    Halloween mirror ghouls anyone?
    56 Posts 18 Posters 64.3k Views 19 Watching
      bhepler Module Developer @Mitchfarino
      @Mitchfarino Presumably you can inject some scripting to define an array of video files and then call a function to play the next file in the array. If you call that function from the onended() event in the VIDEO tag you should be able to get 90% of the way there.
        Mitchfarino Module Developer @bhepler
        @bhepler Any idea how to do that?
          @Mitchfarino StackExchange had a pretty good start.
          Based upon the fact that the text value includes the HTML tag , you can probably put another tag in there to handle your script. Probably. I haven’t tried it. You may end up making some fancy character escaping in order to get it to work properly, but it should be possible. If I get the chance I’ll play with it.
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @bhepler
            @bhepler the problem is to get the script tag evaluated, when it gets inserted as text, i have a script that is working, but still stuck on the evaluation. It’s probably easier to just create a new module, than finding another hacky workaround
              bhepler Module Developer @strawberry 3.141
              @strawberry-3.141 You’re going to turn me into a Javascript developer with crazy talk like that.
                @bhepler that’s what i currently come up with
                    module: "helloworld",
                    position: "fullscreen_below",
                        text: "<video id='halloween_player'></video><script>console.log('init'); var halloween_videos = ['http://techslides.com/demos/sample-videos/small.mp4', 'http://vo.fod4.com/v/9727363b6d/v1280-q2.mp4']; var halloween_index = 0; function playHalloweenVideos(){ console.log('play'); if(halloween_index >= halloween_videos.length){ halloween_index = 0; } var player = document.getElementById('halloween_player'); player.src = halloween_videos[halloween_index++]; player.addEventListener('ended', playHalloweenVideos); player.play(); } playHalloweenVideos();</script><img src='test.png' onload='console.log(\"test\"); eval(document.getElementById(\"halloween_player\").nextSibling.innerHTML); document.removeChild(this);'"
                but i’m not able to eval in my fake img tag, however if you enter this command in the electron console it works
                eval(document.getElementById("halloween_player").nextSibling.innerHTML);
                • F Offline
                  frog
                  • F Offline
                    frog
                    I’m trying to loop a video using the following:
                       module: ‘helloworld’,
                       position: ‘fullscreen_below’,
                          text: “<video src=‘vendor/skelloop.mp4’ autoplay loop; position:absolute; top:100%;left:50%; height:200%’></video>”
                    but it just stops after the first run. I’m using the OMXplayer which I would have thought would have taken the loop parameter - but it seems it doesn’t. Anyone have an idea how I can fix this?
                      bhepler Module Developer @frog
                      @frog You seem to be missing the style='position... part.
                      So:
                            text: “<video src=‘vendor/skelloop.mp4’ autoplay loop style='position:absolute; top:100%;left:50%; height:200%’></video>”
                      F 1 Reply Last reply Reply Quote 2
                      • F Offline
                        frog @bhepler
                        @bhepler yup, that dit it. Thanks!
                        • N Offline
                          nuckinfutz
                          is there a way to use a variable in the video file name? This is so close to what I want it hurts. What I want to do is play a random video from a specific location. I will be creating the videos so I will have complete control over the video naming and encoding.
                            makersworkbench
                            Sorry for resurrecting an old thread, but I have been trying to figure this out on my own for over a week now. How would I use a PING (ultrasonic) sensor to trigger the mmm-podcast module to make the jump scare happen? Python I can write but I am a javascript noob, and that is why I am having issues here.
                            So basically I want the PING sensor to trigger and play the video file full screen with audio after it senses someone x-distance away for X number of seconds. Very bad psudo code below.
                            when distance from sensor = 24-inches for 10-seconds
                            play scare animation using mmm-podcast
                            return to MagicMirror screen
                            wait 60-seconds before arming ping sensor again
                              Bruno
                              Guys,
                              How did you manage to play a local video on the Pi with this module?
                              I am trying to make the halloween ghoul video (maybe a little late). I can get some video to play if the video is online. But if the video is on a directory on my raspberry pi I can’t.
