    Looking for beta testers for MMM-Remote-Control
    remote controlbetamoduledevelopment
    18 Posts 6 Posters 13.2k Views 7 Watching
    • BangeeB
      Bangee Module Developer
      I’ll join ;-)
        rvdgeer
        I’ve joined…
        Tried some and ran into some trouble…
        Will give you a more detailed report when I have the time…
        I noticed all parameters and values in config.js are wrapped in quotes…
        Maybe that’s why I’m seeing
        0|mm       | ** Message: console message: http://localhost:8080/js/main.js @38: TypeError: undefined is not an object (evaluating 'wrapper.appendChild')
        0|mm       | ** Message: console message: http://localhost:8080/js/main.js @130: TypeError: null is not an object (evaluating 'moduleWrapper.getElementsByClassName')
        The second line is repeated a couple of time (for each module?)…
        And when I tried to save eanbled/disabled modules from the remote, the pm2 logs showed an error about insufficient rights…
        Sorry for not having the error log…
        The config.js now looks like (just a small part):
        var config =
            "port": 8080,
            "kioskmode": false,
            "language": "nl",
            "timeFormat": 24,
            "units": "metric",
            "modules": [
                    "module": "MMM-Remote-Control",
                    "config": {}
                    "module": "clock",
                    "position": "top_left",
                    "header": "",
                    "config": {
                        "displayType": "digital",
                        "timeFormat": 24,
                        "displaySeconds": false,
                        "showPeriod": false,
                        "showPeriodUpper": false,
                        "clockBold": false,
                        "showDate": false,
                        "analogSize": "100px",
                        "analogFace": "simple",
                        "analogPlacement": "bottom",
                        "analogShowDate": "top",
                        "secondsColor": "#888888"
        etcetera...
        J 1 Reply Last reply
          done @Jopyth
          @Jopyth said in Looking for beta testers for MMM-Remote-Control:
          It does not show the installed modules list on smartphone in landscape?
          Exactly. I just checked again.
          I use a Galaxy S6 (just for the dimensions) and I experience that on chrome and the default browser.
          I have an idea for the reason.
          You work with something like frames.
          You have the fix navigation area with “Back”, “Brightness” etc. on top and you have a scrollable list with the installed mods below.
          When I go for landscape, there is no chance to get to the scrollable area since the fix area takes already whole of the screen.
          The solution could be to make the whole screen scrollable.
          At least for small mobile devices.
          Or you prevent the browser from going into landscape :D
          I guess this is an easy one.
          I tried to install modules. MMM-hue and FUEL worked but I had no time to configure them. But they showed on the mirror.
          Let me know if I should retry.
            Jopyth Moderator @done
            @done Yes the fixed area there takes up way to much space.
            Does it still do the restart thing? If yes, can you check the output of pm2 show mm and see if Watch & Reload is enabled? I am currently trying to figure out a way to stop pm2 from restarting on changes of files.
            D 1 Reply Last reply
              Jopyth Moderator @rvdgeer
              @rvdgeer The quotes wrapping should be ok, since whether the key of an object is wrapped in quotes or not, does not make a difference as far as I know. However something is still wrong. Are these console messages coming from your browser?
              And did the saving of hidden/shown modules work before you changed to the development branch? Did you change permissions on any folder, and do you have a dedicated user which runs you MagicMirror?
              R 1 Reply Last reply
                done @Jopyth
                I installed the new dependencies and now it seems to work. :)
                  rvdgeer @Jopyth
                  @Jopyth The console messages are from the pm2 logs…
                  I run MM as the default user (pi) and didn’t set any special rights for any folders or files…
                  Now that you mention it, it could be that the saving of the shown/hidden modules didn’t work before either.
                  BTW: I’m running MM on a Pi Zero (so using ‘serveronly’).
                  Edit: now that I think about it: I do have a HelloWorld module enabled which already used single and double quotes before. So maybe there’s a conflict with the added quotes. I will look in to this this weekend.
                  • ToastT
                    Toast
                    @Jopyth is there a possibility to include system updates in the remote ? ie “apt dist-upgrade” or whatever subsystem thats used on the system.
                      @rvdgeer Would be great to find out what causes this and hopefully fix it, however it is still not clear to me, what the reason is. I will investigate a little bit more on the weekend. Maybe I am able to reproduce the issues, could you post your node --version?
                      In the meantime you could compare your config.js and the config.js.backupX and see if you find possible differences?
                        rvdgeer
                        This morning (CET) I have a little more time to do bug reports, troubleshoot and answer some of your questions.
                        So, first things first.
                        My node version:
                        v6.8.1
                        About the config backups:
                        I noticed the that the double quotes were added to the keys and values before the backup was made.
                        This means I don’t have a backup of the true original.
                        It also means I can only compare the current config file to the backup and not the the original.
