version (1:2.11.0-3+deb9u4).
                          unzip is already the newest version (6.0-21+deb9u2).
                          wget is already the newest version (1.18-5+deb9u3).
                            coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15
                          Use 'sudo apt autoremove' to remove them.
                          (node:4945) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                          npm is already the newest version (1.4.21+ds-2).
                          (node:4979) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                          npm WARN package.json path-is-inside@1.0.2 No README data
                          npm WARN package.json sorted-object@2.0.1 No README data
                          /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                          /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                          npm WARN package.json config-chain@1.1.12 No license field.
                          npm WARN package.json cyclist@0.2.2 No license field.
                          npm WARN package.json json-schema@0.2.3 No license field.
                          npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
                          npm WARN package.json qrcode-terminal@0.12.0 No license field.
                          npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
                          npm@6.11.3 /usr/local/lib/node_modules/npm
                            @potts-mike can u send me the install.log, /home/pi/MagicMirror/installers/install.log
                            same userid as here at gmail
                            or post it here
                              @potts-mike also, try again… fixed a messaging problem
                              but… you have MM already installed… (if the folder exists, cause the log is put there)…
                              so, you should be using the update-script to bring to next version…
                                satsatt @sdetweil
                                @sdetweil Can You help me please with this, running Your script gives me this
                                doing test run = false
                                saving custom.css
                                upgrading from version 2.6.0 to 2.8.0
                                fetching latest revisions
                                error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                                überschrieben werden:
                                	package-lock.json
                                	vendor/package-lock.json
                                Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                                Abbruch
                                there were merge errors
                                you should examine and resolve them
                                using the command git log --oneline --decorate
                                de57daa (grafted, HEAD ->
                                how do i commit or stash?
                                  sdetweil @satsatt
                                  @satsatt can u post the contents of /home/pi/MagicMirror/installers/upgrade.log
                                  to stash, it is git stash
                                  but it should have prompted you to do that… so, please wait til I look thru the log
                                    satsatt @sdetweil
                                    @sdetweil ```
                                    Upgrade started - Sa Sep 14 09:01:30 CEST 2019
                                    doing test run = true
                                    downloading dumpactivemodules script
                                    saving custom.css
                                    remote name = origin
                                    current branch = master
                                    no files different from github version
                                    test merge result rc=‘’ if empty, no conflicts
                                    skipping merge, only test run
                                    processing for module MMM-SystemStats . please wait
                                    skipped processing for MMM-SystemStats, doing test run
                                    processing for module MMM-DWD-WarnWeather . please wait
                                    skipped processing for MMM-DWD-WarnWeather, doing test run
                                    restoring custom.css
                                    Upgrade ended - Sa Sep 14 09:01:33 CEST 2019
                                    Upgrade started - Sa Sep 14 09:02:16 CEST 2019
                                    user requested to apply changes
                                    saving custom.css
                                    executing merge, apply specified
                                    merge result rc= 1 Aktualisiere de57daa…a31546b
                                    Upgrade ended - Sa Sep 14 09:02:18 CEST 2019
                                    Upgrade started - Sa Sep 14 14:50:08 CEST 2019
                                    saving custom.css
                                      sdetweil @satsatt
                                      @satsatt great thanks…
                                      can u show me the results of
                                      git status
                                      thanks
                                        satsatt @sdetweil
                                        @sdetweil ```
                                        pi@raspberrypi:~/MagicMirror $ git status
                                        Auf Branch master
                                        Ihr Branch ist zu ‘origin/master’ um 2639 Commits hinterher, und kann vorgespult werden.
                                        (benutzen Sie “git pull”, um Ihren lokalen Branch zu aktualisieren)
                                        zum Commit vorgemerkte Änderungen:
                                        (benutzen Sie “git reset HEAD …” zum Entfernen aus der Staging-Area)
                                        geändert:       package-lock.json
                                        geändert:       vendor/package-lock.json
                                        Unversionierte Dateien:
                                        (benutzen Sie “git add …”, um die Änderungen zum Commit vorzumerken)
                                        installers/dumpactivemodules.js
                                          sdetweil @satsatt
                                          @satsatt english word search…
                                          can u show me output of
                                          locale
                                            satsatt
                                            pi@raspberrypi:~/MagicMirror $ locale
                                            LANG=de_DE.UTF-8
                                            LANGUAGE=de_DE.UTF-8
                                            LC_CTYPE="de_DE.UTF-8"
                                            LC_NUMERIC="de_DE.UTF-8"
                                            LC_TIME="de_DE.UTF-8"
                                            LC_COLLATE="de_DE.UTF-8"
                                            LC_MONETARY="de_DE.UTF-8"
                                            LC_MESSAGES="de_DE.UTF-8"
                                            LC_PAPER="de_DE.UTF-8"
                                            LC_NAME="de_DE.UTF-8"
                                            LC_ADDRESS="de_DE.UTF-8"
                                            LC_TELEPHONE="de_DE.UTF-8"
                                            LC_MEASUREMENT="de_DE.UTF-8"
                                            LC_IDENTIFICATION="de_DE.UTF-8"
                                            LC_ALL=de_DE.UTF-8
                                            • 16
                                            • 17
                                            • 2 / 17
