    328 Posts 27 Posters 650.1k Views 24 Watching
      sdetweil @Mykle1
      @Mykle1 thx. The pm2 on Mac was a challenge. Helped cleanup the older code tho.
      • T Offline
        trividar
        @sdetweil Could you explain exactly what this script is? THX
        T S 2 Replies Last reply Reply Quote 0
        • T Offline
          trividar @trividar
          @sdetweil I found it ;o)
            sdetweil @trividar
            @trividar there are two scripts referenced above
            a new updated installer script, that hopefully fixes some of the problems reported
            a brand new script that will do the update/upgrade to the next MM version when it comes out.
            the current MM plan is to release a new version every 90 days (quarter)
            look thru the forums for how many people had trouble installing the update…
            2.7 from 2.6, and 2.8 from 2.7…
              i updated the links in the 1st post to add .sh to the end of the script name to be consistent with the other two scripts
              raspberry.sh install
              fixuppm2.sh fix pm2 without having to do install (or u changed your mind)
              and now
              update-script.sh do all the work to update your current install to new code level
                MwMagicMirror
                @sdetweil said in new update/upgrade script, ready for testing:
                bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                I just ran your script and get the following errors:
                error: pathspec ‘.github/stale.yml’ did not match any file(s) known to git.
                error: pathspec ‘modules/default/calendar/vendor/ical.js/example_rrule.js’ did not match any file(s) known to git.
                error: pathspec ‘modules/default/calendar/vendor/ical.js/examples/example_rrule.ics’ did not match any file(s) known to git.
                error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test12.ics’ did not match any file(s) known to git.
                error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test13.ics’ did not match any file(s) known to git.
                error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test14.ics’ did not match any file(s) known to git.
                error: pathspec ‘modules/default/weather/providers/ukmetoffice.js’ did not match any file(s) known to git.
                error: pathspec ‘modules/default/weather/providers/weathergov.js’ did not match any file(s) known to git.
                error: pathspec ‘translations/sk.json’ did not match any file(s) known to git.
                error: pathspec ‘translations/tlh.json’ did not match any file(s) known to git.
                error: pathspec ‘vendor/css/font-awesome.css’ did not match any file(s) known to git.
                Any Ideas? I dont recall messing with any of those files.
                MW
                  sdetweil @MwMagicMirror
                  @MwMagicMirror can u send me the mm/installers/upgrade.log
                  Same userid as here at Gmail.com
                  G Mykle1M 2 Replies Last reply Reply Quote 0
                    Those files are in the current GitHub repo.
                    • G Offline
                      Gomalley @sdetweil
                        Tried using the your upgrade script. Current MM version 2.6.
                        Upgrade started - Tue Aug 20 21:51:16 EDT 2019
                        doing test run = true
                        downloading dumpactivemodules script
                        saving custom.css
                        remote name =
                        fetching latest revisions
                        MagicMirror git pull failed
                        restoring custom.css
                        Upgrade ended - Tue Aug 20 21:51:17 EDT 2019
                        • 32
                        • 33
                        • 1 / 33
