    Halloween mirror ghouls anyone?
    56 Posts 18 Posters 67.4k Views 19 Watching
      rvdgeer @Jopyth
      @Jopyth I have found something that’s exactly that:
      A ghost, doing scary stuff, fading in and out on a black background and that stays mostly within an invisible portrait frame…
      Unfortunately it’s not free, so I can’t share it…
      But if we have some sort of video player we can use, I would certainly love to try to get it to work…
      I tried MMM-Podcast, but realised it needs a button, wired to the Pi and I don’t have nor want that…
        Jopyth Moderator
        Well we would need to change MMM-Podcast, to basically play the video always and then maybe show/hide this with MMM-Module-Scheduler.
        Still a custom module might be better here, since we do not want to waste resources, by playing a hidden video all the time, maybe I have time to put something together this weekend.
          rvdgeer @Jopyth
          @Jopyth How about the helloworld module just to add the needed html tags to display video?
          (Obviously just for testing purposes…)
            Mitchfarino Module Developer @Jopyth
            @Jopyth www.reddit.com/r/HighQualityGifs
              McSorley
              Link it up with a PIR sensor with some bluetooth speakers and you could give someone a nasty fright!!
                Jopyth Moderator @rvdgeer
                @rvdgeer Good idea.
                If anyone wants to see how this looks (with a gif it is pretty simple):
                			module: "helloworld",
                			position: "fullscreen_below",
                				text: "<img src='https://thumbs.gfycat.com/DiscreteDenseCockroach-size_restricted.gif' alt='GIF test' style='position:absolute; top:100%; left:50%; transform: translate(-50%, -100%); width:100%;'>"
                R 1 Reply Last reply Reply Quote -1
                  rvdgeer @Jopyth
                  I did sudo apt-get install omxplayer and included a video using <video> tags in the helloworld module.
                  It works great!
                    rvdgeer @rvdgeer
                    Markdown is not available from my Android smartphone. I don’t have the correct character available…
                    And it’s a little too much to ask, to look-up the character on the web, so I can copy it…
                    J BKeyportB 2 Replies Last reply Reply Quote 1
                      jtyle6 @rvdgeer
                      @rvdgeer said in Halloween mirror ghouls anyone?:
                      Markdown forms an Android phone
                        @Jopyth Have you had any luck with this mate?
                        I haven’t looked at it for a while, have had a few things going on so haven’t had chance
                          Jopyth Moderator @Mitchfarino
                          @Mitchfarino did not have the time for it. I will see if I get to it, when I get back from vacation in one week.
                            bhepler Module Developer
                            I experimented with this a bit yesterday. Thanks to @rvdgeer for the hint and @Jopyth for the initial code to start.
                            I ripped a YouTube video to disk and uploaded it to my Pi, putting it in the vendor folder. Adding this to my config.js was surprisingly effective (the rotate 90 is due to the video being designed to be projected on a window):
                            {     module: "helloworld",
                                            text: "<video src='vendor/halloween.mp4' autoplay loop style='transform:rotate(90deg); position:absolute; top:50%;left:30%; height:50%'></video>"
                            M 2 Replies Last reply Reply Quote 1
                              Mitchfarino Module Developer @bhepler
                              @bhepler What video did you use? Sorry I missed the link
                              How did you rip it from YouTube?
                              • Y
                                yawns Moderator @Mitchfarino
                                @Mitchfarino
                                check your chat ;)
                                  Mitchfarino Module Developer @yawns
                                  @yawns Awesome, thank you!
                                    @bhepler Is there a way to loop through a number of videos, rather than just the one on repeat?
                                      bhepler Module Developer @Mitchfarino
                                      @Mitchfarino Presumably you can inject some scripting to define an array of video files and then call a function to play the next file in the array. If you call that function from the onended() event in the VIDEO tag you should be able to get 90% of the way there.
                                        @bhepler Any idea how to do that?
                                          @Mitchfarino StackExchange had a pretty good start.
                                          Based upon the fact that the text value includes the HTML tag , you can probably put another tag in there to handle your script. Probably. I haven’t tried it. You may end up making some fancy character escaping in order to get it to work properly, but it should be possible. If I get the chance I’ll play with it.
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @bhepler
                                            @bhepler the problem is to get the script tag evaluated, when it gets inserted as text, i have a script that is working, but still stuck on the evaluation. It’s probably easier to just create a new module, than finding another hacky workaround
                                            • 2 / 3
