    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 763.1k Views 27 Watching
    • Mykle1M
      Also, please open a new terminal and type
      cat /proc/asound/cards and post the result here please.
      Mine looks like this:
      pop@e8300:~/MagicMirror$ cat /proc/asound/cards
       0 [PCH            ]: HDA-Intel - HDA Intel PCH
                            HDA Intel PCH at 0xf7130000 irq 29
       1 [NVidia         ]: HDA-Intel - HDA NVidia
                            HDA NVidia at 0xf7080000 irq 17
      T 1 Reply Last reply
      • T
        TheGeekfather @Mykle1
        @Mykle1
        Maybe a problem
        It seems all my modules are in
        modules/default/
        Mykle1M T 3 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @TheGeekfather
          @TheGeekfather
          Definitely a problem
          • T
            TheGeekfather @TheGeekfather
            @TheGeekfather
             0 [ALSA           ]: bcm2835_alsa - bcm2835 ALSA
                                  bcm2835 ALSA
             1 [Device         ]: USB-Audio - USB Audio Device
                                  C-Media Electronics Inc. USB Audio Device at usb-0000:01:00.0-1.1, full speed
            • Mykle1M
              @TheGeekfather said in Hello-Lucy:
              modules/default/
              We went over this earlier, I think. Only the default MM modules go there. All other modules go on the root of the modules folder
              • T
                @Mykle1
                Other modules installed there are working but had to change paths for icons to work
                Mykle1M cowboysdudeC T 3 Replies Last reply
                • Mykle1M
                  I don’t even know how to reply to that. Modules belong in the modules folder
                  • cowboysdudeC
                    cowboysdude Module Developer @TheGeekfather
                    @TheGeekfather The problem is when you try to change things you also are changing the way the mirror works and this will lead to issues…the kind you are having LOL.
                    Default modules are wired to work out of that directory - /modules/default
                    3rd party modules are wired to work out of the modules directory. /modules
                    Seems like a lot of extra work and if you miss something then you will have issues. So my suggestion is that if you get a module from github you do this:
                    in the MagicMirror/modules directory
                    git clone https://github.com/mykle1/Hello-Lucy.git
                    Then go to the dir you just cloned the repository in ie MagicMirror/modules/Hello-Lucy
                    [typically from there if a module has dependencies you’d run ‘npm install’… for Lucy you have to be in the MagicMirror/modules/Hello-Lucy/installers directory and you would run a bash command]
                    Put the module in your config and you’re off an running…
                    This will put your modules in the correct place to run without having to change the module itself… Where you are going to run into issues is when a developer hard codes something you can’t find…
                    It’s already happened and that creates issues that are VERY difficult to solve…
                    But I am glad you are trying to learn something and seem very enthusiastic about it :)
                    • T
                      @TheGeekfather
                      I guess the best thing is to re-install all my modules in the correct folder. Is that the only way to get Lucy to work.
                      Thank you again for all your help
                      • T
                        TheGeekfather @cowboysdude
                        @cowboysdude
                        OK, here is what I did
                        1. deleted Hello-Lucy folder from default directory
                        2. cloned hello-lucy in modules directory
                        3. cd installers and ran bash dependencies.sh
                        4. npm start
                        in modules/default directory In the defaultmodules.js file I added
                        var defaultModules = [
                        	"alert",
                        	"calendar",
                        	"clock",
                        	"compliments",
                        	"currentweather",
                        	"helloworld",
                        	"newsfeed",
                        	"weatherforecast",
                        	"updatenotification",
                        	"MMM-Swipe",
                        	"MMM-NHL",
                        	"MMM-BMW-DS",
                        	"modules/Hello-Lucy",
                        	"MMM-iFrame",
                        	"MMM-Astro",
                        lucy started and microphone icon no longer had “undefined” error but icon not flashing and commands like “show clock” or hide “clock” don’t seem to be working
                        • cowboysdudeC
                          @TheGeekfather Well in all honesty what you’re doing is just making a huge mess. You need to delete ALL the modules that don’t belong in the default folder. ANY changes you made to any files undo…
                          Install modules as they are intended and we can help you, other then that I have no answers for you.
                          • T
                            @cowboysdude
                            I understand - and yes I will re-install
                            One last question - should the mic icon flash when you speak?
                            Again, THANK YOU for all your help :)
                            • cowboysdudeC
                              @TheGeekfather Yes, green :)
                              • T
                                @Mykle1
                                Hi, you mentioned you were going to fix the install problem after noticing microphone not working with a fresh install.
                                Any progress?
                                Thank you for updates
                                • cowboysdudeC
                                  @TheGeekfather The mic is an easy fix if you’re using a pi…
                                  Open terminal and type in ‘arecord -l’ it will give you all the info on your mic… more than likely if your using a USB mic it will be most likely 1,0.
                                  In your config in Hello-Lucy in the ‘config’ section of Hello-Lucy you would put:
                                  "microphone: “1,0”,
                                  That’s it…pretty simple. Yes I realize simple if you know it LOL.
                                  • T
                                    @cowboysdude
                                    :) Knowledge is Power - That is what I always told my students
                                    This is the mic I have
                                    **** List of CAPTURE Hardware Devices ****
                                    card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
                                      Subdevices: 1/1
                                      Subdevice #0: subdevice #0
                                    • cowboysdudeC
                                      @TheGeekfather I went to school to be a teacher but never taught… I’m not real good with touchy feeling kinda things I tend to be more direct and that’s not a good thing in Schools LOL
                                      Yes you could add:
                                        disabled: false,
                                        module: "Hello-Lucy",
                                         keyword: 'HELLO LUCY',
                                         microphone: "1,0",
                                         timeout: 15,                        // timeout listening for a command/sentence
                                         defaultOnStartup: 'Hello-Lucy',
                                         standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                                         sounds: [ ],
                                         confirmationSound: "ding.mp3",
                                          startHideAll: true,                 // if true, all modules start as hidden
                                        pageOneModules: ["Hello-Lucy", "MMM-Insults"],    /
                                        pageTwoModules: ["MMM-BMW-DS", "MMM-Events"],     // modules to show on page two
                                        pageThreeModules: ["MMM-Lunartic"],               // modules to show on page three
                                        pageFourModules: ["MMM-PC-Stats"],                // modules to show on page four
                                        pageFiveModules: [],                              // modules to show on page five
                                        pageSixModules: [],                               // modules to show on page six
                                        pageSevenModules: [],                             // modules to show on page seven
                                        pageEightModules: [],                             // modules to show on page eight
                                        pageNineModules: [],                              // modules to show on page nine
                                        pageTenModules: []                                // modules to show on page ten
                                      That is an example config… the ONLY thing you need to change is the modules listed on the ‘pages’… it should work on a pi with a usb mic… Please note there will be about a 4 to 5 second delay… the pi is small and this is heavy weight it’s lifting.
                                      As soon as @Mykle1 tests this on a pi4 we’ll let everyone know :)
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        @cowboysdude
                                        As you know, the installer was not at fault. The automatic identification of the microphone was not happening, at least on the Pi. Thanks for stepping in while I was busy troubleshooting and thanks for testing
                                        • cowboysdudeC
                                          @Mykle1 Who are you and what are you doing here? LOL
                                          • Mykle1M
                                            @cowboysdude
                                            Uhh, I was hoping you’d tell me. :-)
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
