    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 126.0k Views 27 Watching
      dr0pb0x @yo-less
      @yo-less unfortunately this didn’t work :( I even tried setting it to 1px/1% just to make sure but the images didnt change in size
      yo-lessY 1 Reply Last reply
      • yo-lessY
        yo-less Module Developer @dr0pb0x
        @dr0pb0x Have you tried using my forked version here:
        https://github.com/yo-less/MMM-Instagram
        • yo-lessY
          @dr0pb0x I’ve tried it with my forked version after changing the module to simply retrieve any picture from the internet. It’s working fine.
          The only limitation is that you can’t set the MaxHeight in relative terms (percentages), other than that, it works as intended as far as I can tell without actually using the API.
          D 1 Reply Last reply
            dr0pb0x @yo-less
            @yo-less I just had a chance to try it out and it still doesn’t work for me. Could it possibly be Instagram’s API?
            http://stackoverflow.com/questions/21394100/what-are-the-different-image-size-formats-available-via-instagram-api
              Diicken
              Is there anyway to display images from my home server? And do someone have an idea how I should write the code?
              • yo-lessY
                @dr0pb0x Anything is possible, but I doubt it. Please have @kapsolas help you with this, as I don’t have any direct way of testing it. As far as I’m concerned my code adjustments should work.
                • MichMichM
                  MichMich
                  Awesome work! My SO is very pleased with this idea. You might want to add a screenshot to the repo.
                    A Former User
                    Just getting “Loading…”
                    • cowboysdudeC
                      ? 1 Reply Last reply
                        A Former User @cowboysdude
                        @cowboysdude said in MMM-Instagram - Pull and animate photos from Instagram feed:
                        @kapsolas
                        Some of us are having issues here… little help please.
                        Installed per instructions with NPM Install and it isn’t working.
                        That’s all mine says too… “Loading…”
                        apparently this is an unsupported module… delete.
                        • K
                          kapsolas Module Developer
                          I just started up my mirror again and the instagram module loaded up correctly.
                          Are you use that you have configured the token correctly?
                          Additionally, install a tool like firebug on your browser and try to access the mirror using the browser. Then enable firebug. It will have error messages or plugin messages written to the console.
                          If the plugin gets images and starts to display them, you will get console entries such as: incrementing the activeItem and refreshing
                          • cowboysdudeC
                            Well we’re certainly glad it worked for you…however…
                            module: ‘MMM-Instagram’,
                            position: ‘top_right’,
                            access_token: ‘API_KEY from instagram’,
                            count: 200,
                            min_timestamp: 0,
                            animationSpeed: 2500,
                            updateInterval: 12500
                            Replaced ‘API_KEY …’
                            and followed all directions and it still sits there and says “Loading…”…
                              count: 200,
                              min_timestamp: 0,
                              Same
                              • K
                                What are you guys seeing in the console log? If you are not anything… then I will have to send you a version of the module with debug comments in it to see where the issue is.
                                FYI - I had a similar issue with the Module for Traffic and never solved it. It just sat on Loading…
                                • cowboysdudeC
                                  cowboysdude Module Developer @kapsolas
                                  @kapsolas Well gosh darn it LOL SOLVE IT MAN! Lives are hangin in the balance…
                                  No I have run it in dev mode and I see or get no errors… so perhaps using a version with debug would be best :)
                                  • cowboysdudeC
                                    OH I stand corrected… here’s an error:
                                      A Former User
                                      How do you get it to show in a browser??
                                      • cowboysdudeC
                                        cowboysdude Module Developer @Guest
                                        @wjdw87 said in MMM-Instagram - Pull and animate photos from Instagram feed:
                                        restart your mirror like this:
                                        npm start dev
                                          A Former User
                                          cool thanks
                                          • cowboysdudeC
                                            @wjdw87 You’re welcome :) NOW if he can solve the problem it’ll work! :)
                                            • 1 / 5
