    Temporary disable modules
    Scheduled Pinned Locked Moved Feature Requests
    12 Posts 8 Posters 13.7k Views 6 Watching
      paviro
      Yeah exactly just re added my facial recognition module but I could not get openCV working on Sierra yet so it’s crashing and I can’t disable it without removing the config again…
      – The Doctor
      • K
        KirAsh4 Moderator
        I don’t remove config sections … I comment them out … If I’m going to edit that file to change a flag, it’s just as easy to add a /* ... */ tag around the specific section. :)
        P 1 Reply Last reply
        Reply Quote 3
          paviro @KirAsh4
          @KirAsh4 this does work inside a dictionary? Didn’t know that still I think an option would be cleaner @MichMich?
          – The Doctor
          K 1 Reply Last reply
          • K
            KirAsh4 Moderator @paviro
            > opens nearby dictionary, flips to ‘politics’, grabs red pen and writes /* ... */ around definition <
            YEP! Still works! :)
            I wasn’t referring to the actual module files. I’m talking simply editing the config.js file and comment the specific module’s config section out.
            • MichMichM
              MichMich
              Its just a js file. So you can use /* */. That’s what I do! :)
                roramirez Core Contributors
                Seem a good idea add the disabled option. In case is your write the config from other app or external system can be more cleaner add the config option instaed of commented block
                Anyway, I pushed a PR for this :) https://github.com/MichMich/MagicMirror/pull/498
                  Mitchfarino Module Developer
                  Couldn’t you just hide it with the RemoteControl?
                  [card:Jopyth/MMM-Remote-Control]
                  J 1 Reply Last reply
                    Jopyth Moderator @Mitchfarino
                    @Mitchfarino This could be an option, however it only visually looks the same.
                    If for example a module temporarily does not work for some reason (blocks the start of the mirror), hiding it with the Remote-Control would not help.
                    What you probably wanted to say is: This should also be added to the Remote Control module. ;) And I would like to include this option in the GUI for the config there. And there is a big advantage in a config option to disable a module (versus commenting out), since this leaves the values readable from other JS code, i.e. the Remote Control module.
                    M 1 Reply Last reply
                    Reply Quote 2
                      Mitchfarino Module Developer @Jopyth
                      @Jopyth Yeah, that’s exactly what I meant 😉
                      You just worded it a bit better!
                      • T
                        Tyrelex78 @paviro
                        @paviro, thank you very much, this works.
                        disabled: true,
