    Fresh Install
    49 Posts 6 Posters 18.9k Views 6 Watching
      @johnnyboy said in Fresh Install:
      @Mykle1 … Have you not made a new Tutorial on the install since last year? You’re Tutorials really helped and covered everything
      First, how the hell are you bro? Glad to see you. :-)
      No new tutorials. @sdetweil’s installers have made the need for tutorials obsolete. I use his installers myself and I highly recommend them. He is always here to support them in the unlikely event that you have trouble with them. I never have. They work flawlessly for me .
      johnnyboyJ 1 Reply Last reply Reply Quote 1
      • johnnyboyJ Offline
        johnnyboy @sdetweil
        Not possitive, but since it was last year, then version is prob 2.6?
        OS is Jessie for sure as it was built a few years back.
        It had the auto npm that always worked… but even forcing a start does nothing, and is why I assumed that the version was so out of date, it simply crashed?
        That’s me away to fire it back up and try your suggestions first, and worse case, I will start from fresh again with new OS, and your install script, and hope I can migrate my CSS stuff over from the present MM folder… which I will obviously move and rename first.
        Will update on how I got on.
          sdetweil @johnnyboy
          @johnnyboy ok, watching for your feedback
            johnnyboy @Mykle1
            @Mykle1
            Hey up Amigo… Yeah, all’s well here across the pond… how’s things with you? Hope you keeping well, and keeping yourself busy?
            Yeah, as you can tell, I aint been around here a while, and kinda lost interest in my MM, and it has been off for a year, but seems such a waste being there with all that kit inside, being nothing more that a mirror, so felt the need to re-kindle that passion I had initially with it.
            I did occasionally drop in here whenever I could, just to see you guys, and what y’all been up to… but life was just too busy and finding the time to play, was few and far between.
            Hopefully, following @sdetweil’s instructions, I will get my MM back to life, and regain my interest?
              Mykle1 Project Sponsor Module Developer @johnnyboy
              I can’t speak to your interest but you will get up and running following his directions.
                johnnyboy @sdetweil
                @sdetweil said in Fresh Install:
                Okay, I renamed original MM folder, and did your install - bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
                This took a long time and initially thought Pi had froze, so went off and did a few things.
                Came back and looked as if everything installed, and it was awaiting me to enter y/n about splashscreen/autostart… so tried to enter y… but the Pi had froze by that point.
                Pulled the power, and Pi restarted, then went to desktop, and then to MM… so I take it that all went well?
                I checked version and OS — 2.11.0… Raspbian GNU/Linux 9.11 { Stretch }
                So, is that it?.. has it all went okay? and I can now start playing about adding/changing modules?
                How do I change screen to Portrait again?
                  sdetweil @johnnyboy
                  @johnnyboy well, the last two steps didn’t finish, pm2 (autostart) and screen saver
                  u can find separate scripts on my repo for those
                  system change the screen to portrait? that changed too from boot long ago?
                  https://clevertap.com/blog/using-raspberry-pi-to-build-a-commercial-grade-wall-information-dashboard/#:~:text=To change the orientation%2C set,display_rotate%3D3 and reboot again.
                  johnnyboyJ 1 Reply Last reply Reply Quote 0
                    johnnyboy @sdetweil
                    Will do those
                    Ok, I went to the Boot/config.txt… entered the display_rotate=1 and tried to save but says cannot?
                    Rebooted but still in landscape and my entry not saved in boot.
                    Where am I going wrong?
                      sdetweil @johnnyboy
                      @johnnyboy stuff in /boot, /etc are protected, so you have to use the sudo comand
                      nano is the editor
                      sudo nano /boot/config.txt
                        johnnyboy @sdetweil
                        Sorry … I must have missed something?
                        Pi@raspberrypi:~ S sudo nano/boot/config.txt
                        sudo: nano/boot/config.txt : command not found
                        Pi@raspberrypi:~ S sudonano/boot/config.txt
                        Bash: sudonano/boot/config.tx : no such file or directory
                        • 1 / 5
