    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 713.6k Views 57 Watching
    • swvalentiS
      swvalenti Project Sponsor @j.e.f.f
      @j-e-f-f did you see my previous post is that at all doable?
        motdog @j.e.f.f
        @j-e-f-f yep the website where i got the coordinates was wrong. Every other one had the minus sign. Thanks for the extra eyes.
          blackeaglece @motdog
          Hi everyone, I’ve been using this module for more than a year and it’s fine, but since I did the last update of MM I get the {DEGREE} entry after perceived (as you can see from the attached image), I’ve also updated the module but nothing to do. How can I do to remove it? Thank you very much
            miniashman
            Can someone guide me on how to get the weather icon enabled next to the current temperature, please? Gone through the topic but no one else seems to have this issue.
            J StoffbeuteluweS 2 Replies Last reply Reply Quote 0
            • cowboysdudeC
              cowboysdude Module Developer @MajorC
              @majorc It would be :)
                blackeaglece
                  blackeaglece @blackeaglece
                  @blackeaglece said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                  Does anyone know how I can solve this problem?
                  Thank you
                  J ? 2 Replies Last reply Reply Quote 0
                  • F
                    fillilutten
                    Any way to change the order of the different extraCurrentConditions?
                    • F
                      fillilutten
                      Oh, two more things. What css do I do to change color of the slash in H/L in “extraCurrentConditions” ?
                      And can I remove “Powered by OpenWeather”? I have such a small screen so have to remove even the smallest of things.
                        j.e.f.f Project Sponsor Module Developer @blackeaglece
                        @blackeaglece that’s not my weather module. You’re using a different one. Not sure which.
                          j.e.f.f Project Sponsor Module Developer @swvalenti
                          @swvalenti unfortunately, the provider has put “Special weather statement” into the title field and the actual title as part of the description. To get that to show a different colour it would require extra processing to split on the ... character.
                          Having seen a few weather alerts from other regions I can say it’s not commonly done the same way as yours. I don’t know what might break as a result of formatting that way for you.
                          If you’re up for it, you can modify my code for your needs. Most of this prefornatting is in the main MMM-OpenEeatherForecast.js file
                            j.e.f.f Project Sponsor Module Developer @miniashman
                            @miniashman A couple of ways, yes:
                            By default, the animated icon set is used for the large icon beside the current temperature. I’ve found from my testing that sometimes this the code calls for the icon to render before it is ready to do so, and just shows up blank as you see above. There is a configuration parameter to add a delay to animated icon rendering. Use it in your config as follows:
                              animatedIconStartDelay: 1500,
                            This parameter defaults to 1000 (milliseconds) so it looks like you’ll need to experiment with numbers larger than that.
                            Alternatively If you don’t care about the animated icon, then you can turn it off altogether in your config:
                              useAnimatedIcons: false,
                            This will use the static icon set for everything, and you won’t need to play around with the animatedIconStartDelay config parameter.
                              j.e.f.f Project Sponsor Module Developer @fillilutten
                              @fillilutten said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                              This is technically possible with CSS, but it’s likely more trouble than it’s worth for me to explain it here, and error prone. A better and easier option for you would be to modify the mmm-openweather-forecast.njk file to reorder these items as you like.
                              Starting on line 39 you’ll see the templates for the extra current conditions. The order in which they appear here is the order in which they appear in the module.
