    Adding Modules... Please Please advise
    25 Posts 6 Posters 16.9k Views 4 Watching
    • Y
      yawns Moderator @Guest
      Not sure if this is the problem but the position for module WorldTides should be top_right and not top-right
      That btw is my fault, a stupid typo in the readme :(
        A Former User
        ah, cool thanks, hopefully that’s all the problem is, :)
          A Former User
          :( nope, i updated yet still have a blank screen :(
          var config = {
          port: 8080,
          language: 'en',
          timeFormat: 12,
          units: 'metric',
          		module: 'alert',
          		module: 'clock',
          		position: 'top_left'
          		module: 'calendar',
          		header: 'British Holidays Bitch',
          		position: 'top_left',
          					symbol: 'calendar-check-o ',
          					url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
          		module: 'compliments',
          		position: 'lower_third'
          		module: 'currentweather',
          		position: 'top_right',
          			locationID: '1151254',  //ID from http://www.openweathermap.org
          			appid: '297ccc98662ac6f508ac9e47c549a716'
          		module: 'weatherforecast',
          		header: 'Weather huh!',
          		module: 'newsfeed',
          		position: 'bottom_bar',
          			feeds: [
          					title: "Bloomberg Baby!",
          					url: "https://www.bloomberg.com/feeds/podcasts/etf_report.xml"
          			showSourceTitle: true,
          			showPublishDate: true
          		module: 'MMM-WorldTides',
          		longitude: '7.880', //longitude and latitude need to be written with . instead of ,
          		latitude: '98.392',
          		appid: '5d3d65d6-f4a6-45d4-ab44-13e4eab4b421' //appid needs to be requested from worldtides.info
          if (typeof module !== ‘undefined’) {module.exports = config;}
            A Former User
            Is it due to not pasting the code like this
            module: ‘MMM-WorldTides’,
            position: ‘top-right’,
            longitude: ‘’, //longitude and latitude need to be written with . instead of ,
            latitude: ‘’,
            appid: ‘’ //appid needs to be requested from worldtides.info
            • Y
              yawns Moderator
              I need to check on my machine this evening, when I am at home
                A Former User
                Thanks, much appreciated :)
                  A Former User
                  var config = {
                  port: 8080,
                  language: 'en',
                  timeFormat: 12,
                  units: 'metric',
                  		module: 'alert',
                  		module: 'clock',
                  		module: 'calendar',
                  		position: 'lower_third',
                  		module: 'newsfeed',
                  			feeds: [
                  		latitude: '98.392',
                  • A
                    Alvinger
                    I think the error is that the line
                    		module: 'alert',
                    has a trailing comma, it should read
                    		module: 'alert'
                      A Former User
                      Thanks will check now.
                        A Former User
                        Strange these modules have not been pre- code checked before uploading to GH…?
                        I’ve updated my script as been adding other modules, and getting errors or just “loading”…
                        have added /// pre module lines to highlight the ones that i am having issues with …
                        var config = {
                        port: 8080,
                        language: 'en',
                        timeFormat: 12,
                        units: 'metric',
                        		module: 'alert'
                        		module: 'clock',
                        		module: 'calendar',
                        		header: 'British Holidays',
                        		module: 'newsfeed',
                        			feeds: [
                        					title: "Bloomberg",
                        		module: 'newsfeed',
                        			feeds: [
                        					tittle: "BBC Sci-Tech",
                        					url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk"
                        		module: 'MMM-Instagram',
                            	access_token: 'e897699215d0464f9aac278e4fdc25ba',
                            	count: 20,
                            	min_timestamp: 0,
                            	animationSpeed: 2500,
                            	updateInterval: 12500
                        /// module: ‘MMM-Carousel’,
                        /// config: {
                        /// // See below for configurable options
                        /// module: ‘camera’,
                        /// position: ‘top_center’,
                        /// config: selfieInterval: 3, // Time interval in seconds before the photo will be taken.
                        /// emailConfig: {
                        /// service: ‘gmail’, // Email provider to use to send email with a photo.
                        /// auth: {
                        /// user: ‘xxxx@xxx.com’, // Your email account
                        /// pass: ‘’ // Your password for email account
                        /// module: ‘voicecontrol’,
                        /// position: ‘bottom_left’,
                        /// config: {
                        /// models: [
                        /// keyword: “Show Camera”,
                        /// description: “Say ‘Show Camera’ to display camera”,
                        /// file: “showCamera.pmdl”,
                        /// message: “SHOW_CAMERA”
                        /// keyword: “Hide Camera”,
                        /// description: “Say ‘Hide Camera’ to hide camera”,
                        /// file: “hideCamera.pmdl”,
                        /// message: “HIDE_CAMERA”
                        /// keyword: “Selfie”,
                        /// description: “Say ‘Selfie’ when camera is visible”,
                        /// file: “selfie.pmdl”,
                        /// message: “SELFIE”
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @Guest
                          @wjdw87 you’re missing curly braces for config in the camera module
                            A Former User
                            Curley braces where sorry?
                            • K
                              KirAsh4 Moderator
                              Guys, use proper formatting for your code! (edited to add: when posting on the forums - not in your config files)
                              Block code is done with ```on a line by itself, then your code, and closed with another ``` on a line by itself again. This is not the same as an apostrophe! It’s called a 'back tick' or 'accent grave' and can be found to the left of the numerical number 1 at the top on a US keyboard. Please use it! It makes reading your config files a lot easier.
                              On non-US keyboards, um, its location will vary. You can also press and hold your ALT key, and using the numerical pad, enter 9 followed by 6, then let go of the ALT key. Repeat that three times and you get the three back ticks necessary.
                                A Former User
                                link text My config
                                  A Former User
                                  /// as used instead of ``` as they crash my system (the modules) just blank screen, will be removed when the issue is resolved.
                                  B 1 Reply Last reply
                                    bhepler Module Developer @Guest
                                    @wjdw87 Why do you have the newsfeed module specified twice? You have:
                                    	module: 'newsfeed',
                                    		feeds: [
                                    	module: 'newsfeed',
                                    		feeds: [
                                    Would it not make more sense to just put both feeds in the feed array?
                                        module: 'newsfeed',
                                            feeds: [
                                                    title: "BBC Sci-Tech",
                                    (Also, you misspelled “title” in your second newsfeed. You have an extra “t”.)
                                    ? 1 Reply Last reply
                                      A Former User @bhepler
                                      @bhepler said in Adding Modules... Please Please advise:
                                      	module: 'newsfeed',
                                      		feeds: [
                                      	module: 'newsfeed',
                                      		feeds: [
                                          module: 'newsfeed',
                                              feeds: [
                                      you can add them to the same array?
                                        @wjdw87 Indeed, you can. The documentation for the newsfeed module gives a simple example.
                                          A Former User
                                          Ah cool, updated that, but still have issues around the modules i’ve /// out
                                          much appreciated though!
                                            @wjdw87 Okay, I finally had some time so I looked at the file you linked.
                                            As @strawberry-3-141 said, you have an issue on line 100, part of the configuration of the camera module. You have: config: selfieInterval: 3, // Time interval in seconds before the photo will be taken.
                                            You need to follow the config key with a JSON object, designated by curly braces. So the camera module section should look like so:
                                            	module: 'camera',
                                            	position: 'top_center',
                                            		selfieInterval: 3
                                            		emailConfig: {
                                            			service: 'gmail',
                                            			auth: {
                                            				user: '<xxx@xxx.com>',
                                            				pass: '<xxx>'
                                            It doesn’t help that the config section is wrong in the README.MD in the camera module. I’ll see if I can’t get a PR to fix that.
