    Adding Modules... Please Please advise
    25 Posts 6 Posters 15.0k Views 4 Watching
    • yawnsY Offline
      yawns Moderator @Guest
      Not sure if this is the problem but the position for module WorldTides should be top_right and not top-right
      That btw is my fault, a stupid typo in the readme :(
        A Former User
        ah, cool thanks, hopefully that’s all the problem is, :)
          A Former User
          :( nope, i updated yet still have a blank screen :(
          var config = {
          port: 8080,
          language: 'en',
          timeFormat: 12,
          units: 'metric',
          		module: 'alert',
          		module: 'clock',
          		position: 'top_left'
          		module: 'calendar',
          		header: 'British Holidays Bitch',
          		position: 'top_left',
          					symbol: 'calendar-check-o ',
          					url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
          		module: 'compliments',
          		position: 'lower_third'
          		module: 'currentweather',
          		position: 'top_right',
          			locationID: '1151254',  //ID from http://www.openweathermap.org
          			appid: '297ccc98662ac6f508ac9e47c549a716'
          		module: 'weatherforecast',
          		header: 'Weather huh!',
          		module: 'newsfeed',
          		position: 'bottom_bar',
          			feeds: [
          					title: "Bloomberg Baby!",
          					url: "https://www.bloomberg.com/feeds/podcasts/etf_report.xml"
          			showSourceTitle: true,
          			showPublishDate: true
          		module: 'MMM-WorldTides',
          		longitude: '7.880', //longitude and latitude need to be written with . instead of ,
          		latitude: '98.392',
          		appid: '5d3d65d6-f4a6-45d4-ab44-13e4eab4b421' //appid needs to be requested from worldtides.info
          if (typeof module !== ‘undefined’) {module.exports = config;}
            A Former User
            Is it due to not pasting the code like this
            module: ‘MMM-WorldTides’,
            position: ‘top-right’,
            longitude: ‘’, //longitude and latitude need to be written with . instead of ,
            latitude: ‘’,
            appid: ‘’ //appid needs to be requested from worldtides.info
            • yawnsY Offline
              yawns Moderator
              I need to check on my machine this evening, when I am at home
                A Former User
                Thanks, much appreciated :)
                  A Former User
                  var config = {
                  port: 8080,
                  language: 'en',
                  timeFormat: 12,
                  units: 'metric',
                  		module: 'alert',
                  		module: 'clock',
                  		module: 'calendar',
                  		position: 'lower_third',
                  		module: 'newsfeed',
                  			feeds: [
                  		latitude: '98.392',
                  • AlvingerA Offline
                    Alvinger
                    I think the error is that the line
                    		module: 'alert',
                    has a trailing comma, it should read
                    		module: 'alert'
                      A Former User
                      Thanks will check now.
                        A Former User
                        Strange these modules have not been pre- code checked before uploading to GH…?
                        I’ve updated my script as been adding other modules, and getting errors or just “loading”…
                        have added /// pre module lines to highlight the ones that i am having issues with …
                        var config = {
                        port: 8080,
                        language: 'en',
                        timeFormat: 12,
                        units: 'metric',
                        		module: 'alert'
                        		module: 'clock',
                        		module: 'calendar',
                        		header: 'British Holidays',
                        		module: 'newsfeed',
                        			feeds: [
                        					title: "Bloomberg",
                        		module: 'newsfeed',
                        			feeds: [
                        					tittle: "BBC Sci-Tech",
                        					url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk"
                        		module: 'MMM-Instagram',
                            	access_token: 'e897699215d0464f9aac278e4fdc25ba',
                            	count: 20,
                            	min_timestamp: 0,
                            	animationSpeed: 2500,
                            	updateInterval: 12500
                        /// module: ‘MMM-Carousel’,
                        /// config: {
                        /// // See below for configurable options
                        /// module: ‘camera’,
                        /// position: ‘top_center’,
                        /// config: selfieInterval: 3, // Time interval in seconds before the photo will be taken.
                        /// emailConfig: {
                        /// service: ‘gmail’, // Email provider to use to send email with a photo.
                        /// auth: {
                        /// user: ‘xxxx@xxx.com’, // Your email account
                        /// pass: ‘’ // Your password for email account
                        /// module: ‘voicecontrol’,
                        /// position: ‘bottom_left’,
                        /// config: {
                        /// models: [
                        /// keyword: “Show Camera”,
                        /// description: “Say ‘Show Camera’ to display camera”,
                        /// file: “showCamera.pmdl”,
                        /// message: “SHOW_CAMERA”
                        /// keyword: “Hide Camera”,
                        /// description: “Say ‘Hide Camera’ to hide camera”,
                        /// file: “hideCamera.pmdl”,
                        /// message: “HIDE_CAMERA”
                        /// keyword: “Selfie”,
                        /// description: “Say ‘Selfie’ when camera is visible”,
                        /// file: “selfie.pmdl”,
                        /// message: “SELFIE”
