    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 238.4k Views 39 Watching
    • JalibuJ Offline
      Jalibu Module Developer
      I pushed a newer version with a few improvements:
      • New feature: Daily sum (depot growth)
      • Improvement: Better handling of API calls when there are more than 5 stocks in the ticker (the free API limit is 5 request per minute)
      • Improvement: Nicer rendering of stocks with (yet) unknown value
      I renamed some config properties. As this is a breaking change to the older version, please read the Readme file.
      popeye2002P 1 Reply Last reply Reply Quote 0
      • PerlchampP Offline
        Perlchamp
        something like this for goldprice i could need, whitch display a chart of the last 30 days …
        • popeye2002P Offline
          popeye2002 @Jalibu
          @Jalibu I would really like to see this working in my mirror! so far I have had no luck getting data from Alpha avantage. Is there a way to test and see what data is returned? or maybe what error code comes back? The ticker itself is running well with 15 stocks in it but no values are showing. I went back and used your sample config code and still no values returned. Your thoughts?
          Here is what i used for my code:
          	module: "MMM-Jast",
          	position: "bottom_bar",
          		updateIntervalInSeconds: 1800,
          		fadeSpeedInSeconds: 3.5,
          			stocks: [
          			{ name: "Amazon", symbol: "AMZN" },
          			{ name: "Disney", symbol: "DIS" },
          			{ name: "Ford", symbol: "F" },
          			{ name: "Starbucks", symbol: "SBUX" },
          			{ name: "JD.com", symbol: "JD" },
          			{ name: "Microsoft", symbol: "MSFT" },
          			{ name: "Verizon", symbol: "VZ" },
          			{ name: "Phizer", symbol: "PFE" },
          			{ name: "Intuit", symbol: "INTU" },
          			{ name: "Zinga", symbol: "ZNGA" },
          			{ name: "Cognex", symbol: "CGNX" },
          			{ name: "Fortnet", symbol: "FTNT" },
          			{ name: "Ilumina", symbol: "ILMN" },
          			{ name: "KinderMorgen", symbol: "KMI" },
          			{ name: "NewBev", symbol: "NBEV" },
          			{ name: "Neptune", symbol: "NEPT" },
          			{ name: "Alibaba", symbol: "BABA", tradeCurrency: "USD", displayCurrency: "USD" },
          				defaultCurrency: "USD",
          				apiKey: "My_API_KEY_HERE",
          				scroll: "horizontal", //"<none, vertical, horizontal>"
          				maxWidth: "100%",
          				showDepotGrowth: true
            sdetweil @popeye2002
            @popeye2002 open the developers window, (f12 or ctrl-shift-i), select the tab labeled console,
            enter jast in the filter field and look for any errors (usually red text)
            AlphaVantage is very protective of their api, and will reject calls too soon from last one
              popeye2002 @sdetweil
              @sdetweil Thank you sam… I’m learning all the time. well nothing was red with a search for jast.
              But, I learned a little more about how to troubleshoot!
              Load script: modules/MMM-Jast//MMM-Jast.js
              module.js:479 Module registered: MMM-Jast
              loader.js:150 Bootstrapping module: MMM-Jast
              loader.js:155 Scripts loaded for: MMM-Jast
              loader.js:194 Load stylesheet: modules/MMM-Jast/MMM-Jast.css
              loader.js:157 Styles loaded for: MMM-Jast
              translator.js:175 MMM-Jast - Load translation fallback: translations/en.json
              loader.js:159 Translations loaded for: MMM-Jast
                @popeye2002 ok, how did u start MM??? pm2 or npm start
                if pm2
                then do
                pm2  logs --lines=100
                the module says it puts out messages
                console.log(“Sending Stock result:”, { symbol, current, last });
                my guess is based on the node_helper design, that AlphaVantage has rejected the requests as too frequent…
                (as it does one request per stock)
                you should see the errors in the pm2 log (or terminal window if npm start)
                    config.stocks.forEach((stock) => {
                      if (!stock.lastUpdate || Date.now() - stock.lastUpdate >= config.updateIntervalInSeconds * 1000) {
                        const url = `${config.baseURL}query?function=TIME_SERIES_DAILY&outputsize=compact&apikey=${config.apiKey}&symbol=${stock.symbol}`;
                        request(url, { json: true }, (err, res, body) => {
                it should do ALL stocks in one request
                AlphaVantage also only does NYSE, nasdaq requires a separate api from a different provider
                popeye2002P 2 Replies Last reply Reply Quote 0
                  @sdetweil Gosh, I’m not having much luck. I’m in well over my head but the desire to succede keeps me going. I don’t know how i start my mirror… kinda dumb but it auto starts. I mean dumb that i don’t know pm2 or not.
