    Adding Modules... Please Please advise
    25 Posts 6 Posters 16.5k Views 4 Watching
      A Former User
      Ok, cant find anything in the Readme, all git repos just state add to the modules…
      Can someone please share their config file with multiple mods past the default, so i can see where i am going wrong…
      • Y Offline
        yawns Moderator
        Just post your config.js file content and let others see what might be missing.
        Please tab indent your file content before posting or use proper markup so the code is readable
          A Former User
          var config = {
          port: 8080,
          language: 'en',
          timeFormat: 12,
          units: 'metric',
          		module: 'alert',
          		module: 'clock',
          		position: 'top_left'
          		module: 'calendar',
          		header: 'British Holidays',
          		position: 'top_left',
          					symbol: 'calendar-check-o ',
          					url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
          		module: 'compliments',
          		position: 'lower_third'
          		module: 'currentweather',
          		position: 'top_right',
          			locationID: '1151254',  //ID from http://www.openweathermap.org
          			appid: '297ccc98662ac6f508ac9e47c549a716'
          		module: 'weatherforecast',
          		header: 'Weather huh!',
          		module: 'newsfeed',
          		position: 'bottom_bar',
          			feeds: [
          					title: "Bloomberg!",
          					url: "https://www.bloomberg.com/feeds/podcasts/etf_report.xml"
          			showSourceTitle: true,
          			showPublishDate: true
          		module: 'MMM-WorldTides',
          		position: 'top-right',
          		longitude: '7.880', //longitude and latitude need to be written with . instead of ,
          		latitude: '98.392',
          		appid: '5d3d65d6-f4a6-45d4-ab44-13e4eab4b421' //appid needs to be requested from worldtides.info
          Just getting a black screen…
          • Y Offline
            yawns Moderator @Guest
            Not sure if this is the problem but the position for module WorldTides should be top_right and not top-right
            That btw is my fault, a stupid typo in the readme :(
              A Former User
              ah, cool thanks, hopefully that’s all the problem is, :)
                A Former User
                :( nope, i updated yet still have a blank screen :(
                var config = {
                port: 8080,
                language: 'en',
                timeFormat: 12,
                units: 'metric',
                		module: 'alert',
                		module: 'clock',
                		module: 'calendar',
                		header: 'British Holidays Bitch',
                		module: 'newsfeed',
                			feeds: [
                					title: "Bloomberg Baby!",
                		latitude: '98.392',
                if (typeof module !== ‘undefined’) {module.exports = config;}
                  A Former User
                  Is it due to not pasting the code like this
                  module: ‘MMM-WorldTides’,
                  position: ‘top-right’,
                  longitude: ‘’, //longitude and latitude need to be written with . instead of ,
                  latitude: ‘’,
                  appid: ‘’ //appid needs to be requested from worldtides.info
                  • Y Offline
                    yawns Moderator
                    I need to check on my machine this evening, when I am at home
                      A Former User
                      Thanks, much appreciated :)
                        A Former User
                        var config = {
                        port: 8080,
                        language: 'en',
                        timeFormat: 12,
                        units: 'metric',
                        		module: 'alert',
                        		module: 'clock',
                        		module: 'calendar',
                        		position: 'lower_third',
                        		module: 'newsfeed',
                        			feeds: [
                        		latitude: '98.392',
                          Alvinger
                          I think the error is that the line
                          		module: 'alert',
                          has a trailing comma, it should read
                          		module: 'alert'
                            A Former User
                            Thanks will check now.
                              A Former User
                              Strange these modules have not been pre- code checked before uploading to GH…?
                              I’ve updated my script as been adding other modules, and getting errors or just “loading”…
                              have added /// pre module lines to highlight the ones that i am having issues with …
                              var config = {
                              port: 8080,
                              language: 'en',
                              timeFormat: 12,
                              units: 'metric',
                              		module: 'alert'
                              		module: 'clock',
                              		module: 'calendar',
                              		module: 'newsfeed',
                              			feeds: [
                              					title: "Bloomberg",
                              		module: 'newsfeed',
                              			feeds: [
                              					tittle: "BBC Sci-Tech",
                              					url: "http://feeds.bbci.co.uk/news/video_and_audio/technology/rss.xml?edition=uk"
                              		module: 'MMM-Instagram',
                                  	access_token: 'e897699215d0464f9aac278e4fdc25ba',
                                  	count: 20,
                                  	min_timestamp: 0,
                                  	animationSpeed: 2500,
                                  	updateInterval: 12500
                              /// module: ‘MMM-Carousel’,
                              /// config: {
                              /// // See below for configurable options
                              /// module: ‘camera’,
                              /// position: ‘top_center’,
                              /// config: selfieInterval: 3, // Time interval in seconds before the photo will be taken.
                              /// emailConfig: {
                              /// service: ‘gmail’, // Email provider to use to send email with a photo.
                              /// auth: {
                              /// user: ‘xxxx@xxx.com’, // Your email account
                              /// pass: ‘’ // Your password for email account
                              /// module: ‘voicecontrol’,
                              /// position: ‘bottom_left’,
                              /// config: {
                              /// models: [
                              /// keyword: “Show Camera”,
                              /// description: “Say ‘Show Camera’ to display camera”,
                              /// file: “showCamera.pmdl”,
                              /// message: “SHOW_CAMERA”
                              /// keyword: “Hide Camera”,
                              /// description: “Say ‘Hide Camera’ to hide camera”,
                              /// file: “hideCamera.pmdl”,
                              /// message: “HIDE_CAMERA”
                              /// keyword: “Selfie”,
                              /// description: “Say ‘Selfie’ when camera is visible”,
                              /// file: “selfie.pmdl”,
                              /// message: “SELFIE”
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @Guest
                                @wjdw87 you’re missing curly braces for config in the camera module
                                  A Former User
                                  Curley braces where sorry?
                                  • K Offline
                                    KirAsh4 Moderator
                                    Guys, use proper formatting for your code! (edited to add: when posting on the forums - not in your config files)
                                    Block code is done with ```on a line by itself, then your code, and closed with another ``` on a line by itself again. This is not the same as an apostrophe! It’s called a 'back tick' or 'accent grave' and can be found to the left of the numerical number 1 at the top on a US keyboard. Please use it! It makes reading your config files a lot easier.
                                    On non-US keyboards, um, its location will vary. You can also press and hold your ALT key, and using the numerical pad, enter 9 followed by 6, then let go of the ALT key. Repeat that three times and you get the three back ticks necessary.
                                      A Former User
                                      link text My config
                                        A Former User
                                        /// as used instead of ``` as they crash my system (the modules) just blank screen, will be removed when the issue is resolved.
                                          bhepler Module Developer @Guest
                                          @wjdw87 Why do you have the newsfeed module specified twice? You have:
                                          	module: 'newsfeed',
                                          		feeds: [
                                          	module: 'newsfeed',
                                          		feeds: [
                                          Would it not make more sense to just put both feeds in the feed array?
                                              module: 'newsfeed',
                                                  feeds: [
                                                          title: "BBC Sci-Tech",
                                          (Also, you misspelled “title” in your second newsfeed. You have an extra “t”.)
                                            A Former User @bhepler
                                            @bhepler said in Adding Modules... Please Please advise:
                                            	module: 'newsfeed',
                                            		feeds: [
                                            	module: 'newsfeed',
                                            		feeds: [
                                                module: 'newsfeed',
                                                    feeds: [
                                            you can add them to the same array?
