    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.5k Views 77 Watching
    • BangeeB
      Bangee Module Developer
      @ceerix can you try this:
      http://192.168.XXX.XXX:8080/remote?action=RESTART
      @Jopyth the pull request is online. :-)
      https://github.com/Bangee44/MMM-Remote-Control
        Jopyth Moderator @ceerix
        @ceerix How are you going to interact? With custom notifications between the modules? Or are you connecting this differently?
        I am asking because I was thinking, if it is possible to give other modules a simple way of hooking up to my module, and how this could happen. So a first example, on how you would like to do it, might be a good starting point.
          ceerix
          @Bangee thank you for your help this works! :)
          @Jopyth i simply call the URL for the action which i want. For example shutdown the Raspberry when i’m leaving the house.
          A example is the link which Bangee have written:
          If you need any further information i will help you :)
          J 1 Reply Last reply
          • Mr.MeeseeksM
            Mr.Meeseeks @Bangee
            @Bangee @Jopyth thanks again, this is great!
              @ceerix Ok, I see. Thanks!
                Jopyth Moderator
                The module has received a medium update, see the new version on Github.
                Changes:
                • Added: Save as default, which saves the hidden/shown status of your modules (Note: If you change your config, the settings will most likely not load correctly, you might have to change and save them again.)
                • Added: Restart MagicMirror application and switching display on and off, thanks to @Bangee
                • Changed: status indicator appears on top right, instead of the bottom
                • Updated: fixed-width icons, text should be more aligned now
                • Updated: error sign will show (error will appear in server log), if a command fails, e.g. no sudo rights
                • Fixed: style error, which most likely made the remote control look completely different from the preview for anyone except me
                Reply Quote 3
                  d3r
                  New update is sick. Really like the turn display on/off feature.
                  • cowboysdudeC
                    Another module that should be in the core :) Man this mirror is growing Thanks to great people!
                    Thanks @Jopyth
                      ceerix
                      I had an idea in the morning. Would it be possible to develop a new menu in this modul for changing the place of a displayed modul? For example moving it from the top to the middle of the screen with a button?
                      Do you understand what i mean? :)
                      • I
                        ianperrin
                        @Jopyth - another great update. Thanks
                        I’ve added an issue (feature request really) on GitHub to explore whether the functionality of this module could be exposed to other modules so it could be triggered using sendNotification.
                        e.g. sendNotification('REMOTE_ACTION', {query: 'MONITOROFF'}
                        I’ve also drafted a pull request with an idea of how this could be done.
                        If this could be implemented, then things like turning the monitor on and off or restarting MM could be scheduled using a combination of this module and MMM-ModuleScheduler
                        “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                          @ceerix Definitely something I would like to have, too, along with spawning new modules. I think it needs changes to the core project though, which support moving and creating of modules while running.
                          @ianperrin Good idea, I answered on github.
                            Jopyth Moderator
                            New update:
                            • It is now possible to “call” all functions provided via the remote control from modules through notifications (see the readme), thanks to @ianperrin
                            Reply Quote 2
                            • Mr.MeeseeksM
                              Mr.Meeseeks
                              • paphkoP
                                paphko
                                Nice work, this module is a handy one!
                                I have another feature request: HIDE_ALL and SHOW_ALL to hide / show all modules at once :-)
                                • BangeeB
                                  this function is called MONITORON - MONITOROFF ;-)
                                  • MichMichM
                                    MichMich
                                    Super awesome work on the remote App!
                                    Not sure if you already noticed it, but there is a change in the hide/show mechanism which might be very helpful for you:
                                    https://forum.magicmirror.builders/topic/241/revising-the-show-hide-mechanism/9
                                    Keep up the good work.
                                    • G
                                      gismo2006
                                      @Jopyth
                                      I use your MMM-Remote Control. Thank you for this verry good Modul.
                                      But I have a litlle question. Maybe some other will ask themselves too. In a single flat whit only one Person it wouldn’t a problem, but in a House/Flat whit more then one Person (wife/Children…) I thing it could maybe a problem that everybody can call the remote Page. And so I ask myself Is it possible and is it many work to code a PIN question before you can Open the page or clicking something?
                                      greets gismo
                                        Jopyth Moderator @gismo2006
                                        @gismo2006 Good idea. Originally I thought the IP address filtering coming in version 2.1.0 could serve that purpose. Do you think that would work? I.e. you can assign fixed IP addresses to your devices, and enter these addresses in the config.js, and only these IP’s are allowed to access the mirror (and also the Remote Control).
                                        • G
                                          gismo2006
                                          @Jopyth
                                          Hmmm… I think it was a step in a secrue direction. Because here everybody is ill I haven’t enough time to think about it now. But when I think shortly about your post. I think its a first good Idea. But if you say only fixed Ip’s can use and will controll by config.js file, its important only you can use the device. I think about a Desktop Pc in a famelie house. You used it, later your wife used it and if the childs grow up they used it. In the best case everbody has got their own User at the Desktop Pc but it will have the same Ip. So everybody can used the remote page too, because everybody used the PC. :-) Or maybe a tablet which is in the house You see some www Page, later your wife talked about skype, and later the Childs manipulate your mirror because it is funny to hide everything…
                                          Maybe I think to much about manipulating your mirror in your own flat/house. and they will never happend anything but who knowns… :-)
                                          By the way, I really hope, my old englich Teacher will never,never see my Postings… :-D
                                            @gismo2006 Good point. We might even want something like this option in the core.
                                            • 13
                                            • 14
                                            • 2 / 14
