    Microphone/MMM-voice Help
    31 Posts 7 Posters 15.4k Views 7 Watching
      Abhilash1368 @strawberry 3.141
      @strawberry-3-141 I don’t see any content,but its working now.Initially I have my own custom twitter module loaded along with MMM-voice(my twitter.js is not modified yet to support MMM-voice). Once after making changes to my twitter.js according to “Hey Lucy” documentation to receive voice notifications,then it is started working. Thanks
      • richland007R Offline
        richland007
        @strawberry-3-141 Ok so i have a very similar situation i have AlexaPi (and MMM-AlexaPi for visual feedback) and want to use MMM-voice and Hello-Lucy. I have 2 USB microphones (a webcam that i talk to AlexaPI and a USB sound card that i want to use for MMM-voice)
        On the config.js i have assigned microphone id of 2 for MMM-voice ( arecord -l and the install of MMM-voice show that alsa as 0 USB webcam as card 1 and USB sound card as card 2)
        when i start magic mirror MMM-voice says “initializing” than briefly “Waiting for module commands” than settles on “error”
        My questions are:
        1. and i am pretty sure i have an answer for this is that AlexaPi and MMM-voice can they use the same mic or not … most likely not .
        2. why isn’t using microphone #2 straight forward do i have to twitch anything on alsa config, etc will pulse audio be better and what is the difference ?? how do we mitigate this problem??
        I have tested and confirmed that both usb microphones work when they are plugged each by themselves but not when they are both simultaneously plugged in only the webcam would record … i am not sure if i am putting the right parameter here “arecord hw:1,0 -d 10 /tmp/test-mic.wav”
        Please any help will be greatly appreciated
        Denis
        • T Offline
          TheGeekfather @richland007
          @richland007
          I too am trying to get Hello-Lucy/Voice to work with my usb soundcard and microphone. I can record outside of MagicMirror so that works but I have the same problem:
          “displays mic flashing symbol and just says initialising and undefined at bottom”
          I have tried following the documentation but still no luck
          Anyone get Hello-Lucy to work?
          S Mykle1M 2 Replies Last reply Reply Quote 0
            sdetweil @TheGeekfather
            @TheGeekfather use arecord -l and lsusb to find the hw: device id needed…
              Mykle1 Project Sponsor Module Developer @TheGeekfather
              @TheGeekfather
              @cowboysdude
              My apologies, gentlemen. There is a problem with the mic upon install that seems to be specific to the Pi. @cowboysdude did an install late last night and he encountered the same issue, so forgive me. I am looking at it right now and will not sleep until it is resolved. Not!
              Seriously, it will be fixed ASAP.
              Thank you for your patience and interest.
              • T Offline
                TheGeekfather @Mykle1
                @Mykle1
                AWESOME - it is such a great module and to get the mic working would be great !!!
                  @TheGeekfather
                  Sorry about the trouble, man. Totally my fault. Thanks for your patience and interest
                    Mykle1 Project Sponsor Module Developer @Mykle1
                    @TheGeekfather
                    Please try adding microphone: "0", to your config entry. If that does not work please try microphone: "1",
                    EXAMPLE: Just add the microphone line.
                    keyword: 'HELLO LUCY',
                    microphone: "0",
                     timeout: 7,
                    • T Offline
                      @Mykle1
                      It says Initializing “undefined” with line through flashing mic icon with both 0 and 1
                        @TheGeekfather
                        Hmm, ok, working on it
                        • T Offline
                          @Mykle1
                          When I try “0” no flashing mic but still “undefined”
                          I can hear “hello Michael what would you like to see” and then say “Hello Lucy”
                          but no mic input
                          mic works - tried arecord
                            @TheGeekfather
                            Understood. Lets move this to the Hello-Lucy topic, if you don’t mind
                            https://forum.magicmirror.builders/topic/6241/hello-lucy/192
                            • T Offline
                              @Mykle1
                              Yes :)
