    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 204.3k Views 39 Watching
      sdetweil @popeye2002
      @popeye2002 open the developers window, (f12 or ctrl-shift-i), select the tab labeled console,
      enter jast in the filter field and look for any errors (usually red text)
      AlphaVantage is very protective of their api, and will reject calls too soon from last one
      popeye2002P 1 Reply Last reply Reply Quote 0
      • popeye2002P Offline
        popeye2002 @sdetweil
        @sdetweil Thank you sam… I’m learning all the time. well nothing was red with a search for jast.
        But, I learned a little more about how to troubleshoot!
        Load script: modules/MMM-Jast//MMM-Jast.js
        module.js:479 Module registered: MMM-Jast
        loader.js:150 Bootstrapping module: MMM-Jast
        loader.js:155 Scripts loaded for: MMM-Jast
        loader.js:194 Load stylesheet: modules/MMM-Jast/MMM-Jast.css
        loader.js:157 Styles loaded for: MMM-Jast
        translator.js:175 MMM-Jast - Load translation fallback: translations/en.json
        loader.js:159 Translations loaded for: MMM-Jast
          @popeye2002 ok, how did u start MM??? pm2 or npm start
          if pm2
          then do
          pm2  logs --lines=100
          the module says it puts out messages
          console.log(“Sending Stock result:”, { symbol, current, last });
          my guess is based on the node_helper design, that AlphaVantage has rejected the requests as too frequent…
          (as it does one request per stock)
          you should see the errors in the pm2 log (or terminal window if npm start)
              config.stocks.forEach((stock) => {
                if (!stock.lastUpdate || Date.now() - stock.lastUpdate >= config.updateIntervalInSeconds * 1000) {
                  const url = `${config.baseURL}query?function=TIME_SERIES_DAILY&outputsize=compact&apikey=${config.apiKey}&symbol=${stock.symbol}`;
                  request(url, { json: true }, (err, res, body) => {
          it should do ALL stocks in one request
          AlphaVantage also only does NYSE, nasdaq requires a separate api from a different provider
          popeye2002P 2 Replies Last reply Reply Quote 0
            @sdetweil Gosh, I’m not having much luck. I’m in well over my head but the desire to succede keeps me going. I don’t know how i start my mirror… kinda dumb but it auto starts. I mean dumb that i don’t know pm2 or not.
            I made an error when i installed the module and ran the npm install from the incorrect directory… do you think that would have caused errors? I immeadiately went and ran npm install from the correct directory but perhaps some damage was already done?
            pi@raspberrypi:~/MagicMirror/modules $ npm install
            > magicmirror@2.11.0 install /home/pi/MagicMirror
            " && cd vendor && npm install --loglevel=error
            audited 220 packages in 4.134s
            found 8 vulnerabilities (7 low, 1 high)
              run `npm audit fix` to fix them, or `npm audit` for details
            > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
            > npm run install-fonts && echo "MagicMirror installation finished successfully!
            > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
            > echo "Installing fonts ...
            " && cd fonts && npm install --loglevel=error
            audited 1 package in 2.072s
            found 0 vulnerabilities
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            audited 3224 packages in 25.621s
            73 packages are looking for funding
              run `npm fund` for details
            found 2 low severity vulnerabilities
            pi@raspberrypi:~/MagicMirror/modules $ cd MMM-JaST
            bash: cd: MMM-JaST: No such file or directory
            pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Jast
            pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ npm install
            audited 220 packages in 4.073s
            audited 1 package in 1.865s
            audited 3224 packages in 25.347s
            popeye2002P S 2 Replies Last reply Reply Quote 0
              popeye2002 @popeye2002
              @popeye2002 Is there a working stock ticker module out there?
