    MMM-Globe
    118 Posts 32 Posters 192.9k Views 37 Watching
    • cowboysdudeC Offline
      I have tried it…It worked really well… but not on the pi…it’s impressive!
      • E Offline
        earthlink @Eunanibus
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor
          hi, does it work on Mac mini 2011 ?
          • E Offline
            Eunanibus Module Developer
            Hey all!
            The time has come.
            I’ve really appreciated all the feedback I’ve gotten from all of you. I’ve been so happy watching you all use this.
            That being said, development on the lite version starts next week. I want everyone to be able to use this regardless of hardware.
            I’d also like to take in suggestions for feature requests. Anything you want? Anything you wish was better? Now is the time to start letting me now.
            Thanks guys.
            mumblebajM B 2 Replies Last reply Reply Quote 0
            • mumblebajM Offline
              mumblebaj Module Developer @Eunanibus
              @Eunanibus Awesome, can’t wait. I actually tried this the first time i setup my mirror and it worked for me on my Pi 3B+. Although some of the locations were wrong at the time but I assume that was my error. Nice work with this project and again, can’t wait for the light version.
              • E Offline
                earthlink
                  bhepler Module Developer @Eunanibus
                  @Eunanibus - Well, since you’re asking… these are the things I remember from the original code that I would love to see implemented.
                  • Specify locations to be linked by an arc.
                  • Specify colors used for the pins
                  • Specify colors used for the arcs
                  • An updateInterval to control when to refresh the globe w/ the build animation
                  • A true/false switch to display the default pins.
                  • Alternately, an array for unlabeled pins that will replace the defaults if you provide it.
                  Thanks!
                  • L Offline
                    ltzChubbz
                    Any updates on this lite version?
                    Also is there a way to display all pin names when they are close and have them overlap?
                    • TechJak7000T Offline
                      TechJak7000
                      Hey Eunanibus, Jolly good show old boy :blond-haired_man: :clapping_hands: :clapping_hands: :clapping_hands:
                      I have implemented straight away :- IMG_0737.jpg
                      it runs without any problems until now !
                      StoffbeuteluweS 1 Reply Last reply Reply Quote 1
                        Stoffbeuteluwe Project Sponsor @TechJak7000
                        @TechJak7000 hi, do you use a raspberry pi?
                          TechJak7000
                          Hello, I do use Raspberry pi4 with High performance 128 GB SD card !
                          • BesomarB Offline
                            Besomar
                            Impressive!!!
                            I just started a smart mirror project with Pi3 (1G) and just found out about this awesome plugin.
                            Great job!
                            So, I guess I’ll have to wait for that lightweight version :)
                            • I Offline
                              Idea215
                              I have installed module on my P4, but somehow it does not really work. It is only displayed as in the picture below and not as in the pictures on the GitHub page. Does anyone know what the problem is?
                              My Mirror:
                              https://imgur.com/a/tOwDJru
                              GitHub Version:
                              https://i.imgur.com/oF3mxBC.png
                              • W Offline
                                Wenike @Idea215
                                @idea215 Did you go to the github link from the first post or just Googled for MMM-Globe? Yours looks like mine which is from a different MMM-Globe
                                • O Offline
                                  oli28
                                  What a beautiful modul! Any chance to change the font size to be able to fit more destinations next to each others? I did try to find it in the .css but had no luck yet.
                                  • F Offline
                                    Foxy25
                                    I have a question about the module:
                                    I would like to make the background transparent, is that possible? At the moment it is black.
                                    That would help me, because I have a slideshow running in the background and the black background behind the globe doesn’t look so nice …
                                    Would be very grateful if someone could help.
                                    Foxy
                                    • W Offline
                                      Wenike @Foxy25
                                      @foxy25 @foxy25 In your custom.css file, see if adding:
                                      .globe { opacity: 0.0; }
                                      Fixes the issue?
                                      • F Offline
                                        Foxy25 @Wenike
                                        @wenike
                                        i use the command in the styles.css of the modul, not in the custom.css.
                                        It works, but it makes the complete module invisible, not only the background behind the globe.
                                        Thank you for your support.
                                          ashishtank Module Developer @Foxy25
                                          @foxy25 to make globe transparent there are two changes required.
                                          • Module div’s background color
                                          • Globe canvas itself have black color as background.
                                          First one can be easily doable with css but to make globe transparent you will need to change the code as well. Do below to make globe transperent.
                                          • In custom.css add below css
                                          .globe
                                          	background-color: unset;
                                          • in modules\MMM-Globe\encom-globe.js file find below line and change it to.
                                          from
                                          this.renderer = new THREE.WebGLRenderer( { antialias: true } );
                                          to
                                          this.renderer = new THREE.WebGLRenderer( { antialias: true, alpha: true } );
                                          below is output
                                          Before
                                          After
                                          Let me know how/if it works for you.
                                          F 1 Reply Last reply Reply Quote 1
                                          • F Offline
                                            Foxy25 @ashishtank
                                            It works perfect!!!
                                            Thank you so much for you support!!!
                                            Greetings from Germany
                                            Foxy
                                            • 5 / 6
