Adding Modules... Please Please advise
25 Posts 6 Posters 14.6k Views 4 Watching
    A Former User
    Ok, cant find anything in the Readme, all git repos just state add to the modules…
    Can someone please share their config file with multiple mods past the default, so i can see where i am going wrong…
    • Y Offline
      yawns Moderator
      Just post your config.js file content and let others see what might be missing.
      Please tab indent your file content before posting or use proper markup so the code is readable
        A Former User
        var config = {
        port: 8080,
        language: 'en',
        timeFormat: 12,
        units: 'metric',
        		module: 'alert',
        		module: 'clock',
        		position: 'top_left'
        		module: 'calendar',
        		header: 'British Holidays',
        		position: 'top_left',
        					symbol: 'calendar-check-o ',
        					url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
        		module: 'compliments',
        		position: 'lower_third'
        		module: 'currentweather',
        		position: 'top_right',
        			locationID: '1151254',  //ID from http://www.openweathermap.org
        			appid: '297ccc98662ac6f508ac9e47c549a716'
        		module: 'weatherforecast',
        		header: 'Weather huh!',
        		module: 'newsfeed',
        		position: 'bottom_bar',
        			feeds: [
        					title: "Bloomberg!",
        					url: "https://www.bloomberg.com/feeds/podcasts/etf_report.xml"
        			showSourceTitle: true,
        			showPublishDate: true
        		module: 'MMM-WorldTides',
        		position: 'top-right',
        		longitude: '7.880', //longitude and latitude need to be written with . instead of ,
        		latitude: '98.392',
        		appid: '5d3d65d6-f4a6-45d4-ab44-13e4eab4b421' //appid needs to be requested from worldtides.info
        Just getting a black screen…
        Y 1 Reply Last reply Oct 24, 2016, 12:12 PM Reply Quote 0
        • Y Offline
          yawns Moderator @Guest
          Not sure if this is the problem but the position for module WorldTides should be top_right and not top-right
          That btw is my fault, a stupid typo in the readme :(
            A Former User
            ah, cool thanks, hopefully that’s all the problem is, :)
              A Former User
              :( nope, i updated yet still have a blank screen :(
              var config = {
              port: 8080,
              language: 'en',
              timeFormat: 12,
              units: 'metric',
              		module: 'alert',
              		module: 'clock',
              		module: 'calendar',
              		header: 'British Holidays Bitch',
              		module: 'newsfeed',
              			feeds: [
              					title: "Bloomberg Baby!",
              		latitude: '98.392',
              if (typeof module !== ‘undefined’) {module.exports = config;}
                A Former User
                Is it due to not pasting the code like this
                module: ‘MMM-WorldTides’,
                position: ‘top-right’,
                longitude: ‘’, //longitude and latitude need to be written with . instead of ,
                latitude: ‘’,
                appid: ‘’ //appid needs to be requested from worldtides.info
                • Y Offline
                  yawns Moderator
                  I need to check on my machine this evening, when I am at home
                    A Former User
                    Thanks, much appreciated :)
                      A Former User
                      var config = {
                      port: 8080,
                      language: 'en',
                      timeFormat: 12,
                      units: 'metric',
                      		module: 'alert',
                      		module: 'clock',
                      		module: 'calendar',
                      		position: 'lower_third',
                      		module: 'newsfeed',
                      			feeds: [
                      		latitude: '98.392',
                      1 / 3
