    Adding Modules... Please Please advise
    25 Posts 6 Posters 14.7k Views 4 Watching
      A Former User
      Ok, cant find anything in the Readme, all git repos just state add to the modules…
      Can someone please share their config file with multiple mods past the default, so i can see where i am going wrong…
      • yawnsY Offline
        yawns Moderator
        Just post your config.js file content and let others see what might be missing.
        Please tab indent your file content before posting or use proper markup so the code is readable
          A Former User
          var config = {
          port: 8080,
          language: 'en',
          timeFormat: 12,
          units: 'metric',
          		module: 'alert',
          		module: 'clock',
          		position: 'top_left'
          		module: 'calendar',
          		header: 'British Holidays',
          		position: 'top_left',
          					symbol: 'calendar-check-o ',
          					url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
          		module: 'compliments',
          		position: 'lower_third'
          		module: 'currentweather',
          		position: 'top_right',
          			locationID: '1151254',  //ID from http://www.openweathermap.org
          			appid: '297ccc98662ac6f508ac9e47c549a716'
          		module: 'weatherforecast',
          		header: 'Weather huh!',
          		module: 'newsfeed',
          		position: 'bottom_bar',
          			feeds: [
          					title: "Bloomberg!",
          					url: "https://www.bloomberg.com/feeds/podcasts/etf_report.xml"
          			showSourceTitle: true,
          			showPublishDate: true
          		module: 'MMM-WorldTides',
          		position: 'top-right',
          		longitude: '7.880', //longitude and latitude need to be written with . instead of ,
          		latitude: '98.392',
          		appid: '5d3d65d6-f4a6-45d4-ab44-13e4eab4b421' //appid needs to be requested from worldtides.info
          Just getting a black screen…
          • yawnsY Offline
            yawns Moderator @Guest
            Not sure if this is the problem but the position for module WorldTides should be top_right and not top-right
            That btw is my fault, a stupid typo in the readme :(
              A Former User
              ah, cool thanks, hopefully that’s all the problem is, :)
                A Former User
                :( nope, i updated yet still have a blank screen :(
                var config = {
                port: 8080,
                language: 'en',
                timeFormat: 12,
                units: 'metric',
                		module: 'alert',
                		module: 'clock',
                		module: 'calendar',
                		header: 'British Holidays Bitch',
                		module: 'newsfeed',
                			feeds: [
                					title: "Bloomberg Baby!",
                		latitude: '98.392',
                if (typeof module !== ‘undefined’) {module.exports = config;}
                  A Former User
                  Is it due to not pasting the code like this
                  module: ‘MMM-WorldTides’,
                  position: ‘top-right’,
                  longitude: ‘’, //longitude and latitude need to be written with . instead of ,
                  latitude: ‘’,
                  appid: ‘’ //appid needs to be requested from worldtides.info
                  • yawnsY Offline
                    yawns Moderator
                    I need to check on my machine this evening, when I am at home
                      A Former User
                      Thanks, much appreciated :)
                        A Former User
                        var config = {
                        port: 8080,
                        language: 'en',
                        timeFormat: 12,
                        units: 'metric',
                        		module: 'alert',
                        		module: 'clock',
                        		module: 'calendar',
                        		position: 'lower_third',
                        		module: 'newsfeed',
                        			feeds: [
                        		latitude: '98.392',
