    Microphone/MMM-voice Help
    31 Posts 7 Posters 15.7k Views 7 Watching
      Abhilash1368 @tnp0327
      @tnp0327 I am going through same thing,it displays mic flashing symbol and just says initialising and undefined at bottom(if degug:true).Did you resolve it?please let me how to make it work?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Abhilash1368
        @abhilash1368 do you have content in your debug log file?
          Abhilash1368 @strawberry 3.141
          @strawberry-3-141 I don’t see any content,but its working now.Initially I have my own custom twitter module loaded along with MMM-voice(my twitter.js is not modified yet to support MMM-voice). Once after making changes to my twitter.js according to “Hey Lucy” documentation to receive voice notifications,then it is started working. Thanks
          • richland007R Offline
            richland007
            @strawberry-3-141 Ok so i have a very similar situation i have AlexaPi (and MMM-AlexaPi for visual feedback) and want to use MMM-voice and Hello-Lucy. I have 2 USB microphones (a webcam that i talk to AlexaPI and a USB sound card that i want to use for MMM-voice)
            On the config.js i have assigned microphone id of 2 for MMM-voice ( arecord -l and the install of MMM-voice show that alsa as 0 USB webcam as card 1 and USB sound card as card 2)
            when i start magic mirror MMM-voice says “initializing” than briefly “Waiting for module commands” than settles on “error”
            My questions are:
            1. and i am pretty sure i have an answer for this is that AlexaPi and MMM-voice can they use the same mic or not … most likely not .
            2. why isn’t using microphone #2 straight forward do i have to twitch anything on alsa config, etc will pulse audio be better and what is the difference ?? how do we mitigate this problem??
            I have tested and confirmed that both usb microphones work when they are plugged each by themselves but not when they are both simultaneously plugged in only the webcam would record … i am not sure if i am putting the right parameter here “arecord hw:1,0 -d 10 /tmp/test-mic.wav”
            Please any help will be greatly appreciated
            Denis
            • T Offline
              TheGeekfather @richland007
              @richland007
              I too am trying to get Hello-Lucy/Voice to work with my usb soundcard and microphone. I can record outside of MagicMirror so that works but I have the same problem:
              “displays mic flashing symbol and just says initialising and undefined at bottom”
              I have tried following the documentation but still no luck
              Anyone get Hello-Lucy to work?
              S Mykle1M 2 Replies Last reply Reply Quote 0
                sdetweil @TheGeekfather
                @TheGeekfather use arecord -l and lsusb to find the hw: device id needed…
                  Mykle1 Project Sponsor Module Developer @TheGeekfather
                  @TheGeekfather
                  @cowboysdude
                  My apologies, gentlemen. There is a problem with the mic upon install that seems to be specific to the Pi. @cowboysdude did an install late last night and he encountered the same issue, so forgive me. I am looking at it right now and will not sleep until it is resolved. Not!
                  Seriously, it will be fixed ASAP.
                  Thank you for your patience and interest.
                  • T Offline
                    TheGeekfather @Mykle1
                    @Mykle1
                    AWESOME - it is such a great module and to get the mic working would be great !!!
                      @TheGeekfather
                      Sorry about the trouble, man. Totally my fault. Thanks for your patience and interest
                        Mykle1 Project Sponsor Module Developer @Mykle1
                        @TheGeekfather
                        Please try adding microphone: "0", to your config entry. If that does not work please try microphone: "1",
                        EXAMPLE: Just add the microphone line.
                        keyword: 'HELLO LUCY',
                        microphone: "0",
                         timeout: 7,
                        • T Offline
                          @Mykle1
                          It says Initializing “undefined” with line through flashing mic icon with both 0 and 1
                            @TheGeekfather
                            Hmm, ok, working on it
                            • T Offline
                              @Mykle1
                              When I try “0” no flashing mic but still “undefined”
                              I can hear “hello Michael what would you like to see” and then say “Hello Lucy”
                              but no mic input
                              mic works - tried arecord
                                @TheGeekfather
                                Understood. Lets move this to the Hello-Lucy topic, if you don’t mind
                                https://forum.magicmirror.builders/topic/6241/hello-lucy/192
                                • T Offline
                                  @Mykle1
                                  Yes :)