                  I made an error when i installed the module and ran the npm install from the incorrect directory… do you think that would have caused errors? I immeadiately went and ran npm install from the correct directory but perhaps some damage was already done?
                  pi@raspberrypi:~/MagicMirror/modules $ npm install
                  > magicmirror@2.11.0 install /home/pi/MagicMirror
                  " && cd vendor && npm install --loglevel=error
                  audited 220 packages in 4.134s
                  found 8 vulnerabilities (7 low, 1 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                  > npm run install-fonts && echo "MagicMirror installation finished successfully!
                  > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                  > echo "Installing fonts ...
                  " && cd fonts && npm install --loglevel=error
                  audited 1 package in 2.072s
                  found 0 vulnerabilities
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  audited 3224 packages in 25.621s
                  73 packages are looking for funding
                    run `npm fund` for details
                  found 2 low severity vulnerabilities
                  pi@raspberrypi:~/MagicMirror/modules $ cd MMM-JaST
                  bash: cd: MMM-JaST: No such file or directory
                  pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Jast
                  pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ npm install
                  audited 220 packages in 4.073s
                  audited 1 package in 1.865s
                  audited 3224 packages in 25.347s
                  popeye2002P S 2 Replies Last reply Reply Quote 0
                    popeye2002 @popeye2002
                    @popeye2002 Is there a working stock ticker module out there?
                      pm2 logs returned
                      pi@raspberrypi:~ $ pm2  logs --lines=100
                      PM2        | 2020-04-24T21:36:53: PM2 log: pid=4346 msg=process killed
                      PM2        | 2020-04-24T21:36:53: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-24T21:36:53: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-24T21:38:43: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-24T21:38:43: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-24T21:38:43: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-24T21:38:43: PM2 log: pid=5038 msg=process killed
                      PM2        | 2020-04-24T21:38:43: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-24T21:38:43: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-24T21:40:07: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-24T21:40:07: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-24T21:40:07: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-24T21:40:07: PM2 log: pid=5170 msg=process killed
                      PM2        | 2020-04-24T21:40:07: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-24T21:40:07: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T08:32:15: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T08:32:15: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T08:32:15: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T08:32:15: PM2 log: pid=5304 msg=process killed
                      PM2        | 2020-04-25T08:32:15: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T08:32:15: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T08:36:17: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T08:36:17: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T08:36:17: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T08:36:17: PM2 log: pid=9302 msg=process killed
                      PM2        | 2020-04-25T08:36:17: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T08:36:17: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T09:57:23: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T09:57:23: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T09:57:24: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T09:57:24: PM2 log: pid=9444 msg=process killed
                      PM2        | 2020-04-25T09:57:24: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T09:57:24: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T09:58:28: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T09:58:28: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T09:58:28: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T09:58:28: PM2 log: pid=10527 msg=process killed
                      PM2        | 2020-04-25T09:58:28: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T09:58:28: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:09:42: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:09:42: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:09:43: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:09:43: PM2 log: pid=10657 msg=process killed
                      PM2        | 2020-04-25T10:09:43: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:09:43: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:11:40: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:11:40: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:11:40: PM2 log: pid=10870 msg=failed to kill - retrying in 100ms
