    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 954.5k Views 77 Watching
      Jopyth Moderator
      The module has received a medium update, see the new version on Github.
      Changes:
      • Added: Save as default, which saves the hidden/shown status of your modules (Note: If you change your config, the settings will most likely not load correctly, you might have to change and save them again.)
      • Added: Restart MagicMirror application and switching display on and off, thanks to @Bangee
      • Changed: status indicator appears on top right, instead of the bottom
      • Updated: fixed-width icons, text should be more aligned now
      • Updated: error sign will show (error will appear in server log), if a command fails, e.g. no sudo rights
      • Fixed: style error, which most likely made the remote control look completely different from the preview for anyone except me
      Reply Quote 3
        d3r
        New update is sick. Really like the turn display on/off feature.
        • cowboysdudeC
          Another module that should be in the core :) Man this mirror is growing Thanks to great people!
          Thanks @Jopyth
            ceerix
            I had an idea in the morning. Would it be possible to develop a new menu in this modul for changing the place of a displayed modul? For example moving it from the top to the middle of the screen with a button?
            Do you understand what i mean? :)
            J 1 Reply Last reply
            • I
              ianperrin
              @Jopyth - another great update. Thanks
              I’ve added an issue (feature request really) on GitHub to explore whether the functionality of this module could be exposed to other modules so it could be triggered using sendNotification.
              e.g. sendNotification('REMOTE_ACTION', {query: 'MONITOROFF'}
              I’ve also drafted a pull request with an idea of how this could be done.
              If this could be implemented, then things like turning the monitor on and off or restarting MM could be scheduled using a combination of this module and MMM-ModuleScheduler
              “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                Jopyth Moderator @ceerix
                @ceerix Definitely something I would like to have, too, along with spawning new modules. I think it needs changes to the core project though, which support moving and creating of modules while running.
                @ianperrin Good idea, I answered on github.
                  Jopyth Moderator
                  New update:
                  • It is now possible to “call” all functions provided via the remote control from modules through notifications (see the readme), thanks to @ianperrin
                  Reply Quote 2
                  • Mr.MeeseeksM
                    Mr.Meeseeks
                    • paphkoP
                      paphko
                      Nice work, this module is a handy one!
                      I have another feature request: HIDE_ALL and SHOW_ALL to hide / show all modules at once :-)
                      • BangeeB
                        Bangee Module Developer
                        this function is called MONITORON - MONITOROFF ;-)
                        • MichMichM
                          MichMich
                          Super awesome work on the remote App!
                          Not sure if you already noticed it, but there is a change in the hide/show mechanism which might be very helpful for you:
                          https://forum.magicmirror.builders/topic/241/revising-the-show-hide-mechanism/9
                          Keep up the good work.
                          • G
                            gismo2006
                            @Jopyth
                            I use your MMM-Remote Control. Thank you for this verry good Modul.
                            But I have a litlle question. Maybe some other will ask themselves too. In a single flat whit only one Person it wouldn’t a problem, but in a House/Flat whit more then one Person (wife/Children…) I thing it could maybe a problem that everybody can call the remote Page. And so I ask myself Is it possible and is it many work to code a PIN question before you can Open the page or clicking something?
                            greets gismo
                              Jopyth Moderator @gismo2006
                              @gismo2006 Good idea. Originally I thought the IP address filtering coming in version 2.1.0 could serve that purpose. Do you think that would work? I.e. you can assign fixed IP addresses to your devices, and enter these addresses in the config.js, and only these IP’s are allowed to access the mirror (and also the Remote Control).
                              • G
                                gismo2006
                                @Jopyth
                                Hmmm… I think it was a step in a secrue direction. Because here everybody is ill I haven’t enough time to think about it now. But when I think shortly about your post. I think its a first good Idea. But if you say only fixed Ip’s can use and will controll by config.js file, its important only you can use the device. I think about a Desktop Pc in a famelie house. You used it, later your wife used it and if the childs grow up they used it. In the best case everbody has got their own User at the Desktop Pc but it will have the same Ip. So everybody can used the remote page too, because everybody used the PC. :-) Or maybe a tablet which is in the house You see some www Page, later your wife talked about skype, and later the Childs manipulate your mirror because it is funny to hide everything…
                                Maybe I think to much about manipulating your mirror in your own flat/house. and they will never happend anything but who knowns… :-)
                                By the way, I really hope, my old englich Teacher will never,never see my Postings… :-D
                                  @gismo2006 Good point. We might even want something like this option in the core.
                                    rvdgeer
                                    I did some suggestions (or feature requests as you wish) in the past and since they were all implemented (thanks!!!) it’s time for some more…
                                    Wouldn’t it be nice to be able to open up the magicmirror ‘homepage’ from your remote?
                                    Sometimes when I enable/disable modules I would like to see the changes without having to actually go to the mirror to see the changes. So a simple shortcut on the remote to open the ‘homepage’ in a new tab would be great.
                                    And how awesome would it be if this remote could be developed towards something like a GUI for the config.js?!
                                    This means it needs to be part of the core, so it can read all (possible) parameters from each module and make them editable (with the availbale values/options) in a ‘remote config’ web gui.
                                    Possible uses:
                                    • enable and disable modules (instead of hiding: very useful for your background Halloween video)
                                    • move modules from one region to another
                                    • change headers
                                    • change newsfeedurl or update api key
                                    • etc.
                                      plumcraft
                                      @Jopyth : Really great work for your remote control module !
                                      Someone might already suggest that, but because i’m not sure, let’s see :
                                      It would be nice to have on your remote control page, versions of the different modules and indicate if there is a new release for it.
                                      I think the idea is not having an automatic upgrade mechanism for now.
                                      What do you think ?
                                      -Olivier
                                      Mr.MeeseeksM 1 Reply Last reply
                                        slickric
                                        I experience an issue that I haven’t seen other people so sure I’ve done something wrong. When I load the remote on my phone, I get a whole list of options but none clickable :/ Remote topRemote bottom
                                          Jopyth Moderator @slickric
                                          @slickric What browser (version?) are you using? It seems the javascript is not loading correctly, so I probably made something which is not compatible with your browser. I will try to fix this as soon as possible.
                                          S 2 Replies Last reply
                                          • Mr.MeeseeksM
                                            Mr.Meeseeks @plumcraft
                                            @plumcraft
                                            I’m working on that feature now on my own dev, I’ve currently added ‘refresh page’ and ‘update magic mirror’ next is upgrading modules. Then hopefully adding and configuring modules.
                                            • 13
                                            • 14
                                            • 2 / 14