                              Here are the first several lines of that section:
                              {# -------------- Extra Current Conditions -------------- #}
                                  {% if config.showExtraCurrentConditions %}
                                    <div class="extra-current-conditions-wrapper small bright">
                                      {# -- High / Low Temp -- #}
                                      {% if config.extraCurrentConditions.highLowTemp %}
                                        <span class="temperature-container">
                                          <span class="high-temperature">{{ forecast.currently.tempRange.high }}</span>
                                          <span class="temperature-separator dimmed">/</span>
                                          <span class="low-temperature">{{ forecast.currently.tempRange.low }}</span>
                                        </span>
                                      {% endif %}
                                      {# -- Sunrise -- #}
                                      {% if config.extraCurrentConditions.sunrise %}
                                      <span class="sunrise-container">
                                        <img class="inline-icon sunrise-icon" src="{{ inlineIcons.sunrise }}" />
                                        {{ forecast.currently.sunrise }}
                                      </span>
                                      {% endif %}
                                      {# -- Sunset -- #}
                                      {% if config.extraCurrentConditions.sunset %}
                                      <span class="sunset-container">
                                        <img class="inline-icon sunset-icon" src="{{ inlineIcons.sunset }}" />
                                        {{ forecast.currently.sunset }}
                                      </span>
                                      {% endif %}
                              Say you wanted the Hi / Lo temps to display after sunrise / sunset, just move the whole block as follows:
                                      {# -- Sunrise -- #}
                                      </span>
                                      {% endif %}
                                      {# -- Sunset -- #}
                                      </span>
                                      {% endif %}
                                        </span>
                                      {% endif %}
                              Keep in mind that doing this will make it a touch more difficult to update my module as I release updates. When you want to update, you’ll need to to the following:
                              1. Make a backup of your modified mmm-openweather-forecast.njk file (copy it to another location, for example)
                              2. Restore the original with git checkout mmm-openweather-forecast.njk
                              3. Update the code with git pull
                              4. Restore your modified version of mmm-openweather-forecast.njk from your backup
                                Yes:
                                .MMM-OpenWeatherForecast .temperature-container .temperature-separator,
                                .MMM-OpenWeatherForecast .forecast-container .forecast-item .temperature-container .temperature-separator {
                                  color: #FF0000; /* makes it red */
                                Yes.
                                .MMM-OpenWeatherForecast .attribution {
                                  display: none;
                                  j.e.f.f Project Sponsor Module Developer @pwalsh2202
                                  @pwalsh2202 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                  I’m looking to see if I can get just a truncated text-based description of the upcoming weather.
                                  I’d like to see this too. The DarkSky API had this and it’s the one thing I really miss with switching over to OpenWeather. My guess is that in order to do this I’d need to create a special formatter that generates a detailed summary based on the weather data available. Say the API returned a wind speed of over 10mph, gusts reaching 30mph… I could generate a phrase like “It’s windy today with gusts reaching 30mph.”
                                  This looks like a significant time commitment that I just don’t have. I would need to come up with all of the thresholds of the weather data that would trigger such phrases, create phrase templates, choose how they should be ordered, and then worry about translation for all of the languages MM supports. As it is I barely have an hour or two on the weekend to dedicate answering forum questions on this module and fixing any bugs.
                                  If anyone else is willing to do this, I’d gladly welcome the pull request into my code.
                                  The best my module can currently do to address your ask is to configure the module to only show the current conditions and the extra current conditions (which give you the summary in icon/metric format). You can turn off the hourly and daily forecasts if you like. Take a look through the README.md file with outlines all of the configuration options for this module.
                                    pwalsh2202 @j.e.f.f
                                    @j-e-f-f - Thanks for responding. I wasn’t sure if this was something their API auto-configured or not. I didn’t mean to ask so much work of you but thought there might be a part of their API I missed. I just last night managed to get what I needed with a really basic “(Description) currently. The high will be (high temp) and the low will be (low temp.”
                                    Thank you for all your work on this. You saved me a ton of time by using your module as a base.
                                      miniashman @j.e.f.f
                                      @j-e-f-f Thank you it worked just the way I wanted it. Appreciate it :oncoming_fist:
                                      • StoffbeuteluweS
                                        Stoffbeuteluwe Project Sponsor @miniashman
                                        @miniashman
                                        hi… how can I get the C for Celsius behind the degree, on my mirror I only have the number …
                                        BKeyportB M 2 Replies Last reply Reply Quote 0
                                        • BKeyportB
                                          BKeyport Module Developer @Stoffbeuteluwe
                                          Actually, I’d like the F for F#@(%**&@ stupid measurements, for mine too.
                                            miniashman @Stoffbeuteluwe
                                            @stoffbeuteluwe In the custom.css i added the following:
                                            .MMM-OpenWeatherForecast .current-conditions-wrapper .current.temperature:after {
                                                content: "C";
                                            .MMM-OpenWeatherForecast .extra-current-conditions-wrapper  . temperature-container . high-temperature:after,
                                            .MMM-OpenWeatherForecast .extra-current-conditions-wrapper  . temperature-container . low-temperature:after {
                                                content: "C";
                                            .MMM-OpenWeatherForecast .forecast-item.daily .high-temperature:after,
                                            .MMM-OpenWeatherForecast .forecast-item.daily .low-temperature:after {
                                                content: "C";
                                            You can change “C” to “F” if needed depending on which units you want to use.
                                            StoffbeuteluweS J 2 Replies Last reply Reply Quote 0
                                            • 12
                                            • 13
                                            • 4 / 13
