    Magic Mirror Redesign WIP :D
    Scheduled Pinned Locked Moved Showcase
    47 Posts 21 Posters 50.8k Views 26 Watching
      RuKeBo
      The only reason disabling the “updatenotification” module helps is because it is set to a location of “top_bar”, removing it allows everything to move over. I tracked this down to the CSS of course. He basically removed all region stuff and put in only two grid tags. The problem is that there is a div for “top_bar” (not to be confused with the location top_bar), then a container in that, with top_left, top_middle, and top_right within that. The container tag is for the top_bar. Since there is only one CSS tag for each of the top and bottom bars, nothing says to do anything special with the top_bar location so the top_bar is not separate from the top left middle and right. When a grid is used, everything just populates the grid, the top_bar is not separated from the top left, middle and right. This sort of confusing since the top_bar div contains “container”, “top_left”, “top_middle”, and “top_right”. I should say it confuses me, probably doesn’t confuse anyone who knows what they are doing. It’s just that if you style top_bar, it affects “top_bar”, “top_right”, “top_middle”, and “top_left”. It appears you need to style the container.
      Again, just an observation looking at it in dev view, I don’t really know how it works. I was able to get it to work by using a “grid-area” for the container and setting it to span one row and 3 columns for the top and bottom containers. I don’t know if this really will break if other modules are added to other locations or more than one module is added to a particular location.
      • I
        Ihnen42
        Hi, the region bottom bar has four elements. The bottom bar, the bottom left, the bottom center and the bottom right. Since they are in a grid with thirds, one always get pushed to the next row. Since I only use the bottom bar and not the left/center/right I changed the grid-template-columns: 100% 0% 0% 0%; So the bar is 100% and the rest each 0%.
        • E
          earlman
          HI GUYS,
          Sorry I’ve been MIA. Recently moved to a new condo, so I’ve been busy with that. Finally have some time to take a look at this, so expect some updates in the near future.
          Thank you all for the interest ☺
          • E
            earlman @dbinott
            @dbinott @jcmd13 @RuKeBo @Mykle1
            Add
            .top.bar > .container {
                grid-column: 1 / -1;
            to your main.css.
            I think that’ll do the trick. I don’t have any modules with notifications installed atm, so if somebody could post a screenshot of how that looks (after adding the above CSS), it would be a big help
            • E
              earlman
              @aarish could you post some screenshots?
              I’ve updated the main.css file here:
              https://github.com/foundations-design/WhiteLight/blob/master/css/main.css
              I think the part that’s relevant to your issue is from “Layout Stuff” down (line 144 in the main.css file)
              B 1 Reply Last reply
                BravoOscar @earlman
                @earlman
                As you can see, the top_bar and bottom_bar dosent work.
                The calender should be in the bottom_bar and the stock should be in the top_bar
                • E
                  earlman
                  @bravooscar
                  thanks for the screenshot. try using this css for your main.css
                  :root {
                      /**** COLOR ****/
                      --color-text: #fff;
                      --color-background: black;
                      /**** TYPOGRAPHY ****/
                      --font-primary: "Roboto Condensed";
                      --font-secondary: "Roboto";
                      --base: 20px;
                      --text-scale: 1.5;
                      --text-xs: calc(var(--base) / var(--text-scale));
                      --text-sm: var(--base);
                      --text-md: calc(var(--text-sm) * var(--text-scale));
                      --text-lg: calc(var(--text-md) * var(--text-scale));
                      --text-xl: calc(var(--text-lg) * var(--text-scale));
                      --text-2xl: calc(var(--text-xl) * var(--text-scale));
                      --text-3xl: calc(var(--text-2xl) * var(--text-scale));
                      /**** SPACING ****/
                      --grid-gap: 1rem;
                      --outside-margin: 4rem;
                  html {
                    cursor: none;
                    overflow: hidden;
                    background: var(--color-background);
                    user-select: none;
                    font-size: var(--base);
                  ::-webkit-scrollbar {
                    display: none;
                  body {
                    color: var(--color-text);
                    font-family: var(--font-primary), sans-serif;
                    font-weight: 400;
                    line-height: 1.5;
                    margin: 0;
                    -webkit-font-smoothing: antialiased;
                   * Default styles.
                  .dimmed {
                    opacity: 0.4;
                  .normal {
                    opacity: 0.7;
                  .bright {
                    opacity: 1;
                  .xsmall {
                    font-size: var(--text-xs);
                    line-height: 1.4;
                  .small {
                    font-size: var(--text-sm);
                    line-height: 1.4;
                  .medium {
                    font-size: calc(var(--text-md));
                    line-height: 1.4;
                  .large {
                    font-size: calc(var(--text-lg));
                    line-height: 1;
                  .xlarge {
                    font-size: calc(var(--text-xl));
                    line-height: 1;
                    letter-spacing: -3px;
                  .thin {
                    font-family: var(--font-secondary), sans-serif;
                    font-weight: 100;
                  .light {
                    font-weight: 300;
                  .regular {
                    font-weight: 400;
                  .bold {
                    font-weight: 700;
                  .align-right {
                    text-align: right;
                  .align-left {
                    text-align: left;
                  header {
                    text-transform: uppercase;
                    font-size: 1rem;
                    font-family: var(--font-primary), Arial, Helvetica, sans-serif;
                    font-weight: 400;
                    border-bottom: 1px solid #666;
                    line-height: 15px;
                    padding-bottom: 5px;
                    margin-bottom: 10px;
                    color: #999;
                  sup {
                    font-size: 50%;
                    line-height: 50%;
                   * Module styles.
