    DailyXKCD
    15 Posts 5 Posters 15.1k Views 8 Watching
      Blastitt
      (Trying to post this in the Modules/Showcase/Entertainment forum, but that’s not an option on the dropdown… @paviro )
      This module displays the daily XKCD web comic. Automatically updates every 10 hours.
      [card:Blastitt/DailyXKCD]
      Screenshot (Inverted)
      B 1 Reply Last reply Reply Quote 4
      • Z Offline
        zombi27
        yeeah :) i love those!
        I’ll install it right away when i’m home! But a quick idea: Are you able to invert the comics? I think white on black would fit perfectly into the MM :)
        • strawberry 3.141S Offline
          for inverting the colours you can insert the css rule filter: invert(100%);
          B 1 Reply Last reply Reply Quote 2
            paviro
            Maybe add it as an option to the module? I think lots of people would like that!
            – The Doctor
              Blastitt @strawberry 3.141
              @strawberry-3.141 @paviro
              I added an option to invert the colors and dev console shows the image has the style filter : invert(100%); but the colors don’t seem to be inverting at all.
              Update: Changed to -webkit-filter and it worked. Looks hella good.
                Blastitt @Blastitt
                  RedNax Module Developer
                  Hi!
                  Since new comics only come out on monday, wednesday and friday i made a slight modification (ugly hack) to your node_helper.js…
                  On non comic days, after getting the current comic, the node_helper will examines the num value and generate a random number between 1 and said value. It will then get the random comic and return it in the payload.
                  		var self = this;
                  		console.log("Notification: " + notification + " Payload: " + payload);
                  		if(notification === "GET_COMIC"){
                  			var comicJsonUri = payload.config.dailyJsonUrl;
                  			var comic;
                  			var rndcomic;
                  			var rndUrl;
                  			var body;
                  			var d = new Date();
                  			var n = d.getDay();
                  			request(comicJsonUri, function (error, response, body) {
                  				if (!error && response.statusCode == 200) {
                  					console.log(body);
                  					if ( this.n == 1 || this.n == 3 || this.n == 5 ) {
                  							self.sendSocketNotification("COMIC", JSON.parse(body));
                  					} else {
                  						this.comic = JSON.parse(body);
                  						this.rndcomic = Math.floor((Math.random() * this.comic.num) + 1);
                  						this.rndUrl = "http://xkcd.com/" + this.rndcomic + "/info.0.json";
                  						request(this.rndUrl, function (error, response, body) {
                  								console.log(body);
                    Blastitt @RedNax
                    @RedNax
                    I like it! Put in a pull request if you want it in the official repo. Also maybe add a config option to turn the feature off (if someone just wants to see new comics only)?
                      mav29x
                      This is awesome! Thanks for making this!!
                      • N Offline
                        Nexxic
                        Beautiful little module! I was wondering though, is it possible to adjust the size of the comic? I found it quite big for my mirror. Also, did @RedNax modification get into the module? Tried to just copy-paste it, but didn’t get it to work… (Hope I’m posting in the correct thread for this :P)
                          Blastitt @Nexxic
                          @Nexxic In the only pull request made, the author retracted it. I’ve had a couple people say they were working on a pull request for fixing the size of the larger comics, but nothing’s come of it yet. I’m too busy at the moment, otherwise I would do it myself.
                            Submitted another pull request just now…
                              Jopyth Moderator
                              I modified the module, so that it vertically scrolls through the comic. This might be a good option to limit the size, but also be able to see the whole comic (usually the comics have a max. width of 800px, but can be quite high, from time to time).
                              It worked pretty well for this recent one. If you guys want, I can make a pull request.
                                RedNax Module Developer @Jopyth
                                @Jopyth Yes please!
                                  Jopyth Moderator @Blastitt
                                  @Blastitt @RedNax Please review PR #5.