                      PM2        | 2020-04-25T10:11:40: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:11:40: PM2 log: pid=10870 msg=process killed
                      PM2        | 2020-04-25T10:11:41: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:11:41: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:12:19: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:12:19: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:12:19: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:12:19: PM2 log: pid=11003 msg=process killed
                      PM2        | 2020-04-25T10:12:19: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:12:19: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:24:01: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:24:01: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:24:01: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:24:01: PM2 log: pid=11121 msg=process killed
                      PM2        | 2020-04-25T10:24:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:24:01: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:25:09: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:25:09: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:25:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:25:09: PM2 log: pid=11325 msg=process killed
                      PM2        | 2020-04-25T10:25:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:25:09: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:26:54: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:26:54: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:26:54: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:26:54: PM2 log: pid=11455 msg=process killed
                      PM2        | 2020-04-25T10:26:54: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:26:54: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:29:18: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:29:18: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:29:18: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:29:18: PM2 log: pid=11592 msg=process killed
                      PM2        | 2020-04-25T10:29:18: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:29:18: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:47:32: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:47:32: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:47:32: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:47:32: PM2 log: pid=11736 msg=process killed
                      PM2        | 2020-04-25T10:47:32: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:47:32: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T10:56:09: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T10:56:09: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T10:56:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T10:56:09: PM2 log: pid=11989 msg=process killed
                      PM2        | 2020-04-25T10:56:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T10:56:09: PM2 log: App [MagicMirror:0] online
                      PM2        | 2020-04-25T13:07:00: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
                      PM2        | 2020-04-25T13:07:00: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2020-04-25T13:07:01: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2020-04-25T13:07:01: PM2 log: pid=12193 msg=process killed
                      PM2        | 2020-04-25T13:07:01: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-04-25T13:07:01: PM2 log: App [MagicMirror:0] online
                      /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                      0|MagicMir | [2020-04-25 13:07:03.816] [LOG]    Module helper loaded: calendar
                      0|MagicMir | [2020-04-25 13:07:03.817] [LOG]    No helper found for module: compliments.
                      0|MagicMir | [2020-04-25 13:07:03.817] [LOG]    No helper found for module: currentweather.
                      0|MagicMir | [2020-04-25 13:07:03.818] [LOG]    No helper found for module: weatherforecast.
                      0|MagicMir | [2020-04-25 13:07:03.866] [LOG]    Initializing new module helper ...
                      0|MagicMir | [2020-04-25 13:07:03.866] [LOG]    Module helper loaded: newsfeed
                      0|MagicMir | [2020-04-25 13:07:03.867] [LOG]    All module helpers loaded.
                      0|MagicMir | [2020-04-25 13:07:03.963] [LOG]    Starting server on port 8080 ...
                      0|MagicMir | [2020-04-25 13:07:03.975] [LOG]    Server started ...
                      0|MagicMir | [2020-04-25 13:07:03.976] [LOG]    Connecting socket for: updatenotification
                      0|MagicMir | [2020-04-25 13:07:03.977] [LOG]    Connecting socket for: calendar
                      0|MagicMir | [2020-04-25 13:07:03.978] [LOG]    Starting node helper for: calendar
                      0|MagicMir | [2020-04-25 13:07:03.978] [LOG]    Connecting socket for: newsfeed
                      0|MagicMir | [2020-04-25 13:07:03.979] [LOG]    Starting module: newsfeed
                      0|MagicMir | [2020-04-25 13:07:03.979] [LOG]    Sockets connected & modules started ...
                      0|MagicMir | [2020-04-25 13:07:04.063] [LOG]    Launching application.
