    328 Posts 27 Posters 740.6k Views 24 Watching
    • BKeyportB
      BKeyport Module Developer
      Love this concept - question though - from what I’ve read (bits and pieces admittedly), it looks like it only handles the main software - could this be expanded to traverse your module directories and update them, so it could be run, say nightly, to check for and apply updates to everything?
        rabbit83ka
        Hi, great work! I Just used the script to update to 2.9.0 - the only thing I had to do manually was a
        git reset --hard
        before running the script (and afterwards restoring my backup of custom.css).
          sdetweil @BKeyport
          @BKeyport it could… it does traverse the modules already, but it currently only does the npm install part (to update to the current runtime dependencies) … but I could extend it easily to check for module updates (like the updatenotifier default module does) , and apply those
          i am trying to get this tested so we can get it into the base (and off of my dropbox)
            sdetweil @rabbit83ka
            @rabbit83ka u should not have had to do the git reset --hard… please tell me why?
            and my script saves and restores custom.css too
              bhepler Module Developer
              I just gave this a try on my house mirror. I didn’t apply and received the following output:
              doing test run = true
              saving custom.css
              bash: line 92: [: !=: unary operator expected
              upgrading from version 2.8.0 to 2.9.0
              fetching latest revisions
              there are 1 local files that are different than the master repo
                 package-lock.json
              any *-lock.json files do not need to be saved
              do you want to save these files for later   (Y/n)?n
              skipping restore for package-lock.json, doing test run
              processing for module MMM-MovieListings . please wait
              skipped processing for MMM-MovieListings, doing test run
              processing for module MMM-Ring . please wait
              skipped processing for MMM-Ring, doing test run
              processing for module MMM-DarkSkyForecast . please wait
              skipped processing for MMM-DarkSkyForecast, doing test run
              restoring custom.css
              bash: line 260: [: !=: unary operator expected
              This seems wrong. What can I do to help?
                sdetweil @bhepler
                @bhepler ok, try again, fixed… assumed locale was set, wasn’t
                • BKeyportB
                  @sdetweil I will clearly keep it watched… thanks for the info!
                    rabbit83ka @sdetweil
                    @sdetweil Same error than @satsatt
                    I had to restore custom.css because the git-reset deleted it (script backed up custom.css correctly).
                      @rabbit83ka hm… can u send me the install.log? same userid as here on gmail
                      i fixed the error that @satsatt had (or so I thought)
                      i check for english locale, if not set or not current, I add an alias to use english to get the right message output
                      then restore the the alias or remove it…
                        @rabbit83ka said in new update/upgrade script, ready for testing:
                        yes, starting with version 2.9.0 they will no longer track it so changes should not be lost…
                        I will leave the save/restore in
                        • Mykle1M
                          Used your update/upgrade script last night. No issues. Thank you, Sam. :thumbsup:
                          MM 2.8.0 -> 2.9.0
                          Ubuntu 18.04.3
                            sdetweil @Mykle1
                            @Mykle1 cool… did u have extra modules also ?
                            • Mykle1M
                              @sdetweil said in new update/upgrade script, ready for testing:
                              Meaning other than the defaults? I have nearly all of my modules installed, as well as my favorites from other devs. Did something happen to them? hahah
                                sdetweil @Mykle1
                                @Mykle1 no. Just checking on how it was handled.
                                Could u email me the Upgrade log
                                • Mykle1M
                                  Where is it saved to? I can’t seem to find it in Home or the MagicMirror dir
                                    sdetweil @Mykle1
                                    @Mykle1 in the installers folder… (where the install script is and where the upgrade and pm2 scripts should go
                                    dang it… u mean you didn’t READ the message the script put out about where the log is? lol…
                                    • Mykle1M
                                      uhhhh . . . real men don’t read messages. ;-)
                                      Sent the file to your gmail
                                        bhepler Module Developer @sdetweil
                                        @sdetweil - Hmm. Curious. Test run of the script looked good. Added the apply keyword and I’m getting a git error.
                                        fatal: Unable to create '/home/pi/MagicMirror/.git/index.lock': File exists.
                                        Another git process seems to be running in this repository, e.g.
                                        an editor opened by 'git commit'. Please make sure all processes
                                        are terminated then try again. If it still fails, a git process
                                        may have crashed in this repository earlier:
                                        remove the file manually to continue.
                                        there were merge errors
                                        you should examine and resolve them
                                        using the command git log --oneline --decorate
                                        a31546b (HEAD -> master, tag: v2.8.0) Merge pull request #1717 from MichMich/develop
                                        Then a bunch of commit statements. There is no git process running at the moment, but that index.lock file does exist. After deleting that file, it worked like a charm. Thanks!
                                          sdetweil @bhepler
                                          @bhepler said in new update/upgrade script, ready for testing:
                                          to git that means it is already running… on exit it cleans up…
                                          should I add handling this error to the script?
                                          I can tell if its there and git is not running.
                                          great feedback… thanks
                                            sdetweil @bhepler
                                            @bhepler i added handling for the git lock file…
                                            if git is NOT running, I erase the dangling lock file
                                            if git IS running, and this is an APPLY run, i change the run back to test mode, and advise to correct the problem
                                            • 16
                                            • 17
                                            • 3 / 17