                pm2 logs returned
                pi@raspberrypi:~ $ pm2  logs --lines=100
                PM2        | 2020-04-24T21:36:53: PM2 log: pid=4346 msg=process killed
                PM2        | 2020-04-24T21:36:53: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-24T21:36:53: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-24T21:38:43: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-24T21:38:43: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-24T21:38:43: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-24T21:38:43: PM2 log: pid=5038 msg=process killed
                PM2        | 2020-04-24T21:38:43: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-24T21:38:43: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-24T21:40:07: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-24T21:40:07: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-24T21:40:07: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-24T21:40:07: PM2 log: pid=5170 msg=process killed
                PM2        | 2020-04-24T21:40:07: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-24T21:40:07: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T08:32:15: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T08:32:15: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T08:32:15: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T08:32:15: PM2 log: pid=5304 msg=process killed
                PM2        | 2020-04-25T08:32:15: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T08:32:15: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T08:36:17: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T08:36:17: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T08:36:17: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T08:36:17: PM2 log: pid=9302 msg=process killed
                PM2        | 2020-04-25T08:36:17: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T08:36:17: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T09:57:23: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T09:57:23: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T09:57:24: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T09:57:24: PM2 log: pid=9444 msg=process killed
                PM2        | 2020-04-25T09:57:24: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T09:57:24: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T09:58:28: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T09:58:28: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T09:58:28: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T09:58:28: PM2 log: pid=10527 msg=process killed
                PM2        | 2020-04-25T09:58:28: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T09:58:28: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:09:42: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:09:42: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:09:43: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:09:43: PM2 log: pid=10657 msg=process killed
                PM2        | 2020-04-25T10:09:43: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:09:43: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:11:40: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:11:40: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:11:40: PM2 log: pid=10870 msg=failed to kill - retrying in 100ms
                PM2        | 2020-04-25T10:11:40: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:11:40: PM2 log: pid=10870 msg=process killed
                PM2        | 2020-04-25T10:11:41: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:11:41: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:12:19: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:12:19: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:12:19: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:12:19: PM2 log: pid=11003 msg=process killed
                PM2        | 2020-04-25T10:12:19: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:12:19: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:24:01: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:24:01: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:24:01: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:24:01: PM2 log: pid=11121 msg=process killed
                PM2        | 2020-04-25T10:24:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:24:01: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:25:09: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:25:09: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:25:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:25:09: PM2 log: pid=11325 msg=process killed
                PM2        | 2020-04-25T10:25:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:25:09: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:26:54: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:26:54: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:26:54: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:26:54: PM2 log: pid=11455 msg=process killed
                PM2        | 2020-04-25T10:26:54: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:26:54: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:29:18: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:29:18: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:29:18: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:29:18: PM2 log: pid=11592 msg=process killed
                PM2        | 2020-04-25T10:29:18: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:29:18: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:47:32: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:47:32: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:47:32: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:47:32: PM2 log: pid=11736 msg=process killed
                PM2        | 2020-04-25T10:47:32: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:47:32: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T10:56:09: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T10:56:09: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T10:56:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T10:56:09: PM2 log: pid=11989 msg=process killed
                PM2        | 2020-04-25T10:56:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T10:56:09: PM2 log: App [MagicMirror:0] online
                PM2        | 2020-04-25T13:07:00: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                PM2        | 2020-04-25T13:07:00: PM2 log: Stopping app:MagicMirror id:0
                PM2        | 2020-04-25T13:07:01: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-04-25T13:07:01: PM2 log: pid=12193 msg=process killed
                PM2        | 2020-04-25T13:07:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
                PM2        | 2020-04-25T13:07:01: PM2 log: App [MagicMirror:0] online
                /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                0|MagicMir | [2020-04-25 13:07:03.816] [LOG]    Module helper loaded: calendar
                0|MagicMir | [2020-04-25 13:07:03.817] [LOG]    No helper found for module: compliments.
                0|MagicMir | [2020-04-25 13:07:03.817] [LOG]    No helper found for module: currentweather.
                0|MagicMir | [2020-04-25 13:07:03.818] [LOG]    No helper found for module: weatherforecast.
                0|MagicMir | [2020-04-25 13:07:03.866] [LOG]    Initializing new module helper ...
                0|MagicMir | [2020-04-25 13:07:03.866] [LOG]    Module helper loaded: newsfeed
                0|MagicMir | [2020-04-25 13:07:03.867] [LOG]    All module helpers loaded.
                0|MagicMir | [2020-04-25 13:07:03.963] [LOG]    Starting server on port 8080 ...
                0|MagicMir | [2020-04-25 13:07:03.975] [LOG]    Server started ...
                0|MagicMir | [2020-04-25 13:07:03.976] [LOG]    Connecting socket for: updatenotification
                0|MagicMir | [2020-04-25 13:07:03.977] [LOG]    Connecting socket for: calendar
                0|MagicMir | [2020-04-25 13:07:03.978] [LOG]    Starting node helper for: calendar
                0|MagicMir | [2020-04-25 13:07:03.978] [LOG]    Connecting socket for: newsfeed
                0|MagicMir | [2020-04-25 13:07:03.979] [LOG]    Starting module: newsfeed
                0|MagicMir | [2020-04-25 13:07:03.979] [LOG]    Sockets connected & modules started ...
                0|MagicMir | [2020-04-25 13:07:04.063] [LOG]    Launching application.