                      0|MagicMir | [2020-04-25 13:07:06.150] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/popeye2002%40yahoo.com/private-xxx/basic.ics - Interval: 300000
                      0|MagicMir | [2020-04-25 13:07:06.204] [LOG]    Create new news fetcher for url: http://feeds.foxnews.com/foxnews/latest - Interval: 300000
                      0|MagicMir | [2020-04-25 14:04:21.937] [LOG]    Create new calendar fetcher for url: http://e-qo.de/9jxe.ics - Interval: 300000
                      0|MagicMir | [2020-04-25 14:04:21.939] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles - Interval: 300000
                      0|MagicMir | [2020-04-25 14:04:21.966] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 14:22:22.979] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 14:38:37.847] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 14:41:32.981] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 14:43:12.220] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 15:56:03.874] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:00:45.169] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:29:16.261] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:31:44.312] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:42:07.916] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:43:13.644] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:47:47.950] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:49:40.896] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:50:37.811] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 16:51:42.489] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 17:15:51.073] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 19:05:16.061] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 19:08:27.076] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 19:32:33.228] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 19:39:22.974] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 19:40:50.989] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 19:46:01.896] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 19:46:45.924] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 19:49:33.873] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:09:46.906] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:11:40.481] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:12:47.970] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:16:52.618] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:29:10.761] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:29:58.254] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:35:13.756] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:36:40.770] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-25 20:53:02.011] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:30:45.489] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:31:45.053] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:36:19.897] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:37:40.487] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:39:57.737] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:40:44.174] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:42:17.747] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:43:16.624] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:43:48.457] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:46:29.751] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:50:03.961] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:52:17.072] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 08:59:47.487] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 09:05:07.514] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 11:53:35.705] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 11:57:53.203] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 12:14:42.469] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 12:16:20.914] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 12:21:55.192] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 12:33:42.311] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 12:36:20.656] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 12:42:09.482] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 13:30:08.975] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 13:32:30.059] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 13:33:13.172] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 13:34:20.052] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 13:58:13.440] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 14:06:10.539] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 14:11:08.838] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 19:20:53.046] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 19:48:59.181] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 19:51:37.038] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 19:56:36.109] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 20:28:25.851] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 20:34:06.918] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 20:34:52.257] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-26 20:36:22.352] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 07:10:49.993] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 09:08:47.141] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 09:35:53.935] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 12:18:36.586] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 12:22:08.714] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 14:47:40.446] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 14:50:03.962] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 14:52:23.478] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 15:01:12.576] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      0|MagicMir | [2020-04-27 15:05:17.725] [LOG]    Use existing news fetcher for url: http://feeds.foxnews.com/foxnews/latest
                      /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                      0|MagicMir |   syscall: 'getaddrinfo',
                      0|MagicMir |   hostname: 'calendar.google.com'
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:06:22.096] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                      0|MagicMir |     at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
                      0|MagicMir |   errno: 'EAI_AGAIN',
                      0|MagicMir |   code: 'EAI_AGAIN',
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:11:22.067] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:11:22.078] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:11:22.085] [ERRO1a567b5b65e5b7b2ee1188a1c7b1e51eR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:36:22.076] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:36:22.086] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:36:22.094] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=en.usa%23holiday%40group.v.calendar.google.com&ctz=America%2FLos_Angeles Error: getaddrinfo EAI_AGAIN calendar.google.com
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:37:17.474] [ERROR]  fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/':1a567b5b65e5b7b2ee1188a1c7b1e51e Could not resolve host: github.com
                      0|MagicMir |
                      0|MagicMir | [2020-04-27 04:38:09.577] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics Error: getaddrinfo EAI_AGAIN e-qo.de
                      0|MagicMir |   hostname: 'e-qo.de'
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 04:53:13.424] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 06:28:34.409] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics Error: getaddrinfo EAI_AGAIN e-qo.de
                      0|MagicMir | }
                      0|MagicMir | [2020-04-27 08:06:03.590] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 09:01:16.407] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 10:56:11.863] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 11:56:25.483] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 14:50:05.187] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 15:14:26.570] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 15:16:51.611] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 15:35:40.384] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 17:47:57.546] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 19:08:04.123] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 19:45:57.164] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 20:08:40.898] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 20:48:57.682] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 21:39:15.415] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 22:04:27.692] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-27 22:44:40.582] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 02:51:08.557] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 03:26:20.716] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 04:21:43.061] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 05:37:09.320] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 07:02:39.505] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 07:07:41.896] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 08:20:25.487] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 09:00:47.847] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [2020-04-28 09:27:46.569] [ERROR]  Calendar Error. Could not fetch calendar:  http://e-qo.de/9jxe.ics 502: Bad Gateway
                      0|MagicMir | [13333:0428/102617.256655:ERROR:CONSOLE(24)] "Empty response arrived for script 'devtools://devtools/remote/serve_file/@6c341de72733661bdcb7ecb31803cc85d29f5f17/product_registry_impl/product_registry_impl_module.js'", source: devtools://devtools/bundled/shell.js (24)
                      0|MagicMir | [13333:0428/102617.274103:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                      0|MagicMir | [13333:0428/102617.274201:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                      0|MagicMir | [13333:0428/102617.274666:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                      0|MagicMir | [13333:0428/102617.274765:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                      0|MagicMir | [13333:0428/102617.274841:ERROR:CONSOLE(109)] "Uncaught (in promise) Error: Could not instantiate: ProductRegistryImpl.Registry", source: devtools://devtools/bundled/shell.js (109)
                        @popeye2002 said in [MMM-JaST] Just another Stock Ticker:
                        still wrong.
