    DailyXKCD
    15 Posts 5 Posters 15.7k Views 8 Watching
      paviro
      Maybe add it as an option to the module? I think lots of people would like that!
      – The Doctor
        Blastitt @strawberry 3.141
        @strawberry-3.141 @paviro
        I added an option to invert the colors and dev console shows the image has the style filter : invert(100%); but the colors don’t seem to be inverting at all.
        Update: Changed to -webkit-filter and it worked. Looks hella good.
          Blastitt @Blastitt
            RedNax Module Developer
            Hi!
            Since new comics only come out on monday, wednesday and friday i made a slight modification (ugly hack) to your node_helper.js…
            On non comic days, after getting the current comic, the node_helper will examines the num value and generate a random number between 1 and said value. It will then get the random comic and return it in the payload.
            		var self = this;
            		console.log("Notification: " + notification + " Payload: " + payload);
            		if(notification === "GET_COMIC"){
            			var comicJsonUri = payload.config.dailyJsonUrl;
            			var comic;
            			var rndcomic;
            			var rndUrl;
            			var body;
            			var d = new Date();
            			var n = d.getDay();
            			request(comicJsonUri, function (error, response, body) {
            				if (!error && response.statusCode == 200) {
            					console.log(body);
            					if ( this.n == 1 || this.n == 3 || this.n == 5 ) {
            							self.sendSocketNotification("COMIC", JSON.parse(body));
            					} else {
            						this.comic = JSON.parse(body);
            						this.rndcomic = Math.floor((Math.random() * this.comic.num) + 1);
            						this.rndUrl = "http://xkcd.com/" + this.rndcomic + "/info.0.json";
            						request(this.rndUrl, function (error, response, body) {
            								console.log(body);
            B 1 Reply Last reply
            Reply Quote 2
              Blastitt @RedNax
              @RedNax
              I like it! Put in a pull request if you want it in the official repo. Also maybe add a config option to turn the feature off (if someone just wants to see new comics only)?
                mav29x
                This is awesome! Thanks for making this!!
                • N
                  Nexxic
                  Beautiful little module! I was wondering though, is it possible to adjust the size of the comic? I found it quite big for my mirror. Also, did @RedNax modification get into the module? Tried to just copy-paste it, but didn’t get it to work… (Hope I’m posting in the correct thread for this :P)
                    Blastitt @Nexxic
                    @Nexxic In the only pull request made, the author retracted it. I’ve had a couple people say they were working on a pull request for fixing the size of the larger comics, but nothing’s come of it yet. I’m too busy at the moment, otherwise I would do it myself.
                    J 1 Reply Last reply
                      Submitted another pull request just now…
                        Jopyth Moderator
                        I modified the module, so that it vertically scrolls through the comic. This might be a good option to limit the size, but also be able to see the whole comic (usually the comics have a max. width of 800px, but can be quite high, from time to time).
                        It worked pretty well for this recent one. If you guys want, I can make a pull request.
                        R 1 Reply Last reply
                          RedNax Module Developer @Jopyth
                          @Jopyth Yes please!
                            Jopyth Moderator @Blastitt
                            @Blastitt @RedNax Please review PR #5.