                              In this topic all the “text” tag on the helloworld is blank because it is html tag so it gets “interpreted” by my browsers. I’ll try to post my “text” tag in non-HTML way, so you guys can analyse it (I took off the “minor than” sign from the tags: video, src and /video)
                              Heres my config:
                                          position: "middle_center",
                                              text: "video id=\"homevideo\" width=\"100%\" autoplay autobuffer> source src=\"http://clips.vorwaerts-gmbh.de/VfE_html5.mp4\" type=\"video/mp4\" /> /video>"
                              Above is an example if a simples mp4 video online: http://clips.vorwaerts-gmbh.de/VfE_html5.mp4
                              How do I change to a local mp4 file in my Pi? I tryed src="/home/pi/path/to/my/file.mp4" but no success… any ideas?
                              S Mykle1M 2 Replies Last reply Reply Quote 0
                                sdetweil @Bruno
                                @Bruno said in Halloween mirror ghouls anyone?:
                                Guys,
                                Heres my config:
                                Path has got to be in the mm folder tree or linked to from there
                                /modules/module name/filename.mp4
                                  Mykle1 Project Sponsor Module Developer @Bruno
                                  If you are trying to make a module that plays local videos or if you’re just looking for a module that plays local videos then have a look at this module
                                  https://github.com/mykle1/MMM-EasyBack
                                  I just downloaded your example video and it works perfectly well with this module, locally.
                                  B B 2 Replies Last reply Reply Quote 0
                                    Bruno @Mykle1
                                    @Mykle1 said in Halloween mirror ghouls anyone?:
                                    Nice!!! I’ll give it a try. It’s nice that I can define width and height!!! Thanks!!
                                      You’re welcome, mate. If you are still wanting to create your own module, feel free to take whatever you find useful from the module and use it in your own.
                                        BD0G @Mykle1
                                        @Mykle1
                                        This is so weird!
                                        I installed MMM-EasyBack as per the instructions.
                                        Copied a small Halloween Video in the MagicMirror/Modules/MMM-EasyBack/Videos folder. The file is named HalloweenMM.mp4. Its 15 MB. So pretty small.
                                        Here are my config.js entries for the module.
                                            module: 'MMM-EasyBack',
                                            position: 'middle_center',
                                               // bgName: "Example.jpg",   // "Example.jpg", the file name of your background image (case sensitive)
                                                videoName: "HalloweenMM.mp4",       // "baboon.mp4",         // file name of your local video
                                                height: "1920px",    // your display's resolution in pixels. Enter in config.js
                                                width: "1080px",     // your display's resolution in pixels. Enter in config.js
                                        I completely removed the section about Youtube ID , etc . When I launch the MM interface it contunually comes up with the YouTube Video by David Snow found here https://www.youtube.com/watch?v=So3vH9FY2H4
                                        There is no reference that I can find to that video at all.
                                        The YouTube ID that is referenced by this video is the same one that was in the original configuration file.
                                          sdetweil @BD0G
                                          @BD0G open the developers window, ctrl-shift-i on the mm keyboard, and select the console tab and then enter hall in the filter field
                                          see if there are any errors (usually red text)
                                          case matters
                                            BD0G @sdetweil
                                            @sdetweil Thanks Sam.
                                            I went into the MMM-EasyBack.js file and altered it to reflect the video HalloweenMM.mp4 rather than within the config.js file. I also removedt the hard coded Youtube ID that was in the MMM-EasyBack.js file.
                                            Now it plays the Halloween file , but I cannot control the sizing of the video and it takes up just about the entire screen.
                                            Module.register("MMM-EasyBack", {
                                                defaults: {
                                                    bgName: "",         // .jpg, .gif, .png, Full screen animated gifs too!
                                                    videoName: "HalloweenMM.mp4",     // your local picture files go in "images" folder of MMM-EasyBack
                                                    youTubeID: "",      // YouTube ID from the YouTube url
                                                    height: "800px",   // your display's resolution in pixels. Enter in config.js
                                                    width: "600px",    // your display's resolution in pixels. Enter in config.js
                                                    animationSpeed: "0",
                                                    updateInterval: 60 * 60 * 1000,
                                            • 2 / 3