                        need to be in the actual module folder
                        cd ~/MagicMirror/modules/MMM-Jast
                        npm install
                          @popeye2002 don’t see this module at all
                            @sdetweil it was in there but hard to see with out any break
                              @popeye2002 something is messed up…
                              I suggest you erase the MMM-Jast folder and git clone again
                              do
                              rm -rf MMM-Jast
                              git clone https://github.com/jalibu/MMM-Jast.git
                              cd MMM-Jast
                              npm install
                              then restart mm
                              pm2 restart 0
                                @sdetweil much much better!!!
                                and now I do see the errors for to many calls
                                0|MagicMirror  | [2020-04-28 11:05:25.153] [ERROR]
                                0|MagicMirror  | Error processing Stock response {
                                0|MagicMirror  |   Note: 'Thank you for using Alpha Vantage! Our standard API call frequency is 5 ' +
                                0|MagicMirror  |     'calls per minute and 500 calls per day. Please visit ' +
                                0|MagicMirror  |     'https://www.alphavantage.co/premium/ if you would like to target a higher ' +
                                0|MagicMirror  |     'API call frequency.'
                                0|MagicMirror  | }
                                0|MagicMirror  | [2020-04-28 11:05:25.167] [ERROR]
                                0|MagicMirror  | }
                                0|MagicMirror  | [2020-04-28 11:05:25.460] [LOG]
                                0|MagicMirror  | Sending Stock result: { symbol: 'SBUX', current: 77.74, last: 75.58 }
                                0|MagicMirror  | [2020-04-28 11:05:25.482] [LOG]
                                0|MagicMirror  | Sending Stock result: { symbol: 'MSFT', current: 174.05, last: 174.55 }
                                0|MagicMirror  | [2020-04-28 11:05:25.555] [LOG]
                                0|MagicMirror  | Sending Stock result: { symbol: 'JD', current: 45.58, last: 45.05 }
                                0|MagicMirror  | [2020-04-28 11:05:25.649] [LOG]
                                0|MagicMirror  | Sending Stock result: { symbol: 'VZ', current: 58.22, last: 57.81 }
                                0|MagicMirror  | [2020-04-28 11:05:25.683] [LOG]
                                0|MagicMirror  | Sending Stock result: { symbol: 'PFE', current: 38.1199, last: 38.33 }
                                0|MagicMirror  | [2020-04-28 11:05:28.263] [ERROR]
                                  Can’t thank you enough!!!
                                  You really made my day a whole lot better! no idea how I may pass it along but you can belive i will pass it forward one way or another.
                                  Cheers
                                  Scott
                                    @popeye2002 cool, thats the idea around here… we all work together
                                    • W Offline
                                      wilbur245
                                      Hello I have installed Jast, everything is fine.
                                      I just don’t see a share.
                                      Biontech
                                      FRA: 22UA
                                      there is zero also 22UA.DE does not work.
                                      how can i “https://www.stockdio.com/”
                                      insert as API?
                                      JalibuJ 1 Reply Last reply Reply Quote 0
                                        MisterTFM
                                        What “symbol” should I use for the Dow Jones Industrial Average? I tried DJI and .DJI
                                          RIKKO14
                                          does this module work for french stocks on euronext ?
                                          • W Offline
                                            wilbur245
                                            Hello, what do I have to do so that the values ​​are shown up to date to some extent. It is currently only queried once a day or the value renewed.
                                            I sometimes have values ​​for 2 days even though they have fallen or increased
                                            • 1 / 9