                        Another thing I noticed is that backupfile got overwritten this morning.
                        Because my MagicMirror is still a work in progress it’s powered off most of the time.
                        When I tried to reproduce the issues I came across last time I noticed that the first backup I made was saved as config.js.backup1, overwriting a previous backup.
                        At least for me this wasn;t expected behaviour and I don’t think it’s how I wish to save (or lose) my backups.
                        About saving hidden/shown modules:
                        As I said before, I haven’t set any special permisions and I’m using the default useron my Pi Zero: pi
                        Becasue there’s no keyboard and mouse attached (the Pi Zero’s micro usb port is used for a wifi dongle) I use ssh and scp (and of cource the Remote!) to do most editing, testing and troubleshooting.
                        On saving the current state of hidden/shown modules the pm2 logs reported this:
                        On hiding the helloworld module:
                        0|mm       | ** Message: console message: http://localhost:8080/modules/MMM-Remote-Control//MMM-Remote-Control.js @219: [object Object]
                        0|mm       | ** Message: console message: http://localhost:8080/js/logger.js @20: helloworld is suspended.
                        0|mm       | ** Message: console message: http://localhost:8080/js/module.js @313: TypeError: Object is not a function (evaluating 'callback()')
                        On saving the current state directly after:
                        0|mm       | Whoops! There was an uncaught exception...
                        0|mm       | { Error: EACCES: permission denied, open '/home/pi/MagicMirror/modules/MMM-Remote-Control/settings.json'
                        0|mm       |     at Error (native)
                        0|mm       |   errno: -13,
                        0|mm       |   code: 'EACCES',
                        0|mm       |   syscall: 'open',
                        0|mm       |   path: '/home/pi/MagicMirror/modules/MMM-Remote-Control/settings.json' }
                        0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        This can be reproduced every time when I follow these steps.
                        I you need any specific testing, please let me know and I’ll try to find the time.
                          rvdgeer
                          And one more.
                          On restarting I get the following error:
                          0|mm       | { Error: Command failed: pm2 restart mm
                          0|mm       |     at ChildProcess.exithandler (child_process.js:206:12)
                          0|mm       |     at emitTwo (events.js:106:13)
                          0|mm       |     at ChildProcess.emit (events.js:191:7)
                          0|mm       |     at maybeClose (internal/child_process.js:877:16)
                          0|mm       |     at Socket.<anonymous> (internal/child_process.js:334:11)
                          0|mm       |     at emitOne (events.js:96:13)
                          0|mm       |     at Socket.emit (events.js:188:7)
                          0|mm       |     at Pipe._handle.close [as _onclose] (net.js:498:12)
                          0|mm       |   killed: true,
                          0|mm       |   code: null,
                          0|mm       |   signal: 'SIGTERM',
                          0|mm       |   cmd: 'pm2 restart mm' }
                          0|mm       | Loading config ...
                          0|mm       | Loading module helpers ...
                          0|mm       | No helper found for module: helloworld.
                          0|mm       | No helper found for module: alert.
                          0|mm       | Initializing new module helper ...
                          0|mm       | No helper found for module: clock.
                          0|mm       | No helper found for module: currentweather.
                          0|mm       | No helper found for module: weatherforecast.
                          0|mm       | No helper found for module: compliments.
                          0|mm       | All module helpers loaded.
                          0|mm       | Starting server op port 8080 ...
                          0|mm       | Server started ...
                          0|mm       | Connecting socket for: MMM-Remote-Control
                          0|mm       | Starting node helper for: MMM-Remote-Control
                          0|mm       | Connecting socket for: MMM-Traffic
                          0|mm       | MMM-Traffic helper started ...
                          0|mm       | Connecting socket for: calendar
                          0|mm       | Starting node helper for: calendar
                          0|mm       | Connecting socket for: MMM-NetworkScanner
                          0|mm       | Starting module: MMM-NetworkScanner
                          0|mm       | Connecting socket for: newsfeed
                          0|mm       | Starting module: newsfeed
                          0|mm       | Sockets connected & modules started ...
                          0|mm       | Ready to go! Please point your browser to: http://localhost:8080
                          Mr.MeeseeksM 1 Reply Last reply
                            done
                            Is there any new version to test?
                              @done Kind of, yes. I think I have not fixed all mentioned errors, but hopefully the major ones. Also @Mr-Meeseeks added some new functionality (sending alerts).
                              Feel free to git pull the current status and test again. :) It should no longer mess up config.js files as much, but it still could be. It is using config.js.backupX so make manual backup somewhere else.
                              • Mr.MeeseeksM
                                Mr.Meeseeks @rvdgeer
                                @rvdgeer do you have pm2 installed and configured? Oh looked above, you do. Well I have noticed even though logs show command error, it still works, I think it’s because node doesn’t surround commands in quotes.
                                CAAAAN DOO!👍
