    Microphone/MMM-voice Help
    31 Posts 7 Posters 15.7k Views 7 Watching
      sdetweil @tnp0327
      @tnp0327 can u minimize the mirror and look at the console log of the terminal window… maybe there is some other error…
      minimize = alt-spacebar, n
      • T Offline
        tnp0327
        @sdetweil @strawberry-3-141 so I did not find a debug file but was able to follow the instructions to look at the console log and the only message I am seeing regarding MMM-voice is:
        Starting module: MMM-voice MMM-voice.js:82
        MMM-voice is waiting for voice command registrations. MMM-voice.js:85
          sdetweil @tnp0327
          @tnp0327 before the modules is the startup of the node_helpers… if u can scroll back up the console window, you might find something else…
          have u tested to make sure the mic is working? with the rec command?
          rec somefile.wav
          on the bottom of the console window should be a meter like bar that moves when u speak…
          then you can control-z out of the rec command and then play somefile.wav to see how it sounds…
          • T Offline
            tnp0327
            OMW to work now - will run it again later and update with my feedback. Thanks for the help so far.
              Abhilash1368 @tnp0327
              @tnp0327 I am going through same thing,it displays mic flashing symbol and just says initialising and undefined at bottom(if degug:true).Did you resolve it?please let me how to make it work?
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @Abhilash1368
                @abhilash1368 do you have content in your debug log file?
                  Abhilash1368 @strawberry 3.141
                  @strawberry-3-141 I don’t see any content,but its working now.Initially I have my own custom twitter module loaded along with MMM-voice(my twitter.js is not modified yet to support MMM-voice). Once after making changes to my twitter.js according to “Hey Lucy” documentation to receive voice notifications,then it is started working. Thanks
                  • richland007R Offline
                    richland007
                    @strawberry-3-141 Ok so i have a very similar situation i have AlexaPi (and MMM-AlexaPi for visual feedback) and want to use MMM-voice and Hello-Lucy. I have 2 USB microphones (a webcam that i talk to AlexaPI and a USB sound card that i want to use for MMM-voice)
                    On the config.js i have assigned microphone id of 2 for MMM-voice ( arecord -l and the install of MMM-voice show that alsa as 0 USB webcam as card 1 and USB sound card as card 2)
                    when i start magic mirror MMM-voice says “initializing” than briefly “Waiting for module commands” than settles on “error”
                    My questions are:
                    1. and i am pretty sure i have an answer for this is that AlexaPi and MMM-voice can they use the same mic or not … most likely not .
                    2. why isn’t using microphone #2 straight forward do i have to twitch anything on alsa config, etc will pulse audio be better and what is the difference ?? how do we mitigate this problem??
                    I have tested and confirmed that both usb microphones work when they are plugged each by themselves but not when they are both simultaneously plugged in only the webcam would record … i am not sure if i am putting the right parameter here “arecord hw:1,0 -d 10 /tmp/test-mic.wav”
                    Please any help will be greatly appreciated
                    Denis
                    • T Offline
                      TheGeekfather @richland007
                      @richland007
                      I too am trying to get Hello-Lucy/Voice to work with my usb soundcard and microphone. I can record outside of MagicMirror so that works but I have the same problem:
                      “displays mic flashing symbol and just says initialising and undefined at bottom”
                      I have tried following the documentation but still no luck
                      Anyone get Hello-Lucy to work?
                      S Mykle1M 2 Replies Last reply Reply Quote 0
                        sdetweil @TheGeekfather
                        @TheGeekfather use arecord -l and lsusb to find the hw: device id needed…
                          Mykle1 Project Sponsor Module Developer @TheGeekfather
                          @TheGeekfather
                          @cowboysdude
                          My apologies, gentlemen. There is a problem with the mic upon install that seems to be specific to the Pi. @cowboysdude did an install late last night and he encountered the same issue, so forgive me. I am looking at it right now and will not sleep until it is resolved. Not!
                          Seriously, it will be fixed ASAP.
                          Thank you for your patience and interest.
                          • T Offline
                            TheGeekfather @Mykle1
                            @Mykle1
                            AWESOME - it is such a great module and to get the mic working would be great !!!
                              @TheGeekfather
                              Sorry about the trouble, man. Totally my fault. Thanks for your patience and interest
                                Mykle1 Project Sponsor Module Developer @Mykle1
                                @TheGeekfather
                                Please try adding microphone: "0", to your config entry. If that does not work please try microphone: "1",
                                EXAMPLE: Just add the microphone line.
                                keyword: 'HELLO LUCY',
                                microphone: "0",
                                 timeout: 7,
                                • T Offline
                                  @Mykle1
                                  It says Initializing “undefined” with line through flashing mic icon with both 0 and 1
                                    @TheGeekfather
                                    Hmm, ok, working on it
                                    • T Offline
                                      @Mykle1
                                      When I try “0” no flashing mic but still “undefined”
                                      I can hear “hello Michael what would you like to see” and then say “Hello Lucy”
                                      but no mic input
                                      mic works - tried arecord
                                        @TheGeekfather
                                        Understood. Lets move this to the Hello-Lucy topic, if you don’t mind
                                        https://forum.magicmirror.builders/topic/6241/hello-lucy/192
                                        • T Offline
                                          @Mykle1
                                          Yes :)
