    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.4k Views 77 Watching
      Jopyth Moderator @slickric
      @slickric What browser (version?) are you using? It seems the javascript is not loading correctly, so I probably made something which is not compatible with your browser. I will try to fix this as soon as possible.
      S 2 Replies Last reply
      • Mr.MeeseeksM
        Mr.Meeseeks @plumcraft
        @plumcraft
        I’m working on that feature now on my own dev, I’ve currently added ‘refresh page’ and ‘update magic mirror’ next is upgrading modules. Then hopefully adding and configuring modules.
        CAAAAN DOO!👍
          slickric @Jopyth
          @Jopyth safari on iOS 10. I’ve got an android tablet that I’ll try this morning to see if that’s the case. Thanks for the quick reply!
            slickric @Jopyth
            @Jopyth I get the same on chrome 54.0.2840.66 on iOS10 too :/
            J 1 Reply Last reply
              plumcraft
              @Mr-Meeseeks : Perfect, thanks :)
                Pbaan93
                Trying to get the HIDE/SHOW working with postman.
                http://192.168.2.2:8080/remote?action=HIDE&module=<<module_name>>
                What is the syntax? cant find it, sorry …
                  Jopyth Moderator @Pbaan93
                  @Pbaan93 You have got the correct syntax, your only problem might be, that you need the correct identifier, which depends on your config.js. If your modules in your config.js look like this:
                          module: 'calendar',
                          header: 'Some calendar',
                          position: 'top_right',
                              // not configured, just an example
                          module: 'clock',
                          position: 'top_left'
                          module: 'newsfeed',
                          position: 'bottom_bar',
                  You could use module_0_calendar, module_1_clock and module_2_newsfeed to hide each module (it is always module + the number of the module in your config, starting to count from 0 + the module name, all separated with underscores).
                  This is the internal identifier, and not simple to construct, but allows to have, for example multiple calendars, and you can hide one or the other.
                    Pbaan93
                    @Jopyth Thanks for the clear info! I will try this tonight.
                    I’m planning to make an app for ‘Homey’ so i can controll the mirror with my home automation system. With your app this will be possible, so thanks again!
                    For easy configuration in the homey app I need an extra API option: ‘list’, so the homey app knows all the modules with their status. Is this possible?
                      @slickric That is weird, my iPad is also running chrome 54.0.2840.66. I assume this also happens, when you access the remote URL from a desktop browser? Could you open the remote URL with developer console, and have a look at possible errors?
                      @Pbaan93 I can add this, yes. Do you think a simple JSON format would suffice?
                        Pbaan93
                        Yes that would be really nice!!! Just a list of modules with their status, preferably also their identyfier if that is possible. Thanks to this I can make the homey app completely adaptive to wat modules are installed on the mirror.
                          slickric @Jopyth
                          @Jopyth #facepalm as expected it was me that was the problem. Got the below errors in console which made me realise immediately that for some rediculous reason I changed the name of the folder from “MMM-Remote-Control” to just “remote”. Obviously it couldn’t find the CSS and js files because I changed the folder :/ renamed and all working perfectly. Great work with the module and massive thanks for the help! alt text
                            Jopyth Moderator
                            New version, please let me know if you find any bugs:
                            [1.0.0] - 2016-10-24
                            Added
                            • Changelog
                            • New buttons in user interface
                              • Hide/show all modules
                              • Link to MagicMirror² homepage
                              • Option to adapt brightness (making the mirror brighter than 100% can be limited to certain modules)
                            • Contributing hints
                            • Internal versioning of saved config (current version: 1)
                            • Added action MODULE_DATA to return module data in JSON format
                            Changed
                            • Internal timeout for commands increased from 5 to 8 seconds
                            • Symbols for display on and off
                            • Internal changes in preparation for Magic Mirror version 2.1.0
                            P R 2 Replies Last reply
                            Reply Quote 3
                              Pbaan93 @Jopyth
                              @Jopyth That is really fast! Nice! Cool improvements ;)
                                Pbaan93
                                @Jopyth Nice update, tested it and it works like a charm.
                                You have shown me more ideas :P …
                                Is it possible to set position? Than we will almost have full controll!
                                • G
                                  gismo2006
                                  @Jopyth Don’t worry, no more questions. ;-) I like only to say thank you :-)
                                    rvdgeer @Jopyth
                                    @Jopyth Thank you for the great update.
                                    I see you have implemented some of my suggestions, which makes me very happy.
                                    I still hope to see this evolve into a config GUI some day…
                                      Jopyth Moderator
                                      @rvdgeer This is the next big thing on my ToDo list. I don’t know when I will finish this though. If anyone has ideas on the workflow and the UI and how they would like to see and change the config in the UI, feel free to post here.
                                      R 1 Reply Last reply
                                        rvdgeer @Jopyth
                                        @Jopyth Sounds great!
                                        If you want the all-in-one package:
                                        I could imagine you need to be able crawl and index all installed modules and openup their modulename.js files to be able to determine what configurable parameters it has.
                                        That way it should be possible to vreate buttons in the remote to add an installed module from a list and add and edit the parameters.
                                        This might need a change in the core structure, because it would be nice to know what parameters per module are availble and what the possible values are…
                                        (Like what’s posted on most of the modules github pages.)
                                        And how about an option to drag and drop the order of the modules.
                                        Another (slimmed down) way to go would be to just look at the current config and make al parameters editable in a form. Maybe create an option to add a new parameter and it’s value. The users should know the name and possible values for the parameter.
                                        In the future you could even dream about an option to ‘git pull’ a module to update it from the gui. Or to ‘npm install’ the depencies. And maybe even download and install new modules that are availble online…
                                        But that’s just me dreaming…
                                        • Mr.MeeseeksM
                                          Mr.Meeseeks
                                          @Jopyth I’ve added on mine ability to refresh browser, update mm and modules, and send alerts. I’ll probably work on installing and configuring modules next.
                                          I’ll push merge soon
                                          CAAAAN DOO!👍
                                          J 2 Replies Last reply
                                            Jopyth Moderator @Mr.Meeseeks
                                            @Mr.Meeseeks Nice!
                                            • 13
                                            • 14
                                            • 3 / 14
