    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 763.0k Views 27 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @TheGeekfather
      @TheGeekfather said in Hello-Lucy:
      Other modules installed there are working but had to change paths for icons to work
      I don’t even know how to reply to that. Modules belong in the modules folder
      • cowboysdudeC
        cowboysdude Module Developer @TheGeekfather
        @TheGeekfather The problem is when you try to change things you also are changing the way the mirror works and this will lead to issues…the kind you are having LOL.
        Default modules are wired to work out of that directory - /modules/default
        3rd party modules are wired to work out of the modules directory. /modules
        Seems like a lot of extra work and if you miss something then you will have issues. So my suggestion is that if you get a module from github you do this:
        in the MagicMirror/modules directory
        git clone https://github.com/mykle1/Hello-Lucy.git
        Then go to the dir you just cloned the repository in ie MagicMirror/modules/Hello-Lucy
        [typically from there if a module has dependencies you’d run ‘npm install’… for Lucy you have to be in the MagicMirror/modules/Hello-Lucy/installers directory and you would run a bash command]
        Put the module in your config and you’re off an running…
        This will put your modules in the correct place to run without having to change the module itself… Where you are going to run into issues is when a developer hard codes something you can’t find…
        It’s already happened and that creates issues that are VERY difficult to solve…
        But I am glad you are trying to learn something and seem very enthusiastic about it :)
        T 1 Reply Last reply
        • T
          TheGeekfather @TheGeekfather
          @TheGeekfather
          I guess the best thing is to re-install all my modules in the correct folder. Is that the only way to get Lucy to work.
          Thank you again for all your help
          • T
            TheGeekfather @cowboysdude
            @cowboysdude
            OK, here is what I did
            1. deleted Hello-Lucy folder from default directory
            2. cloned hello-lucy in modules directory
            3. cd installers and ran bash dependencies.sh
            4. npm start
            in modules/default directory In the defaultmodules.js file I added
            var defaultModules = [
            	"alert",
            	"calendar",
            	"clock",
            	"compliments",
            	"currentweather",
            	"helloworld",
            	"newsfeed",
            	"weatherforecast",
            	"updatenotification",
            	"MMM-Swipe",
            	"MMM-NHL",
            	"MMM-BMW-DS",
            	"modules/Hello-Lucy",
            	"MMM-iFrame",
            	"MMM-Astro",
            lucy started and microphone icon no longer had “undefined” error but icon not flashing and commands like “show clock” or hide “clock” don’t seem to be working
            • cowboysdudeC
              @TheGeekfather Well in all honesty what you’re doing is just making a huge mess. You need to delete ALL the modules that don’t belong in the default folder. ANY changes you made to any files undo…
              Install modules as they are intended and we can help you, other then that I have no answers for you.
              • T
                @cowboysdude
                I understand - and yes I will re-install
                One last question - should the mic icon flash when you speak?
                Again, THANK YOU for all your help :)
                • cowboysdudeC
                  @TheGeekfather Yes, green :)
                  • T
                    TheGeekfather @Mykle1
                    @Mykle1
                    Hi, you mentioned you were going to fix the install problem after noticing microphone not working with a fresh install.
                    Any progress?
                    Thank you for updates
                    • cowboysdudeC
                      @TheGeekfather The mic is an easy fix if you’re using a pi…
                      Open terminal and type in ‘arecord -l’ it will give you all the info on your mic… more than likely if your using a USB mic it will be most likely 1,0.
                      In your config in Hello-Lucy in the ‘config’ section of Hello-Lucy you would put:
                      "microphone: “1,0”,
                      That’s it…pretty simple. Yes I realize simple if you know it LOL.
