    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 120.7k Views 27 Watching
    • K Offline
      kapsolas Module Developer
      I have not looked into autoresizing an image. It is on my list to get to when I have some time.
      The image at this point is not being resized, I just take it and display it as it comes from instagram.
      Videos will auto play when I get to them as well.
      Thanks!
      • Y Offline
        yo-less Module Developer
        @dr0pb0x , @kapsolas I had a quick look at your code (Not a fan of the bit.ly link) and if you go about displaying the Instagram image this way:
        	var imageWrapper = document.createElement("img");
        	imageWrapper.src = tempimpage.photolink;
        	imageWrapper.style.maxWidth = this.config.instaMaxWidth;
        	imageWrapper.style.maxHeight = this.config.instaMaxHeight;
        	imageDisplay.appendChild(imageWrapper);
        you should be able to specify two parameters instaMaxWidth and instaMaxHeight that the user can change in their config.file so the beginning of your MMM-Instagram.js file would look like this:
            defaults: {
                format: 'json',
                lang: 'en-us',
                animationSpeed: 1000,
                updateInterval: 60000, // 10 minutes
                access_token: '',
                count: 200,
                min_timestamp: 0,
                loadingText: 'Loading...',
                instaMaxWidth: '100%',
                instaMaxHeight: '100%'
        Now, any user of your module could define their own maximum image width and height, either by specifying an absolute figure like ‘300px’ or in relative terms using ‘20%’ or the like. I’ve created a pull request, but I suggest you test my code first as I don’t have an Instagram account or Instagram API key to test it.
        You can use my fork to do so: https://github.com/yo-less/MMM-Instagram
        D J 2 Replies Last reply Reply Quote 0
          dr0pb0x @yo-less
          @yo-less unfortunately this didn’t work :( I even tried setting it to 1px/1% just to make sure but the images didnt change in size
          • Y Offline
            yo-less Module Developer @dr0pb0x
            @dr0pb0x Have you tried using my forked version here:
            • Y Offline
              @dr0pb0x I’ve tried it with my forked version after changing the module to simply retrieve any picture from the internet. It’s working fine.
              The only limitation is that you can’t set the MaxHeight in relative terms (percentages), other than that, it works as intended as far as I can tell without actually using the API.
                dr0pb0x @yo-less
                @yo-less I just had a chance to try it out and it still doesn’t work for me. Could it possibly be Instagram’s API?
                http://stackoverflow.com/questions/21394100/what-are-the-different-image-size-formats-available-via-instagram-api
                  Diicken
                  Is there anyway to display images from my home server? And do someone have an idea how I should write the code?
                  • Y Offline
                    @dr0pb0x Anything is possible, but I doubt it. Please have @kapsolas help you with this, as I don’t have any direct way of testing it. As far as I’m concerned my code adjustments should work.
                    • MichMichM Offline
                      MichMich
                      Awesome work! My SO is very pleased with this idea. You might want to add a screenshot to the repo.
                        A Former User
                        Just getting “Loading…”
                        • cowboysdudeC Offline
                            A Former User @cowboysdude
                            @cowboysdude said in MMM-Instagram - Pull and animate photos from Instagram feed:
                            @kapsolas
                            Some of us are having issues here… little help please.
                            Installed per instructions with NPM Install and it isn’t working.
                            That’s all mine says too… “Loading…”
                            apparently this is an unsupported module… delete.
                            • K Offline
                              I just started up my mirror again and the instagram module loaded up correctly.
                              Are you use that you have configured the token correctly?
                              Additionally, install a tool like firebug on your browser and try to access the mirror using the browser. Then enable firebug. It will have error messages or plugin messages written to the console.
                              If the plugin gets images and starts to display them, you will get console entries such as: incrementing the activeItem and refreshing
                                Well we’re certainly glad it worked for you…however…
                                module: ‘MMM-Instagram’,
                                position: ‘top_right’,
                                access_token: ‘API_KEY from instagram’,
                                count: 200,
                                min_timestamp: 0,
                                animationSpeed: 2500,
                                updateInterval: 12500
                                Replaced ‘API_KEY …’
                                and followed all directions and it still sits there and says “Loading…”…
                                  count: 200,
                                  min_timestamp: 0,
                                  Same
                                  • K Offline
                                    What are you guys seeing in the console log? If you are not anything… then I will have to send you a version of the module with debug comments in it to see where the issue is.
                                    FYI - I had a similar issue with the Module for Traffic and never solved it. It just sat on Loading…
                                      cowboysdude Module Developer @kapsolas
                                      @kapsolas Well gosh darn it LOL SOLVE IT MAN! Lives are hangin in the balance…
                                      No I have run it in dev mode and I see or get no errors… so perhaps using a version with debug would be best :)
                                        OH I stand corrected… here’s an error:
                                          A Former User
                                          How do you get it to show in a browser??
                                            cowboysdude Module Developer @Guest
                                            @wjdw87 said in MMM-Instagram - Pull and animate photos from Instagram feed:
                                            restart your mirror like this:
                                            npm start dev
                                            • 1 / 5
