    MMM-MyCommute
    286 Posts 80 Posters 685.4k Views 77 Watching
      SoleLo @bhepler
      @bhepler would something like this work?
      .MMM-MYCommute.arrival-time-only .time {
      display: none;
      UPDATE: I actually tried
      .MMM-MYCommute. transit-arrival-time.time
      display: none;
      Still doesn’t work.
        sun34529
        @SoleLo and @bhepler , I’m trying to figure this out as well. Any luck?
        • lavolp3L Offline
          lavolp3 Module Developer
          I see that the most recent active fork of this module has changed to @qistoph ?
          I am wondering if the module still works with one origin or if there’s already a possibility for several routes with different origins and destinations?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            sdetweil @sun34529
            @sun34529 use a browser on your pc, chrome or firefox, and open the MM page, (make sure the mm config allows outside access with
            address:"0.0.0.0",
            ipWhitelist:[],
            in config.js)
            then do ctrl-shift-i on your keyboard to open the developers window,
            and select the elements tab, and navigate to the module content to the piece u are interested in
            once there, click on it in the elements tree (so it becomes selected) and u will see the css tree for that element on the right side.
            the top most is the info AT the element, u can click to add display:none and the element should not be shown…
            on the bottom of the screen shows the class name tree
            this will give u the info to get the file update right… Screenshot at 2020-05-25 17-11-54.png
            • RedNaxR Offline
              RedNax Module Developer
              Hi everyone,
              Just to remind you that this still works…
              https://github.com/RedNax67/MMM-TrafficCal
              https://forum.magicmirror.builders/topic/831/mmm-trafficcal-dynamically-display-commutes-based-on-calendar-entries?_=1590694194999
                Srcodesalittle
                Hi there. Thanks for making this module.
                I was running this flawlessly till a few days ago when it randomly just disappeared from my mirror. The API is still active, I haven’t crossed my billing threshold or anything and the startup logs do show that Mycommute has started. Do you by any chance have any suggestions on what could be happening?
                Thanks in advance!
                  Srcodesalittle @RedNax
                  @RedNax Thanks for the heads up. So, I don’t actually run a calendar module so I’m a little lost on how to specify the destination (I go to the same destination everyday).
                  Could you possibly please give me a more broken down instruction on what I need to do to set a destination?
                  Thanks in advance!
                  • L Offline
                    leem2000
                    Hi, I’m new to Pi and MM. I’ve installed few modules and got them working. MMM-MyCommute looks to be a very useful module but can’t get it to work. I installed it following the instructions on its git page. It’s failing to load. I get “Loading…”.
                    I’m running with unmodified config from the git module page with my apiKey and hideDays set to []. The API key works as I have tested it with another module and also with https://maps.googleapis.com/maps/api/directions/json?origin=Disneyland&destination=Universal+Studios+Hollywood&key=. No errors in pm2 logs either. Peeking into the main .js file, there are log statements. I can’t locate a log file. Not familiar with Node or MM. Would appreciate pointers on what to try and where to look next.
                    Thanks in advance.
                      sdetweil @leem2000
                      @leem2000 for the MMM-MyCommute.js, open the developers window (ctrl-shift-i on the mirror keyboard), select the console tab… u can filter too, enter comm in the filter field to see messages out from only a module with ‘comm’ in its name
                      • L Offline
                        leem2000 @sdetweil
                        Thanks @sdetweil. There are some errors logged to the console.
                        The module it’s trying to access is
                        http://localhost:8080/modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js.
                        When I put that into the browser I get
                        Cannot GET /modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js
                        Then for each destination, I get
                        Clearly, moment.duration format function is missing. I installed node by following manual install instructions in MM install page.
                        I have the following in node_modules/moment. This is as installed and not modified.
                        pi@raspberrypi:~/MagicMirror/node_modules/moment $ pwd
                        /home/pi/MagicMirror/node_modules/moment
                        pi@raspberrypi:~/MagicMirror/node_modules/moment $ ls
                        CHANGELOG.md  ender.js  locale  moment.d.ts  package.js    README.md  ts3.1-typings
                        dist          LICENSE   min     moment.js    package.json  src
                        Any ideas on how to fix this?
                          sdetweil @leem2000
                          @leem2000its looking for the moment in the MODULE node_modules folder, NOT the base
                          did u do the npm install in the module folder?
                          Enter the MMM-MyCommute directory and execute npm install
                          • L Offline
                            leem2000 @sdetweil
                            Thanks, that worked! I haven’t been doing “npm install” for the other modules I installed. Is that recommended after each module install?
                              sdetweil @leem2000
                              @leem2000 if it has a package.json file, yes, and if the instructions say so, yes
                              gotta follow the instructions
                                requiemmg
                                I have been installing this module on 2 MagicMirrors.
                                It’s running 24/7 and I check travelling time to 4 destinations (so, 8 with both mirrors).
                                Today I got an email, that after about only 2 weeks or so, there are just 25€ remaining of my testing period and 300€.
                                I do not have any other projects and I’ve checked the Dashboard, there have been more than 45000 queries to the directions API so far.
                                First thing I did: Limited the module on both mirrors to run only at daytime. But as I have different work locations and shifts, this is not so good. And, of course, I dont want to generate queries for a real amount of cash…
                                What should I do? Is this normal?
                                  sdetweil @requiemmg
                                  @requiemmg yes, I got a warning too from google, 4 mirrors, asking every 5 minutes, the api query counts add up fast… 8,000 calls a week…
                                    requiemmg
                                    Okay, so no way to limit API calls? Would it be possible to call every 10 minutes or so and only every 60 minutes in the “non-active” time?
                                      sdetweil @requiemmg
                                      @requiemmg if someone changes the code, sure. can do almost anything. I support another mirror app which does provide for a interested time period. (rush hour), and doesn’t call API outside that time period if set
                                        requiemmg
                                        Okay, played around a bit. Set the module to show times only from 5am to 5pm. And I added a “pollFrequency: 15 * 60 * 1000,” to my config.
                                        While the first one works (the module disappears at night), the second one does not seem to work:
                                        This is the Traffic from the last 2 days. You can see the requests are paused last night. I made changes to the poll frequency yesterday in the afternoon, no change.
                                        The module used up nearly all of my €300 starting balance. I wonder if this will go on like this.
                                        API calls in the last 48 hours:
                                        API calls in the last ONE hour:
                                        Which I do not understand: No errors. Poll Frequency of every 15 Minutes. 2 Mirrors with 4 destinations each. So 4*8=24 API calls/hour would be what I expect to see…
                                          sdetweil @requiemmg
                                          @requiemmg 352/hour is 5.87 per minute, about once every 12 seconds… once every 24 seconds both of 2 machines.
                                          1 looked at the code, 1 api request per destination.
                                            requiemmg
                                            Raised an issue. Seems like the problem comes with the use of MMM-Pages, so on every reload of the page, the module is loaded and the requests are sent again, even if the data is still up to date. @qistoph was so nice to make a fork to address this issue.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