                  .module {
                    margin-bottom: 30px;
                  .region.bottom .module {
                    margin-top: 30px;
                    margin-bottom: 0;
                  .no-wrap {
                    white-space: nowrap;
                    overflow: hidden;
                    text-overflow: ellipsis;
                  .pre-line {
                    white-space: pre-line;
                   * LAYOUT STUFF
                  .region {
                    width: 100%;
                  .region.fullscreen {
                    position: absolute;
                    height: 100vh;
                    width: 100vw;
                    top: 0;
                    left: 0;
                    right: 0;
                    bottom: 0;
                    z-index: -1;
                    pointer-events: none;
                  .region.fullscreen * {
                    pointer-events: auto;
                  .region table {
                    width: 100%;
                    border-spacing: 0;
                    border-collapse: separate;
                  body {
                    display: grid;
                    grid-gap: var(--grid-gap);
                    grid-template-rows: repeat(5, minmax(0, max-content));
                    padding: var(--outside-margin);
                    place-items: stretch;
                    height: 100vh;
                  .top.bar {
                    display: grid;
                    grid-template-columns: repeat(3, 1fr);
                  .bottom.bar {
                    display: grid;
                  .bottom.bar > .container {
                  .left {
                    grid-column: 1 / 2;
                  .right {
                    grid-column: -1 / -2;
                  .region {
                    /* for testing */
                    /* border: 1px solid white;  */
                    BravoOscar @earlman
                    @earlman
                    Tryed the new main.css
                    Stock i working, it should be “top_bar”.
                    Calender should be position: “bottom_bar”, under travle time, but bottom_bar is over bottom_left, bottom_center and bottom_right
                    E 1 Reply Last reply
                    • E
                      earlman @BravoOscar
                      @bravooscar
                      try this:
                      :root {
                        /**** COLOR ****/
                        --color-text: #fff;
                        --base: 20px;
                        --text-scale: 1.5;
                        /**** SPACING ****/
                        --grid-gap: 1rem;
                      html {
                        cursor: none;
                        overflow: hidden;
                        user-select: none;
                        display: none;
                      body {
                        font-weight: 400;
                        line-height: 1.5;
                        margin: 0;
                       * Default styles.
                      .dimmed {
                        opacity: 0.4;
                      .normal {
                        opacity: 0.7;
                      .bright {
                        opacity: 1;
                      .xsmall {
                        line-height: 1.4;
                      .small {
                        line-height: 1.4;
                      .medium {
                        line-height: 1.4;
                      .large {
                        line-height: 1;
                      .xlarge {
                        line-height: 1;
                      .thin {
                        font-weight: 100;
                      .light {
                        font-weight: 300;
                      .regular {
                        font-weight: 400;
                      .bold {
                        font-weight: 700;
                      .align-right {
                        text-align: right;
                      .align-left {
                        text-align: left;
                      header {
                        font-size: 1rem;
                        font-weight: 400;
                        line-height: 15px;
                        color: #999;
                      sup {
                        font-size: 50%;
                        line-height: 50%;
                       * Module styles.
                      .module {
                        margin-top: 30px;
                        margin-bottom: 0;
                      .no-wrap {
                        overflow: hidden;
                      .pre-line {
                       * LAYOUT STUFF
                      .region {
                        width: 100%;
                        position: absolute;
                        height: 100vh;
                        width: 100vw;
                        top: 0;
                        left: 0;
                        right: 0;
                        bottom: 0;
                        z-index: -1;
                      .region table {
                        width: 100%;
                        border-spacing: 0;
                      body {
                        display: grid;
                        height: 100vh;
                      .top.bar {
                        display: grid;
                      .bottom.bar {
                        display: grid;
                        grid-row: 2;
                      .bottom.bar > .bottom {
                          grid-row: 1;
                      .left {
                        grid-column: 1 / 2;
                      .right {
                      /* for testing */
                      .region {
                      • A
                        aarish
                        • A
                          aarish
                          @earlman The redesign looks really cool and I love the concept you are going for. I wanted to try it on my mirror however I could not access the notion page with the set up instructions as it says I don’t have access. Is their another place with the instruction?
                            MDLefevere @earlman
                            @earlman Can we get that wallpaper :astonished_face: ?? (with the mountain)
                              MDLefevere
                              @cowboysdude
                              I’ve found it and uploaded it. Not huge but for a 24" it’s fine.
                              Click
                              • cowboysdudeC
                                cowboysdude Module Developer @MDLefevere
                                @mdlefevere Thank you!
                                • JalibuJ
                                  Jalibu Module Developer
                                  Hi @earlman,
                                  I am impressed by your redesign.
                                  I registered on notion.so but can not access your guide :-/
                                  • E
                                    earlman @Jalibu
                                    @jalibu @aarish
                                    Appreciate the interest! Here’s the Notion page.
                                    Let me know if something’s not working. The instructions haven’t been updated in a while.
                                    H 1 Reply Last reply
                                    • H
                                      huz360 @earlman
                                      @earlman hi, i cant access the guide
                                        Chazzer @earlman
                                        @earlman great work, this looks really good.minimalist and clean
                                        • 2 / 3
