    Rss for news feeds?
    13 Posts 6 Posters 25.5k Views 5 Watching
    • bheplerB Offline
      bhepler Module Developer @deadherring
      • bheplerB Offline
        Try this for a Google news url: https://news.google.com/news?cf=all&hl=en&pz=1&ned=us&output=rss
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @deadherring
          @deadherring you must have just used the wrong syntax i tested a couple and they all worked for me, make sure you only use one of those two quotes ' or " another will lead to wrong syntax
          https://imgur.com/a/cQ0lN
            deadherring
            Hey guys,
            Thanks a lot for the responses. Here’s what I think might be happening:
            The first three I configured that I got working
            title: “ESPN”,
            url: “http://www.espn.com/espn/rss/news”
            and one from CNN, I configured on the pi itself, modifying the config file with a mouse and keyboard on the pi. The rest that I shared that weren’t working, modified the config file on my mac via text edit and then ftp’d the file up to the pi. I suspect that the mac might be saving the file in a way the pi does not like, or, as was suggested, inputting the " s in a way the pi does not like. At least, that’s my theory right now, I need to test when I get home.
            This is the procedure I am following to edit config.js on my mac:
            1. Two-fingered click on config.js. Open with Text Edit
            2. Modify the file
            3. Save as: config.js. I leave the default plain text encoding (UTF-8)
            Is that the right procedure? My MM is installed in the wall in my bathroom and it would be a huge pain to have to connect a mouse and keyboard to it every time I want to modify anything. I suppose I can ssh into it and modify the config file via nano too. I don’t know if that solves the problem, I have to try later.
            Thanks again,
            Nathan
            KirAsh4K bheplerB 2 Replies Last reply Reply Quote 0
            • KirAsh4K Offline
              KirAsh4 Moderator @deadherring
              @deadherring said in Rss for news feeds?:
              Either use SSH to get on the rpi, or, if you must, get a wireless mouse/keyboard combo. Those things are cheap on eBay.
              • bheplerB Offline
                I think you may be on to something here. Looking back at your complete list of feeds, this is what showed up from your copy & paste:
                title: “Jerusalem Post”
                url: “http://www.jpost.com/Rss/RssFeedsFrontPage.aspx”
                Now I don’t know about your Mac, but from here that looks like some unicode characters where there should be UTF-8. The quotes around Jerusalem Post and the URL value are jacked up. I think you’re better off SSH into the Pi and using nano to edit the config.js file.
                  deadherring
                  I got this working, the problem was indeed something with the formatting by editing as a text file on my mac. By sshing into the box and modifying the config file directly on the pi I got it working.
                  One question I still have: is there any way to tell the box to drop headlines after 2 days or so? I’m seeing headlines that are 5, 6, 7, 8 days old cycle through and they are no longer news. I’m seeing some new headlines make their way in but the majority are old. I want to have the MM drop headlines when they are stale, say after 2 days time.
                  I see there is a updateInterval tag but I believe that refers to the frequency it checks for new headlines, not when it drops old headlines off. Anyone else having the same issue?
                  Thanks,
                  Nathan
                    safaaelbrans Banned
