    Microphone/MMM-voice Help
    31 Posts 7 Posters 16.1k Views 7 Watching
      sdetweil @tnp0327
      @tnp0327 before the modules is the startup of the node_helpers… if u can scroll back up the console window, you might find something else…
      have u tested to make sure the mic is working? with the rec command?
      rec somefile.wav
      on the bottom of the console window should be a meter like bar that moves when u speak…
      then you can control-z out of the rec command and then play somefile.wav to see how it sounds…
      • T
        tnp0327
        OMW to work now - will run it again later and update with my feedback. Thanks for the help so far.
        • A
          Abhilash1368 @tnp0327
          @tnp0327 I am going through same thing,it displays mic flashing symbol and just says initialising and undefined at bottom(if degug:true).Did you resolve it?please let me how to make it work?
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @Abhilash1368
            @abhilash1368 do you have content in your debug log file?
            • A
              Abhilash1368 @strawberry 3.141
              @strawberry-3-141 I don’t see any content,but its working now.Initially I have my own custom twitter module loaded along with MMM-voice(my twitter.js is not modified yet to support MMM-voice). Once after making changes to my twitter.js according to “Hey Lucy” documentation to receive voice notifications,then it is started working. Thanks
              • richland007R
                richland007
                @strawberry-3-141 Ok so i have a very similar situation i have AlexaPi (and MMM-AlexaPi for visual feedback) and want to use MMM-voice and Hello-Lucy. I have 2 USB microphones (a webcam that i talk to AlexaPI and a USB sound card that i want to use for MMM-voice)
                On the config.js i have assigned microphone id of 2 for MMM-voice ( arecord -l and the install of MMM-voice show that alsa as 0 USB webcam as card 1 and USB sound card as card 2)
                when i start magic mirror MMM-voice says “initializing” than briefly “Waiting for module commands” than settles on “error”
                My questions are:
                1. and i am pretty sure i have an answer for this is that AlexaPi and MMM-voice can they use the same mic or not … most likely not .
                2. why isn’t using microphone #2 straight forward do i have to twitch anything on alsa config, etc will pulse audio be better and what is the difference ?? how do we mitigate this problem??
                I have tested and confirmed that both usb microphones work when they are plugged each by themselves but not when they are both simultaneously plugged in only the webcam would record … i am not sure if i am putting the right parameter here “arecord hw:1,0 -d 10 /tmp/test-mic.wav”
                Please any help will be greatly appreciated
                Denis
                • T
                  TheGeekfather @richland007
                  @richland007
                  I too am trying to get Hello-Lucy/Voice to work with my usb soundcard and microphone. I can record outside of MagicMirror so that works but I have the same problem:
                  “displays mic flashing symbol and just says initialising and undefined at bottom”
                  I have tried following the documentation but still no luck
                  Anyone get Hello-Lucy to work?
                  S Mykle1M 2 Replies Last reply Reply Quote 0
                    sdetweil @TheGeekfather
                    @TheGeekfather use arecord -l and lsusb to find the hw: device id needed…
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @TheGeekfather
                      @TheGeekfather
                      @cowboysdude
                      My apologies, gentlemen. There is a problem with the mic upon install that seems to be specific to the Pi. @cowboysdude did an install late last night and he encountered the same issue, so forgive me. I am looking at it right now and will not sleep until it is resolved. Not!
                      Seriously, it will be fixed ASAP.
                      Thank you for your patience and interest.
                      • T
                        TheGeekfather @Mykle1
                        @Mykle1
                        AWESOME - it is such a great module and to get the mic working would be great !!!
                        • Mykle1M
                          @TheGeekfather
                          Sorry about the trouble, man. Totally my fault. Thanks for your patience and interest
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @Mykle1
                            @TheGeekfather
                            Please try adding microphone: "0", to your config entry. If that does not work please try microphone: "1",
                            EXAMPLE: Just add the microphone line.
                            keyword: 'HELLO LUCY',
                            microphone: "0",
                             timeout: 7,
                            • T
                              @Mykle1
                              It says Initializing “undefined” with line through flashing mic icon with both 0 and 1
                              • Mykle1M
                                @TheGeekfather
                                Hmm, ok, working on it
                                • T
                                  @Mykle1
                                  When I try “0” no flashing mic but still “undefined”
                                  I can hear “hello Michael what would you like to see” and then say “Hello Lucy”
                                  but no mic input
                                  mic works - tried arecord
                                  • Mykle1M
                                    @TheGeekfather
                                    Understood. Lets move this to the Hello-Lucy topic, if you don’t mind
                                    https://forum.magicmirror.builders/topic/6241/hello-lucy/192
                                    • T
                                      @Mykle1
                                      Yes :)
