    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.4k Views 77 Watching
    • MichMichM
      MichMich
      Super awesome work on the remote App!
      Not sure if you already noticed it, but there is a change in the hide/show mechanism which might be very helpful for you:
      https://forum.magicmirror.builders/topic/241/revising-the-show-hide-mechanism/9
      Keep up the good work.
      • G
        gismo2006
        @Jopyth
        I use your MMM-Remote Control. Thank you for this verry good Modul.
        But I have a litlle question. Maybe some other will ask themselves too. In a single flat whit only one Person it wouldn’t a problem, but in a House/Flat whit more then one Person (wife/Children…) I thing it could maybe a problem that everybody can call the remote Page. And so I ask myself Is it possible and is it many work to code a PIN question before you can Open the page or clicking something?
        greets gismo
        J 1 Reply Last reply
          Jopyth Moderator @gismo2006
          @gismo2006 Good idea. Originally I thought the IP address filtering coming in version 2.1.0 could serve that purpose. Do you think that would work? I.e. you can assign fixed IP addresses to your devices, and enter these addresses in the config.js, and only these IP’s are allowed to access the mirror (and also the Remote Control).
          • G
            gismo2006
            @Jopyth
            Hmmm… I think it was a step in a secrue direction. Because here everybody is ill I haven’t enough time to think about it now. But when I think shortly about your post. I think its a first good Idea. But if you say only fixed Ip’s can use and will controll by config.js file, its important only you can use the device. I think about a Desktop Pc in a famelie house. You used it, later your wife used it and if the childs grow up they used it. In the best case everbody has got their own User at the Desktop Pc but it will have the same Ip. So everybody can used the remote page too, because everybody used the PC. :-) Or maybe a tablet which is in the house You see some www Page, later your wife talked about skype, and later the Childs manipulate your mirror because it is funny to hide everything…
            Maybe I think to much about manipulating your mirror in your own flat/house. and they will never happend anything but who knowns… :-)
            By the way, I really hope, my old englich Teacher will never,never see my Postings… :-D
              @gismo2006 Good point. We might even want something like this option in the core.
                rvdgeer
                I did some suggestions (or feature requests as you wish) in the past and since they were all implemented (thanks!!!) it’s time for some more…
                Wouldn’t it be nice to be able to open up the magicmirror ‘homepage’ from your remote?
                Sometimes when I enable/disable modules I would like to see the changes without having to actually go to the mirror to see the changes. So a simple shortcut on the remote to open the ‘homepage’ in a new tab would be great.
                And how awesome would it be if this remote could be developed towards something like a GUI for the config.js?!
                This means it needs to be part of the core, so it can read all (possible) parameters from each module and make them editable (with the availbale values/options) in a ‘remote config’ web gui.
                Possible uses:
                • enable and disable modules (instead of hiding: very useful for your background Halloween video)
                • move modules from one region to another
                • change headers
                • change newsfeedurl or update api key
                • etc.
                  plumcraft
                  @Jopyth : Really great work for your remote control module !
                  Someone might already suggest that, but because i’m not sure, let’s see :
                  It would be nice to have on your remote control page, versions of the different modules and indicate if there is a new release for it.
                  I think the idea is not having an automatic upgrade mechanism for now.
                  What do you think ?
                  -Olivier
                  Mr.MeeseeksM 1 Reply Last reply
                    slickric
                    I experience an issue that I haven’t seen other people so sure I’ve done something wrong. When I load the remote on my phone, I get a whole list of options but none clickable :/ Remote topRemote bottom
                      Jopyth Moderator @slickric
                      @slickric What browser (version?) are you using? It seems the javascript is not loading correctly, so I probably made something which is not compatible with your browser. I will try to fix this as soon as possible.
                      S 2 Replies Last reply
                      • Mr.MeeseeksM
                        Mr.Meeseeks @plumcraft
                        @plumcraft
                        I’m working on that feature now on my own dev, I’ve currently added ‘refresh page’ and ‘update magic mirror’ next is upgrading modules. Then hopefully adding and configuring modules.
                        CAAAAN DOO!👍
                          slickric @Jopyth
                          @Jopyth safari on iOS 10. I’ve got an android tablet that I’ll try this morning to see if that’s the case. Thanks for the quick reply!
                            slickric @Jopyth
                            @Jopyth I get the same on chrome 54.0.2840.66 on iOS10 too :/
                              plumcraft
                              @Mr-Meeseeks : Perfect, thanks :)
                                Pbaan93
                                Trying to get the HIDE/SHOW working with postman.
                                http://192.168.2.2:8080/remote?action=HIDE&module=<<module_name>>
                                What is the syntax? cant find it, sorry …
                                  Jopyth Moderator @Pbaan93
                                  @Pbaan93 You have got the correct syntax, your only problem might be, that you need the correct identifier, which depends on your config.js. If your modules in your config.js look like this:
                                          module: 'calendar',
                                          header: 'Some calendar',
                                          position: 'top_right',
                                              // not configured, just an example
                                          module: 'clock',
                                          position: 'top_left'
                                          module: 'newsfeed',
                                          position: 'bottom_bar',
                                  You could use module_0_calendar, module_1_clock and module_2_newsfeed to hide each module (it is always module + the number of the module in your config, starting to count from 0 + the module name, all separated with underscores).
                                  This is the internal identifier, and not simple to construct, but allows to have, for example multiple calendars, and you can hide one or the other.
                                    Pbaan93
                                    @Jopyth Thanks for the clear info! I will try this tonight.
                                    I’m planning to make an app for ‘Homey’ so i can controll the mirror with my home automation system. With your app this will be possible, so thanks again!
                                    For easy configuration in the homey app I need an extra API option: ‘list’, so the homey app knows all the modules with their status. Is this possible?
                                      @slickric That is weird, my iPad is also running chrome 54.0.2840.66. I assume this also happens, when you access the remote URL from a desktop browser? Could you open the remote URL with developer console, and have a look at possible errors?
                                      @Pbaan93 I can add this, yes. Do you think a simple JSON format would suffice?
                                        Pbaan93
                                        Yes that would be really nice!!! Just a list of modules with their status, preferably also their identyfier if that is possible. Thanks to this I can make the homey app completely adaptive to wat modules are installed on the mirror.
                                          slickric @Jopyth
                                          @Jopyth #facepalm as expected it was me that was the problem. Got the below errors in console which made me realise immediately that for some rediculous reason I changed the name of the folder from “MMM-Remote-Control” to just “remote”. Obviously it couldn’t find the CSS and js files because I changed the folder :/ renamed and all working perfectly. Great work with the module and massive thanks for the help! alt text
                                            Jopyth Moderator
                                            New version, please let me know if you find any bugs:
                                            [1.0.0] - 2016-10-24
                                            Added
                                            • Changelog
                                            • New buttons in user interface
                                              • Hide/show all modules
                                              • Link to MagicMirror² homepage
                                              • Option to adapt brightness (making the mirror brighter than 100% can be limited to certain modules)
                                            • Contributing hints
                                            • Internal versioning of saved config (current version: 1)
                                            • Added action MODULE_DATA to return module data in JSON format
                                            Changed
                                            • Internal timeout for commands increased from 5 to 8 seconds
                                            • Symbols for display on and off
                                            • Internal changes in preparation for Magic Mirror version 2.1.0
                                            P R 2 Replies Last reply
                                            Reply Quote 3
                                            • 13
                                            • 14
                                            • 3 / 14
