    328 Posts 27 Posters 658.0k Views 24 Watching
      I also have a newer installer that resolves a lot of problems with PM2, and supports installing on non-PI systems (Mac, pi zero, odroid, jetson nano)
       bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
      edited Jan 4, 2020 - move from dropbox to github as distro
      Mykle1M 1 Reply Last reply Reply Quote 4
        Personally, I’d like to thank you, Sam, for your excellent work on the install scripts. I’ve used them twice in the past and they worked perfectly
          sdetweil @Mykle1
          @Mykle1 thx. The pm2 on Mac was a challenge. Helped cleanup the older code tho.
          • T Offline
            trividar
            @sdetweil Could you explain exactly what this script is? THX
            T S 2 Replies Last reply Reply Quote 0
            • T Offline
              trividar @trividar
              @sdetweil I found it ;o)
                sdetweil @trividar
                @trividar there are two scripts referenced above
                a new updated installer script, that hopefully fixes some of the problems reported
                a brand new script that will do the update/upgrade to the next MM version when it comes out.
                the current MM plan is to release a new version every 90 days (quarter)
                look thru the forums for how many people had trouble installing the update…
                2.7 from 2.6, and 2.8 from 2.7…
                  i updated the links in the 1st post to add .sh to the end of the script name to be consistent with the other two scripts
                  raspberry.sh install
                  fixuppm2.sh fix pm2 without having to do install (or u changed your mind)
                  and now
                  update-script.sh do all the work to update your current install to new code level
                    MwMagicMirror
                    @sdetweil said in new update/upgrade script, ready for testing:
                    bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                    I just ran your script and get the following errors:
                    error: pathspec ‘.github/stale.yml’ did not match any file(s) known to git.
                    error: pathspec ‘modules/default/calendar/vendor/ical.js/example_rrule.js’ did not match any file(s) known to git.
                    error: pathspec ‘modules/default/calendar/vendor/ical.js/examples/example_rrule.ics’ did not match any file(s) known to git.
                    error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test12.ics’ did not match any file(s) known to git.
                    error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test13.ics’ did not match any file(s) known to git.
                    error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test14.ics’ did not match any file(s) known to git.
                    error: pathspec ‘modules/default/weather/providers/ukmetoffice.js’ did not match any file(s) known to git.
                    error: pathspec ‘modules/default/weather/providers/weathergov.js’ did not match any file(s) known to git.
                    error: pathspec ‘translations/sk.json’ did not match any file(s) known to git.
                    error: pathspec ‘translations/tlh.json’ did not match any file(s) known to git.
                    error: pathspec ‘vendor/css/font-awesome.css’ did not match any file(s) known to git.
                    Any Ideas? I dont recall messing with any of those files.
                    MW
                      sdetweil @MwMagicMirror
                      @MwMagicMirror can u send me the mm/installers/upgrade.log
                      Same userid as here at Gmail.com
                      G Mykle1M 2 Replies Last reply Reply Quote 0
                        Those files are in the current GitHub repo.
                        • 32
                        • 33
                        • 1 / 33
