    MMM-WOTD
    Scheduled Pinned Locked Moved Fun & Games
    7 Posts 5 Posters 2.8k Views 5 Watching
    • cowboysdudeC Offline
      Word of the day Module for your mirror!
      See README for instructions
      Download:
      Download Here
      Version 1.0.0
      • L Offline
        lxne Project Sponsor
        Hi, I have updated my MagicMirror to 2.15.0 and then installed MMM-WOTD but I do not get any output. My MM runs with quite a view modules but MMM-WOTD won’t show up.
        According to my telegram-bot these modules are installed (MMM-WOTD is not among those):
        alert
        MMM-pages
        MMM-UpdateNotification
        MMM-TelegramBot
        MMM-Volume
        MMM-Tools
        MMM-GoogleAssistant
        MMM-Assistant2Display
        clock
        MMM-DWD-WarnWeather
        calendar
        MMM-MplayerRadio
        MMM-MusicOnDemand
        MMM-Weather
        MMM-DarkSkyForecast
        newsfeed
        MMM-NewsFeed
        MMM-GroveGestures
        In the log I can only find one line regarding MMM-WOTD and it says: [02.04.2021 21:28.53.261] [LOG] No helper found for module: MMM-WOTD.
        Any idea what might be the problem?
        Best wishes.
        bugsounetB 1 Reply Last reply Reply Quote 0
        • bugsounetB Offline
          bugsounet Banned @lxne
          @cowboysdude : you have set an error when you have created the repository …
          why WWW-WOTD ?
          in your module, you have Set MMM-WOTD
          So that why @lxne have an issue (nodule not found)
          And an error on the getDom function
              getDom: function() {
                if(this.loaded == true){
                  var wotd = this.wotd[0];
                  var wordTable = document.createElement('div');
                  if (this.config.style == 'narrow') {
                      wordTable.classList.add('narrow');
                  } else {
                      wordTable.classList.add('wide');
                  var wordTR = document.createElement('tr');
                  var word = document.createElement('td');
                  word.classList.add('bright', 'small');
                  word.setAttribute('style', 'background:' + this.config.wbackground);
                  word.innerHTML = "Word  ";
                  wordTR.appendChild(word);
                  var word2 = document.createElement('td');
                  word2.classList.add('small');
                  word2.setAttribute("style", "color:" + this.config.word + "; background-color: " + this.config.dbackground + ";");
                  word2.innerHTML = wotd.word;
                  wordTR.appendChild(word2);
                  wordTable.appendChild(wordTR);
                  var wordTR2 = document.createElement('tr');
                  var wordd = document.createElement('td');
                  wordd.classList.add('bright', 'small');
                  wordd.setAttribute('style', 'background:' + this.config.wbackground);
                  wordd.innerHTML = "Meaning  ";
                  wordTR2.appendChild(wordd);
                  var wordd2 = document.createElement('td');
                  wordd2.classList.add('small');
                  wordd2.setAttribute('style', 'color:' + this.config.definition + '; background-color: ' + this.config.dbackground + ';');
                  wordd2.innerHTML = wotd.definition;
                  wordTR2.appendChild(wordd2);
                  wordTable.appendChild(wordTR2);
                  var wordTR3 = document.createElement('tr');
                  var wordf = document.createElement('td');
                  wordf.classList.add('bright', 'small');
                  wordf.setAttribute('style', 'background:' + this.config.wbackground);
                  wordf.innerHTML = "Say  ";
                  wordTR3.appendChild(wordf);
                  var wordf2 = document.createElement('td');
                  wordf2.setAttribute('style', 'color:' + this.config.say + '; background-color: ' + this.config.dbackground + ';');
                  wordf2.classList.add('small');
                  wordf2.innerHTML = wotd.pronunciation;
                  wordTR3.appendChild(wordf2);
                  wordTable.appendChild(wordTR3);
                  wrapper.appendChild(wordTable);
                return wrapper;
          • wow … tr/td tag like win95 ???, i think, you can do better !
          • I have corrected your error… you have not created the Dom on first request
          • package.json missing ! (if an user do npm install … it will install MagicMirror !)
          @lxne: for a temp resolve, just rename WWW-WOTD in modules directory to MMM-WOTD
            cowboysdude Module Developer @bugsounet
            V2 is out!
            Changes have been done to conform with the non use of request :)
            It uses Axios now.
            All updates files including new package.json file are there.
            https://github.com/cowboysdude/WWW-WOTD
              JohnGalt @cowboysdude
              @cowboysdude Did you intend to call this module “WWW-WOTD” instead of the standard “MMM-…” ??
              I downloaded it, it installed itself as “WWW-WOTD” and it does not run. I did not delve into the code, but suspect the non-standard name may be spread through the code.
              Any thoughts?
                sdetweil @JohnGalt
                @JohnGalt the repo name is right …
                maybe the git repo inside is wrong
                do this
                git clone https://github.com/cowboysdude/MMM-WOTD MMM-WOTD
                  JohnGalt @sdetweil
                  @sdetweil Sam-thanks. It does load now. I’ll have to go back and [re-]learn some css to get it to fit in with the other modules, as it is way too tall, but this is progress. Thanks again
