    328 Posts 27 Posters 752.2k Views 24 Watching
    • Mykle1M
      Yes Sam, that is what I meant by a manual installation. :-/
        sdetweil @Mykle1
        @Mykle1 cool. Thanks for the test. Updated script to handle
        Mykle1M 1 Reply Last reply
        Reply Quote 2
        • Mykle1M
          @sdetweil said in new update/upgrade script, ready for testing:
          I wish I would have waited for the updated script. I went ahead and installed a new MM because I couldn’t move forward with what I am doing. Again, thanks for your scripts. I will continue to use them. They’re awesome. :thumbsup:
            sdetweil @Mykle1
            @Mykle1 I think u did the right thing. The “handle” is to bail out gracefully if there is no git repo locally (zip file install doesn’t provide any path forward, that I have found)
            • Mykle1M
              Understood, thanks. :-)
                Added some reporting of current version and version upgrading to.
                Also had path that did a live merge when u were just testing. Fixed that
                  another update… i was reporting ALL the files that changed between versions, but who cares (things are SUPPOSED the change!)… we only care if there is a conflict… fixed that
                    potts-mike
                    I am getting the below errors when trying to run your installer script, thoughts?
                    bash: line 18: $‘\r’: command not found
                    bash: line 20: $‘\r’: command not found
                    bash: line 27: $‘\r’: command not found
                    bash: -c: line 28: syntax error near unexpected token $'{\r'' 'ash: -c: line 28: trim() {
                      sdetweil @potts-mike
                      @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
                        potts-mike
                        it ran with the following errors and magic mirror did not start.
                        install log being saved to /home/pi/MagicMirror/installers/install.log
                        Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                        Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                        Fetched 25.4 kB in 1s (22.4 kB/s)
                        Reading package lists... Done
                        Building dependency tree
                        build-essential is already the newest version (12.3).
                        curl is already the newest version (7.52.1-5+deb9u9).
                        git is already the newest version (1:2.11.0-3+deb9u4).
                        unzip is already the newest version (6.0-21+deb9u2).
                        wget is already the newest version (1.18-5+deb9u3).
                          coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15
                        Use 'sudo apt autoremove' to remove them.
                        (node:4945) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                        npm is already the newest version (1.4.21+ds-2).
                        (node:4979) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                        npm WARN package.json path-is-inside@1.0.2 No README data
                        npm WARN package.json sorted-object@2.0.1 No README data
                        /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                        /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                        npm WARN package.json config-chain@1.1.12 No license field.
                        npm WARN package.json cyclist@0.2.2 No license field.
                        npm WARN package.json json-schema@0.2.3 No license field.
                        npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
                        npm WARN package.json qrcode-terminal@0.12.0 No license field.
                        npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
                        npm@6.11.3 /usr/local/lib/node_modules/npm
                        S 2 Replies Last reply
                          @potts-mike can u send me the install.log, /home/pi/MagicMirror/installers/install.log
                          same userid as here at gmail
                          or post it here
                            @potts-mike also, try again… fixed a messaging problem
                            but… you have MM already installed… (if the folder exists, cause the log is put there)…
                            so, you should be using the update-script to bring to next version…
                              satsatt @sdetweil
                              @sdetweil Can You help me please with this, running Your script gives me this
                              doing test run = false
                              saving custom.css
                              upgrading from version 2.6.0 to 2.8.0
                              fetching latest revisions
                              error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                              überschrieben werden:
                              	package-lock.json
                              	vendor/package-lock.json
                              Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                              Abbruch
                              there were merge errors
                              you should examine and resolve them
                              using the command git log --oneline --decorate
                              de57daa (grafted, HEAD ->
                              how do i commit or stash?
                                sdetweil @satsatt
                                @satsatt can u post the contents of /home/pi/MagicMirror/installers/upgrade.log
                                to stash, it is git stash
                                but it should have prompted you to do that… so, please wait til I look thru the log
                                  satsatt @sdetweil
                                  @sdetweil ```
                                  Upgrade started - Sa Sep 14 09:01:30 CEST 2019
                                  doing test run = true
                                  downloading dumpactivemodules script
                                  saving custom.css
                                  remote name = origin
                                  current branch = master
                                  no files different from github version
                                  test merge result rc=‘’ if empty, no conflicts
                                  skipping merge, only test run
                                  processing for module MMM-SystemStats . please wait
                                  skipped processing for MMM-SystemStats, doing test run
                                  processing for module MMM-DWD-WarnWeather . please wait
                                  skipped processing for MMM-DWD-WarnWeather, doing test run
                                  restoring custom.css
                                  Upgrade ended - Sa Sep 14 09:01:33 CEST 2019
                                  Upgrade started - Sa Sep 14 09:02:16 CEST 2019
                                  user requested to apply changes
                                  saving custom.css
                                  executing merge, apply specified
                                  merge result rc= 1 Aktualisiere de57daa…a31546b
                                  Upgrade ended - Sa Sep 14 09:02:18 CEST 2019
                                  Upgrade started - Sa Sep 14 14:50:08 CEST 2019
                                  saving custom.css
                                    sdetweil @satsatt
                                    @satsatt great thanks…
                                    can u show me the results of
                                    git status
                                    thanks
                                      satsatt @sdetweil
                                      @sdetweil ```
                                      pi@raspberrypi:~/MagicMirror $ git status
                                      Auf Branch master
                                      Ihr Branch ist zu ‘origin/master’ um 2639 Commits hinterher, und kann vorgespult werden.
                                      (benutzen Sie “git pull”, um Ihren lokalen Branch zu aktualisieren)
                                      zum Commit vorgemerkte Änderungen:
                                      (benutzen Sie “git reset HEAD …” zum Entfernen aus der Staging-Area)
                                      geändert:       package-lock.json
                                      geändert:       vendor/package-lock.json
                                      Unversionierte Dateien:
                                      (benutzen Sie “git add …”, um die Änderungen zum Commit vorzumerken)
                                      installers/dumpactivemodules.js
                                        sdetweil @satsatt
                                        @satsatt english word search…
                                        can u show me output of
                                        locale
                                          satsatt
                                          pi@raspberrypi:~/MagicMirror $ locale
                                          LANG=de_DE.UTF-8
                                          LANGUAGE=de_DE.UTF-8
                                          LC_CTYPE="de_DE.UTF-8"
                                          LC_NUMERIC="de_DE.UTF-8"
                                          LC_TIME="de_DE.UTF-8"
                                          LC_COLLATE="de_DE.UTF-8"
                                          LC_MONETARY="de_DE.UTF-8"
                                          LC_MESSAGES="de_DE.UTF-8"
                                          LC_PAPER="de_DE.UTF-8"
                                          LC_NAME="de_DE.UTF-8"
                                          LC_ADDRESS="de_DE.UTF-8"
                                          LC_TELEPHONE="de_DE.UTF-8"
                                          LC_MEASUREMENT="de_DE.UTF-8"
                                          LC_IDENTIFICATION="de_DE.UTF-8"
                                          LC_ALL=de_DE.UTF-8
                                            satsatt
                                            you want git status in english i suppose?
                                            • 16
                                            • 17
                                            • 2 / 17