                      • T
                        @cowboysdude
                        :) Knowledge is Power - That is what I always told my students
                        This is the mic I have
                        **** List of CAPTURE Hardware Devices ****
                        card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
                          Subdevices: 1/1
                          Subdevice #0: subdevice #0
                        • cowboysdudeC
                          @TheGeekfather I went to school to be a teacher but never taught… I’m not real good with touchy feeling kinda things I tend to be more direct and that’s not a good thing in Schools LOL
                          Yes you could add:
                            disabled: false,
                            module: "Hello-Lucy",
                             keyword: 'HELLO LUCY',
                             microphone: "1,0",
                             timeout: 15,                        // timeout listening for a command/sentence
                             defaultOnStartup: 'Hello-Lucy',
                             standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                             sounds: [ ],
                             confirmationSound: "ding.mp3",
                              startHideAll: true,                 // if true, all modules start as hidden
                            pageOneModules: ["Hello-Lucy", "MMM-Insults"],    /
                            pageTwoModules: ["MMM-BMW-DS", "MMM-Events"],     // modules to show on page two
                            pageThreeModules: ["MMM-Lunartic"],               // modules to show on page three
                            pageFourModules: ["MMM-PC-Stats"],                // modules to show on page four
                            pageFiveModules: [],                              // modules to show on page five
                            pageSixModules: [],                               // modules to show on page six
                            pageSevenModules: [],                             // modules to show on page seven
                            pageEightModules: [],                             // modules to show on page eight
                            pageNineModules: [],                              // modules to show on page nine
                            pageTenModules: []                                // modules to show on page ten
                          That is an example config… the ONLY thing you need to change is the modules listed on the ‘pages’… it should work on a pi with a usb mic… Please note there will be about a 4 to 5 second delay… the pi is small and this is heavy weight it’s lifting.
                          As soon as @Mykle1 tests this on a pi4 we’ll let everyone know :)
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            @cowboysdude
                            As you know, the installer was not at fault. The automatic identification of the microphone was not happening, at least on the Pi. Thanks for stepping in while I was busy troubleshooting and thanks for testing
                            • cowboysdudeC
                              @Mykle1 Who are you and what are you doing here? LOL
                              • Mykle1M
                                @cowboysdude
                                Uhh, I was hoping you’d tell me. :-)
                                • cowboysdudeC
                                  @TheGeekfather If you have any other questions I’m sure @Mykle1 will be happy to help you :) I’m not on that often… the last couple days I’ve been on more then I have been in 3 months LOL
                                  • T
                                    @Mykle1
                                    Thank you for all your help. Started fresh install - put modules in correct folder
                                    added "microphone: “1,0”,
                                    AND
                                    Hello-Lucy works GREAT :)
                                    Reply Quote 2
                                    • Mykle1M
                                      @TheGeekfather
                                      Well ok then! You’re happy? I’m happy! Lucy’s happy! :-)
                                      Seriously, I’m glad you’re up and running and I’m glad you’re pleased. :thumbsup:
                                      Now, can you do something simple for me? Can you please tell me:
                                      1. Your hardware ( Pi3? 4? whatever)
                                      2. Your microphone (including if it’s USB or analog)
                                      3. Your OS (if not using a Pi?)
                                      4. Your response time from the time you issue a command until Lucy responds or you hear the confirmation sound. Instantly? 1 second? 3? 5?
                                      • cowboysdudeC
                                        I love it when a plan comes together…
                                        alt text
                                        • T
                                          @Mykle1
                                          Happy :)
                                          1. Pi 4
                                          2. Mic is Analog plugged in to a sound card (came with mic - Zax Sound)
                                          3. Buster
                                          4. 2-3 seconds
                                          Just a small note - Sometimes I have to unplug sound card and plug back in - Works with either a speaker plugged in to card or using HDMI sound.
                                          • cowboysdudeC
                                            @TheGeekfather Try using a Omnidirectional mic… like this :
                                            https://www.walmart.com/ip/Stereo-Omnidirectional-Condenser-Microphone-Mic-3-5mm-Connector-for-Meeting-Business-Conference-Desktop-Computer/392379431
                                            Can’t say it will solve the delay…the Pi’s seem to have that delay…
                                            alt text
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