                0|MagicMir | [2020-04-25 13:07:06.150] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/popeye2002%40yahoo.com/private-xxx/basic.ics - Interval: 300000
                0|MagicMir | [2020-04-25 13:07:06.204] [LOG]    Create new news fetcher for url: http://feeds.foxnews.com/foxnews/latest - Interval: 300000
                0|MagicMir | [2020-04-25 14:04:21.937] [LOG]    Create new calendar fetcher for url: http://e-qo.de/9jxe.ics - Interval: 300000
                0|MagicMir | [2020-04-25 14:04:21.939] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles - Interval: 300000
                0|MagicMir | [2020-04-25 14:04:21.966] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 14:22:22.979] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 14:38:37.847] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 14:41:32.981] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 14:43:12.220] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 15:56:03.874] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:00:45.169] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:29:16.261] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:31:44.312] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:42:07.916] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:43:13.644] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:47:47.950] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:49:40.896] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:50:37.811] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 16:51:42.489] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 17:15:51.073] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 19:05:16.061] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 19:08:27.076] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 19:32:33.228] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 19:39:22.974] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 19:40:50.989] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 19:46:01.896] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 19:46:45.924] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 19:49:33.873] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:09:46.906] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:11:40.481] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:12:47.970] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:16:52.618] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:29:10.761] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:29:58.254] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:35:13.756] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:36:40.770] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-25 20:53:02.011] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:30:45.489] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:31:45.053] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:36:19.897] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:37:40.487] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:39:57.737] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:40:44.174] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:42:17.747] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:43:16.624] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:43:48.457] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:46:29.751] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:50:03.961] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:52:17.072] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 08:59:47.487] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 09:05:07.514] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 11:53:35.705] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 11:57:53.203] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 12:14:42.469] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 12:16:20.914] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 12:21:55.192] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 12:33:42.311] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 12:36:20.656] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 12:42:09.482] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 13:30:08.975] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 13:32:30.059] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 13:33:13.172] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 13:34:20.052] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 13:58:13.440] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 14:06:10.539] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 14:11:08.838] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 19:20:53.046] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 19:48:59.181] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 19:51:37.038] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 19:56:36.109] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 20:28:25.851] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 20:34:06.918] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 20:34:52.257] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-26 20:36:22.352] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 07:10:49.993] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 09:08:47.141] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 09:35:53.935] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 12:18:36.586] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 12:22:08.714] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 14:47:40.446] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 14:50:03.962] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 14:52:23.478] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 15:01:12.576] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                0|MagicMir | [2020-04-27 15:05:17.725] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                0|MagicMir |   syscall: 'getaddrinfo',
                0|MagicMir |   hostname: 'calendar.google.com'
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:06:22.096] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                0|MagicMir |     at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
                0|MagicMir |   errno: 'EAI_AGAIN',
                0|MagicMir |   code: 'EAI_AGAIN',
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:11:22.067] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:11:22.078] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:11:22.085] [ERRO1a567b5b65e5b7b2ee1188a1c7b1e51eR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:36:22.076] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:36:22.086] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:36:22.094] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:37:17.474] [ERROR]  fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/':1a567b5b65e5b7b2ee1188a1c7b1e51e Could not resolve host: github.com
                0|MagicMir |
                0|MagicMir | [2020-04-27 04:38:09.577] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics Error: getaddrinfo EAI_AGAIN e-qo.de
                0|MagicMir |   hostname: 'e-qo.de'
                0|MagicMir | }
                0|MagicMir | [2020-04-27 04:53:13.424] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 06:28:34.409] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics Error: getaddrinfo EAI_AGAIN e-qo.de
                0|MagicMir | }
                0|MagicMir | [2020-04-27 08:06:03.590] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 09:01:16.407] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 10:56:11.863] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 11:56:25.483] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 14:50:05.187] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 15:14:26.570] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 15:16:51.611] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 15:35:40.384] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 17:47:57.546] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 19:08:04.123] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 19:45:57.164] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 20:08:40.898] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 20:48:57.682] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 21:39:15.415] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 22:04:27.692] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-27 22:44:40.582] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 02:51:08.557] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 03:26:20.716] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 04:21:43.061] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 05:37:09.320] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 07:02:39.505] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 07:07:41.896] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 08:20:25.487] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 09:00:47.847] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [2020-04-28 09:27:46.569] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                0|MagicMir | [13333:0428/102617.256655:ERROR:CONSOLE(24)] "Empty response arrived for script 'devtools://devtools/remote/serve_file/@6c341de72733661bdcb7ecb31803cc85d29f5f17/product_registry_impl/product_registry_impl_module.js'", source: devtools://devtools/bundled/shell.js (24)
                0|MagicMir | [13333:0428/102617.274103:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                0|MagicMir | [13333:0428/102617.274201:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                0|MagicMir | [13333:0428/102617.274666:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                0|MagicMir | [13333:0428/102617.274765:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                0|MagicMir | [13333:0428/102617.274841:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                  @popeye2002 said in [MMM-JaST] Just another Stock Ticker:
                  still wrong.
                  need to be in the actual module folder
                  cd ~/MagicMirror/modules/MMM-Jast
                  npm install
                    @popeye2002 don’t see this module at all
                      @sdetweil it was in there but hard to see with out any break
                        @popeye2002 something is messed up…
                        I suggest you erase the MMM-Jast folder and git clone again
                        do
                        rm -rf MMM-Jast
                        git clone https://github.com/jalibu/MMM-Jast.git
                        cd MMM-Jast
                        npm install
                        then restart mm
                        pm2 restart 0
                        • 16
                        • 17
                        • 1 / 17
