    Rss for news feeds?
    13 Posts 6 Posters 25.7k Views 5 Watching
      deadherring
      Some more that don’t work:
      title: “Yahoo News”,
      url: “http://news.yahoo.com/rss”
      title: "Yahoo MLB",
      url: “http://sports.yahoo.com/mlb/rss.xml”
      strawberry 3.141S 1 Reply Last reply Reply Quote 1
        slickric
        ABC news works. “http://abc.net.au/news/feed/51120/rss.xml”
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @deadherring
          @deadherring can you post your config.js part of the newsfeed section completely, I get the no config file message when I start MM this is probably to a syntax error and there shouldn’t be a limit of newsfedd that can be added
            deadherring
            Here’s whats configured that currently IS working:
            module: ‘newsfeed’,
            position: ‘bottom_bar’,
            feeds: [
            title: “New York Times”,
            url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
            title: “CNN”,
            url: “http://rss.cnn.com/rss/cnn_topstories.rss”
            title: “Jerusalem Post”
            url: “http://www.jpost.com/Rss/RssFeedsFrontPage.aspx”
            title: “ESPN”,
            url: “http://www.espn.com/espn/rss/news”
            title: “Israel National News”,
            url: “http://www.israelnationalnews.com/RSS.aspx”
            			showSourceTitle: true,
            			showPublishDate: true
            Here’s what I tried to get working:
            module: ‘newsfeed’,
            feeds: [
            title: “CNN”,
            title: “ESPN”,
            title: “ESPN Baseball”,
            url: “http://www.espn.com/espn/rss/mlb/news”
            url: “http://israelnationalnews.com/RSS.aspx”
            title: “Ynet Breaking News”,
            url: “http://www.ynet.co.il/Integration/StoryRss3254.xml”
            title: “Reuters”,
            url: “http://feeds.reuters.com/reuters/topNews”
            title: “Reuters Sports”,
            url: “http://feeds.reuters.com/reuters/sportsNews”
            title: “Google News”,
            url: “https://news.google.com/output=rss”
            Note, that I also tried to enter each one of the above feeds individually in the config file and restarted MM and got the no config file message for each. The only feeds I could get working are the ones in the working section I described above.
            I feel like there must be something I am missing? Does the version of MM I am using matter? I’m not sure the command to tell which version I have, I searched the forum but couldn’t find anything.
            Thanks,
            Nathan
            • bheplerB Offline
              bhepler Module Developer @deadherring
              • bheplerB Offline
                Try this for a Google news url: https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss
                  @deadherring you must have just used the wrong syntax i tested a couple and they all worked for me, make sure you only use one of those two quotes ' or " another will lead to wrong syntax
                  https://imgur.com/a/cQ0lN
                    deadherring
                    Hey guys,
                    Thanks a lot for the responses. Here’s what I think might be happening:
                    The first three I configured that I got working
                    title: “ESPN”,
                    and one from CNN, I configured on the pi itself, modifying the config file with a mouse and keyboard on the pi. The rest that I shared that weren’t working, modified the config file on my mac via text edit and then ftp’d the file up to the pi. I suspect that the mac might be saving the file in a way the pi does not like, or, as was suggested, inputting the " s in a way the pi does not like. At least, that’s my theory right now, I need to test when I get home.
                    This is the procedure I am following to edit config.js on my mac:
                    1. Two-fingered click on config.js. Open with Text Edit
                    2. Modify the file
                    3. Save as: config.js. I leave the default plain text encoding (UTF-8)
                    Is that the right procedure? My MM is installed in the wall in my bathroom and it would be a huge pain to have to connect a mouse and keyboard to it every time I want to modify anything. I suppose I can ssh into it and modify the config file via nano too. I don’t know if that solves the problem, I have to try later.
                    Thanks again,
                    Nathan
                    KirAsh4K bheplerB 2 Replies Last reply Reply Quote 0
                    • KirAsh4K Offline
                      KirAsh4 Moderator @deadherring
                      @deadherring said in Rss for news feeds?:
                      Either use SSH to get on the rpi, or, if you must, get a wireless mouse/keyboard combo. Those things are cheap on eBay.
                      • bheplerB Offline
                        I think you may be on to something here. Looking back at your complete list of feeds, this is what showed up from your copy & paste:
                        Now I don’t know about your Mac, but from here that looks like some unicode characters where there should be UTF-8. The quotes around Jerusalem Post and the URL value are jacked up. I think you’re better off SSH into the Pi and using nano to edit the config.js file.
