    Halloween mirror ghouls anyone?
    56 Posts 18 Posters 68.0k Views 19 Watching
    • MitchfarinoM
      Mitchfarino Module Developer @yawns
      @yawns Awesome, thank you!
      • MitchfarinoM
        Mitchfarino Module Developer @bhepler
        @bhepler Is there a way to loop through a number of videos, rather than just the one on repeat?
        bheplerB 1 Reply Last reply
        • bheplerB
          bhepler Module Developer @Mitchfarino
          @Mitchfarino Presumably you can inject some scripting to define an array of video files and then call a function to play the next file in the array. If you call that function from the onended() event in the VIDEO tag you should be able to get 90% of the way there.
          MitchfarinoM 1 Reply Last reply
          • MitchfarinoM
            @bhepler Any idea how to do that?
            • bheplerB
              @Mitchfarino StackExchange had a pretty good start.
              Based upon the fact that the text value includes the HTML tag , you can probably put another tag in there to handle your script. Probably. I haven’t tried it. You may end up making some fancy character escaping in order to get it to work properly, but it should be possible. If I get the chance I’ll play with it.
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @bhepler
                @bhepler the problem is to get the script tag evaluated, when it gets inserted as text, i have a script that is working, but still stuck on the evaluation. It’s probably easier to just create a new module, than finding another hacky workaround
                • bheplerB
                  bhepler Module Developer @strawberry 3.141
                  @strawberry-3.141 You’re going to turn me into a Javascript developer with crazy talk like that.
                  • strawberry 3.141S
                    @bhepler that’s what i currently come up with
                        module: "helloworld",
                        position: "fullscreen_below",
                            text: "<video id='halloween_player'></video><script>console.log('init'); var halloween_videos = ['http://techslides.com/demos/sample-videos/small.mp4', 'http://vo.fod4.com/v/9727363b6d/v1280-q2.mp4']; var halloween_index = 0; function playHalloweenVideos(){ console.log('play'); if(halloween_index >= halloween_videos.length){ halloween_index = 0; } var player = document.getElementById('halloween_player'); player.src = halloween_videos[halloween_index++]; player.addEventListener('ended', playHalloweenVideos); player.play(); } playHalloweenVideos();</script><img src='test.png' onload='console.log(\"test\"); eval(document.getElementById(\"halloween_player\").nextSibling.innerHTML); document.removeChild(this);'"
                    but i’m not able to eval in my fake img tag, however if you enter this command in the electron console it works
                    eval(document.getElementById("halloween_player").nextSibling.innerHTML);
                    • F
                      frog
                      • F
                        frog
                        I’m trying to loop a video using the following:
                           module: ‘helloworld’,
                           position: ‘fullscreen_below’,
                              text: “<video src=‘vendor/skelloop.mp4’ autoplay loop; position:absolute; top:100%;left:50%; height:200%’></video>”
                        but it just stops after the first run. I’m using the OMXplayer which I would have thought would have taken the loop parameter - but it seems it doesn’t. Anyone have an idea how I can fix this?
                        • bheplerB
                          bhepler Module Developer @frog
                          @frog You seem to be missing the style='position... part.
                          So:
                                text: “<video src=‘vendor/skelloop.mp4’ autoplay loop style='position:absolute; top:100%;left:50%; height:200%’></video>”
                          F 1 Reply Last reply
                          Reply Quote 2
                          • F
                            frog @bhepler
                            @bhepler yup, that dit it. Thanks!
                            • N
                              nuckinfutz
                              is there a way to use a variable in the video file name? This is so close to what I want it hurts. What I want to do is play a random video from a specific location. I will be creating the videos so I will have complete control over the video naming and encoding.
                                makersworkbench
                                Sorry for resurrecting an old thread, but I have been trying to figure this out on my own for over a week now. How would I use a PING (ultrasonic) sensor to trigger the mmm-podcast module to make the jump scare happen? Python I can write but I am a javascript noob, and that is why I am having issues here.
                                So basically I want the PING sensor to trigger and play the video file full screen with audio after it senses someone x-distance away for X number of seconds. Very bad psudo code below.
                                when distance from sensor = 24-inches for 10-seconds
                                play scare animation using mmm-podcast
                                return to MagicMirror screen
                                wait 60-seconds before arming ping sensor again
                                  Bruno
                                  Guys,
                                  How did you manage to play a local video on the Pi with this module?
                                  I am trying to make the halloween ghoul video (maybe a little late). I can get some video to play if the video is online. But if the video is on a directory on my raspberry pi I can’t.
                                  In this topic all the “text” tag on the helloworld is blank because it is html tag so it gets “interpreted” by my browsers. I’ll try to post my “text” tag in non-HTML way, so you guys can analyse it (I took off the “minor than” sign from the tags: video, src and /video)
                                  Heres my config:
                                              position: "middle_center",
                                                  text: "video id=\"homevideo\" width=\"100%\" autoplay autobuffer> source src=\"http://clips.vorwaerts-gmbh.de/VfE_html5.mp4\" type=\"video/mp4\" /> /video>"
                                  Above is an example if a simples mp4 video online: http://clips.vorwaerts-gmbh.de/VfE_html5.mp4
                                  How do I change to a local mp4 file in my Pi? I tryed src="/home/pi/path/to/my/file.mp4" but no success… any ideas?
                                  S Mykle1M 2 Replies Last reply
                                    sdetweil @Bruno
                                    @Bruno said in Halloween mirror ghouls anyone?:
                                    Guys,
                                    Heres my config:
                                    Path has got to be in the mm folder tree or linked to from there
                                    /modules/module name/filename.mp4
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @Bruno
                                      If you are trying to make a module that plays local videos or if you’re just looking for a module that plays local videos then have a look at this module
                                      https://github.com/mykle1/MMM-EasyBack
                                      I just downloaded your example video and it works perfectly well with this module, locally.
                                      B B 2 Replies Last reply
                                        Bruno @Mykle1
                                        @Mykle1 said in Halloween mirror ghouls anyone?:
                                        Nice!!! I’ll give it a try. It’s nice that I can define width and height!!! Thanks!!
                                        Mykle1M 1 Reply Last reply
                                        • Mykle1M
                                          You’re welcome, mate. If you are still wanting to create your own module, feel free to take whatever you find useful from the module and use it in your own.
                                            BD0G @Mykle1
                                            @Mykle1
                                            This is so weird!
                                            I installed MMM-EasyBack as per the instructions.
                                            Copied a small Halloween Video in the MagicMirror/Modules/MMM-EasyBack/Videos folder. The file is named HalloweenMM.mp4. Its 15 MB. So pretty small.
                                            Here are my config.js entries for the module.
                                                module: 'MMM-EasyBack',
                                                position: 'middle_center',
                                                   // bgName: "Example.jpg",   // "Example.jpg", the file name of your background image (case sensitive)
                                                    videoName: "HalloweenMM.mp4",       // "baboon.mp4",         // file name of your local video
                                                    height: "1920px",    // your display's resolution in pixels. Enter in config.js
                                                    width: "1080px",     // your display's resolution in pixels. Enter in config.js
                                            I completely removed the section about Youtube ID , etc . When I launch the MM interface it contunually comes up with the YouTube Video by David Snow found here https://www.youtube.com/watch?v=So3vH9FY2H4
                                            There is no reference that I can find to that video at all.
                                            The YouTube ID that is referenced by this video is the same one that was in the original configuration file.
                                            • 2 / 3
