    Regions
    Scheduled Pinned Locked Moved Core System
    34 Posts 19 Posters 126.8k Views 24 Watching
      doubleT Module Developer
      @Peter said in Regions:
      . bottom_bar
      That’s what I ment with exact code. Because this will do nothing, it should be
      .bottom.bar
      Because the element you want to address has both classes, there’s no space in between.
      But I see where it went wrong: “bottom_bar” is how you assign a module to a region in the config.js. But that’s not how you address it in css.
      Can you show us your problem with either a screenshot or a photo? If I understand right, you have
      • Newsfeed in bottom_bar (css: .region.bottom.bar .container .module)
      • a module in bottom_left (css: .region.bottom.bar .region.bottom.left)
      • something in bottom_right (css: .region.bottom.bar .region.bottom.right)
        Important: “.region.bottom.bar .container” will address ALL of them because of the structure.
      Usually, the bottom_bar should claim its place as needed and push the other two up as necessary. So that would be normal (and is what you described).
      I’d try
      .region.bottom.bar .container .module.newsfeed {
          height: ???px; /* height of the module with maximum lines possible */
      P 1 Reply Last reply
        Peter @doubleT
        @doubleT , you made my day!
        It works perfectly.
        Indeed I have a newsfeed (several from different sources) in the bottom_bar, Moviemodule in bottom_left and random (travel) pictures in bottom_right region.
        With your help the modules stay on the same line!
        Thanks!
        Peter
          You’re welcome.
          Btw. depending on how you control your Pi and Mirror, you don’t need to restart your whole Pi. In this case, just refreshing the browser should work, or restarting the Mirror process, if it doesn’t.
          • WayneRigleyW
            WayneRigley
            Hi all, well after countless trying ive given up and now asking for help. my MM is working perfect and the only troubling issue in my top_right section, i have a few things in there under the config but i would like to extend the left border of my top_right a little more left if thats possible. i have too much open space from the center to the right side. i will not be resizing fonts using the shift+ +/- any longer so that wont be an issue is manually adjusted. thanks all in advance and have a look here what im refering to
            https://photos.app.goo.gl/EUWdJRQwAjKJksx46
            Wayne R
            • F
              Fifin404
              Hi all, is there any way to change outer border around modules? Make it smaller?
              • FoziF
                Fozi Project Sponsor
                Im main.css you can change the margin, heightand width under ‚body’ as you need. Here are my values I adjusted. The default values are commented.
                body {
                  /* margin: 60px; */
                  margin: 5px;
                  position: absolute;
                  /*height: calc(100% - 120px);
                  width: calc(100% - 120px);*/
                  height: calc(100% - 10px);
                  width: calc(100% - 10px);
                Mykle1M 1 Reply Last reply
                • F
                  Fifin404
                  Thank you, that is what I looking for.
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Fozi
                    @Fozi said in Regions:
                    Encouraging people to modify their main.css is really not a good idea, especially for those that are new to MM and/or linux.
                    Please direct your help towards the custom.css file which is intended for just such modifications.
                    Peace
                    -A concerned citizen-
                    D FoziF 2 Replies Last reply
                      drwatson @Mykle1
                      Good point, @Mykle1
                      Can you then suggest the equivalent change to make the proper way without modifying the main.css?
                      C Mykle1M 2 Replies Last reply
                        cskenney @drwatson
                        @drwatson Copy the exact same code that @Fozi noted above and put it in the custom.css file.
                        Below is what I put in my custom.css file.
                        body {
                          margin: 5px;
                          position: absolute;
                        Reply Quote 3
                        • BKeyportB
                          BKeyport Module Developer
                          • FoziF
                            Fozi Project Sponsor @Mykle1
                            @Mykle1 ouh damned…your concerns are absolutely justified. Haven’t hought of that. Thanks for pointing me to that.:thumbs_up_light_skin_tone:
                            Reply Quote 2
                            • F
                              Fifin404
                              Yes I added code to custom.css not main.css. Thanks for all
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @drwatson
                                @drwatson @Fozi
                                Well, any changes that you consider making in the main.css can be made in the custom.css file without changing the main.css file. The custom.css file will override what is in the main.css file. This way you’re not altering any core files and your modifications will be accepted. When it’s time to upgrade to a newer version of MM the upgrade won’t abort because of changes you’ve made to the core files and your custom.css changes will survive the upgrade. :-)
                                I’m still learning things every day and I enjoy the process. That’s the whole point for me.
                                Peace!
                                • cowboysdudeC
                                  Yes I would HIGHLY suggest you do not change the main.css file… that could send other modules or positions in to chaos. Use the custom css as Mykle1 suggested :)
                                  • T
                                    toots
                                    Sorry if this has been asked. Is there a way to do left_side and right_side? I’m displaying my mirror on a chromecast so it’s locked into landscape mode at 720p and there isn’t a whole lot of room for each of the regions. I’d rather replace top_left and bottom_left with left_side, and just use the entire edge.
                                      sdetweil @toots
                                      @toots u could edit the index.html to add your left/right locations, and add entries to custom.css for them
                                        megagprime
                                        hi all, how could i center this kodi-websocket module between these two?
                                        using bottom left for map, bottom center for kodi websocket and bottom right for wind
                                        i tried custom.css module placement but did not work
                                        .module.MMM-Kodi-WebSocket{
                                        left : 600 px,
                                          pastormingle
                                          can you position left middle?
                                            sdetweil @pastormingle
                                            @pastormingle no, not a valid position
                                            here is the list from the MM doc
                                            https://docs.magicmirror.builders/modules/configuration.html#module-configuration
