    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 715.1k Views 27 Watching
      Added modules that will now work by default with Lucy
      1. MMM-MLB
      2. MMM-MLBStandings
      3. MMM-Recipe
      4. MMM-rfacts
      5. MMM-Holiday
      6. MMM-NiceThings
      7. MMM-MusicCharts
      8. MMM-Advice
      9. MMM-NHL
        @TheGeekfather
        When I try “0” no flashing mic but still “undefined”
        I can hear “hello Michael what would you like to see” and then say “Hello Lucy”
        When you say Hello Lucy the microphone does not turn green and start blinking? Just for verification
          Lets verify some other things too.
          the path to your Hello-Lucy folder is home/MagicMirror/modules/Hello-Lucy?
          Inside the Hello-Lucy folder is a node_modules folder?
            Also, please open a new terminal and type
            cat /proc/asound/cards and post the result here please.
            Mine looks like this:
            pop@e8300:~/MagicMirror$ cat /proc/asound/cards
             0 [PCH            ]: HDA-Intel - HDA Intel PCH
                                  HDA Intel PCH at 0xf7130000 irq 29
             1 [NVidia         ]: HDA-Intel - HDA NVidia
                                  HDA NVidia at 0xf7080000 irq 17
            • T Offline
              TheGeekfather @Mykle1
              @Mykle1
              Maybe a problem
              It seems all my modules are in
              modules/default/
              Mykle1M T 3 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @TheGeekfather
                @TheGeekfather
                Definitely a problem
                • T Offline
                  TheGeekfather @TheGeekfather
                  @TheGeekfather
                   0 [ALSA           ]: bcm2835_alsa - bcm2835 ALSA
                                        bcm2835 ALSA
                   1 [Device         ]: USB-Audio - USB Audio Device
                                        C-Media Electronics Inc. USB Audio Device at usb-0000:01:00.0-1.1, full speed
                    @TheGeekfather said in Hello-Lucy:
                    modules/default/
                    We went over this earlier, I think. Only the default MM modules go there. All other modules go on the root of the modules folder
                    • T Offline
                      @Mykle1
                      Other modules installed there are working but had to change paths for icons to work
                      Mykle1M cowboysdudeC T 3 Replies Last reply Reply Quote 0
                        I don’t even know how to reply to that. Modules belong in the modules folder
                        • cowboysdudeC Offline
                          cowboysdude Module Developer @TheGeekfather
                          @TheGeekfather The problem is when you try to change things you also are changing the way the mirror works and this will lead to issues…the kind you are having LOL.
                          Default modules are wired to work out of that directory - /modules/default
                          3rd party modules are wired to work out of the modules directory. /modules
                          Seems like a lot of extra work and if you miss something then you will have issues. So my suggestion is that if you get a module from github you do this:
                          in the MagicMirror/modules directory
                          git clone https://github.com/mykle1/Hello-Lucy.git
                          Then go to the dir you just cloned the repository in ie MagicMirror/modules/Hello-Lucy
                          [typically from there if a module has dependencies you’d run ‘npm install’… for Lucy you have to be in the MagicMirror/modules/Hello-Lucy/installers directory and you would run a bash command]
                          Put the module in your config and you’re off an running…
                          This will put your modules in the correct place to run without having to change the module itself… Where you are going to run into issues is when a developer hard codes something you can’t find…
                          It’s already happened and that creates issues that are VERY difficult to solve…
                          But I am glad you are trying to learn something and seem very enthusiastic about it :)
                          • T Offline
                            @TheGeekfather
                            I guess the best thing is to re-install all my modules in the correct folder. Is that the only way to get Lucy to work.
                            Thank you again for all your help
                            • T Offline
                              TheGeekfather @cowboysdude
                              @cowboysdude
                              OK, here is what I did
                              1. deleted Hello-Lucy folder from default directory
                              2. cloned hello-lucy in modules directory
                              3. cd installers and ran bash dependencies.sh
                              4. npm start
                              in modules/default directory In the defaultmodules.js file I added
                              var defaultModules = [
                              	"alert",
                              	"calendar",
                              	"clock",
                              	"compliments",
                              	"currentweather",
                              	"helloworld",
                              	"newsfeed",
                              	"weatherforecast",
                              	"updatenotification",
                              	"MMM-Swipe",
                              	"MMM-NHL",
                              	"MMM-BMW-DS",
                              	"modules/Hello-Lucy",
                              	"MMM-iFrame",
                              	"MMM-Astro",
                              lucy started and microphone icon no longer had “undefined” error but icon not flashing and commands like “show clock” or hide “clock” don’t seem to be working
                                @TheGeekfather Well in all honesty what you’re doing is just making a huge mess. You need to delete ALL the modules that don’t belong in the default folder. ANY changes you made to any files undo…
                                Install modules as they are intended and we can help you, other then that I have no answers for you.
                                • T Offline
                                  @cowboysdude
                                  I understand - and yes I will re-install
                                  One last question - should the mic icon flash when you speak?
                                  Again, THANK YOU for all your help :)
                                    @TheGeekfather Yes, green :)
                                    • T Offline
                                      @Mykle1
                                      Hi, you mentioned you were going to fix the install problem after noticing microphone not working with a fresh install.
                                      Any progress?
                                      Thank you for updates
                                        @TheGeekfather The mic is an easy fix if you’re using a pi…
                                        Open terminal and type in ‘arecord -l’ it will give you all the info on your mic… more than likely if your using a USB mic it will be most likely 1,0.
                                        In your config in Hello-Lucy in the ‘config’ section of Hello-Lucy you would put:
                                        "microphone: “1,0”,
                                        That’s it…pretty simple. Yes I realize simple if you know it LOL.
                                        • T Offline
                                          @cowboysdude
                                          :) Knowledge is Power - That is what I always told my students
                                          This is the mic I have
                                          **** List of CAPTURE Hardware Devices ****
                                          card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
                                            Subdevices: 1/1
                                            Subdevice #0: subdevice #0
                                            @TheGeekfather I went to school to be a teacher but never taught… I’m not real good with touchy feeling kinda things I tend to be more direct and that’s not a good thing in Schools LOL
                                            Yes you could add:
                                              disabled: false,
                                              module: "Hello-Lucy",
                                               keyword: 'HELLO LUCY',
                                               microphone: "1,0",
                                               timeout: 15,                        // timeout listening for a command/sentence
                                               defaultOnStartup: 'Hello-Lucy',
                                               standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                                               sounds: [ ],
                                               confirmationSound: "ding.mp3",
                                                startHideAll: true,                 // if true, all modules start as hidden
                                              pageOneModules: ["Hello-Lucy", "MMM-Insults"],    /
                                              pageTwoModules: ["MMM-BMW-DS", "MMM-Events"],     // modules to show on page two
                                              pageThreeModules: ["MMM-Lunartic"],               // modules to show on page three
                                              pageFourModules: ["MMM-PC-Stats"],                // modules to show on page four
                                              pageFiveModules: [],                              // modules to show on page five
                                              pageSixModules: [],                               // modules to show on page six
                                              pageSevenModules: [],                             // modules to show on page seven
                                              pageEightModules: [],                             // modules to show on page eight
                                              pageNineModules: [],                              // modules to show on page nine
                                              pageTenModules: []                                // modules to show on page ten
                                            That is an example config… the ONLY thing you need to change is the modules listed on the ‘pages’… it should work on a pi with a usb mic… Please note there will be about a 4 to 5 second delay… the pi is small and this is heavy weight it’s lifting.
                                            As soon as @Mykle1 tests this on a pi4 we’ll let everyone know :)
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
