    MM-Navbar - Navigation Bar for Touchscreens to hide/show modules
    47 Posts 11 Posters 52.7k Views 15 Watching
    • tidus5T
      tidus5 @chrisyy
      @chrisyy i think you can list all the modules yes but how to attribut the good icon?
      i will check for hide the module on startup tonight - i let you know if i find something
      Reply Quote 2
        chrisyy
        Thanks for ur Picture. Mine is looking similar.
        Thats the next thing i thought about. U got all modules, but still u need a text file or sth with a module -> Icon categorization.
        My tries to hide all modules on startup were leading to a totally black screen.
        @tidus5 can I use the picture for github?
        tidus5T 1 Reply Last reply
        • tidus5T
          tidus5 @chrisyy
          @chrisyy yes of course :-)
          • cowboysdudeC
            cowboysdude Module Developer @tidus5
            @tidus5 VERY excellent!! Thank you… I can use that :)
              chrisyy
              i added the code to hide all modules on startup :)
              • tidus5T
                tidus5 @chrisyy
                @chrisyy
                pretty cool
                im using your code
                MM.getModules().exceptModule(this).exceptWithClass(‘clock’).enumerate(function(module){
                module.hide(1000, function(){
                to create an icon to hide or show all
                for now i can only show all - cant hide all after.
                did you plan to work on that ?
                  chrisyy
                  Its a possibility.
                  Think u are missing a toggle there, i can build u one later and update it.
                    chrisyy
                    @tidus5
                    Can u try this?
                    var hideallmodules = true;
                    var hideallmodulesbutton = document.createElement(“span”);
                    hideallmodulesbutton.className = “wi wi-day-rain-mix navbar”; // change icon here
                    wrapper.appendChild(hideallmodulesbutton);
                    $(hideallmodulesbutton).on(“click”, function(){
                    if(hideallmodules){
                    module.show(1000, function(){
                    hideallmodules = false;
                    }else{
                    this is a bit messy, but should work as the rest of the buttons. will publish it to git, when i got time.
                    • tidus5T
                      tidus5 @chrisyy
                      @chrisyy Hello
                      amazing!!! thank you
                      just small error added exceptWithClass(‘MM-navbar’) (exceptmodule(this)) didnt work (the nav itself was hidden)
                      thank you so much
                      	$(hideallmodulesbutton).on("click", function(){
                      		if(hideallmodules){
                      			MM.getModules().exceptWithClass('MM-navbar').exceptWithClass('clock').enumerate(function(module){
                      		}else{
                      • tidus5T
                        tidus5
                        @chrisyy yop everything is working perfectly
                        i added a timing of 1000 on every hide/show
                        without i had a little ugly mouvement sometimes :-)
                        again thanks you !!!
                        • TheHyp3T
                          TheHyp3
                          What a great module! Is there a way to get the icons centerd? I´m using a 7" touchscreen display and it looks like the picture below:
                          If I would add more icons they go in a line below.
                          • tidus5T
                            tidus5 @TheHyp3
                            @TheHyp3
                            Hello
                            in navbar.css you can play with
                            .center{
                            position: fixed;
                            left: 45%;
                            • personnaly i removed this class
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @tidus5
                              @tidus5 its never a good idea to manipulate modules code, but after reviewing this module there is no chance to avoid it to have custom buttons. The module owner should change this to config options.
                              I came up with this solution to center them
                              custom.css
                              .MM-navbar .center {
                                left: 50%;
                                -webkit-transform: translate(-50%);
                                chrisyy
                                I have already tested some things and still didnt update and pushed to git.
                                The problem with the creation of buttons out of the config is a for/while that still doesn’t work. Also i would need a library for icons.
                                Ur proplem was indeed an issue, will fix this within git.
                                • TheHyp3T
                                  TheHyp3
                                  @strawberry-3.141 did a little change on my custome.css in MagicMirror/css. Now its working very well.
                                  Heres the code:
                                  width: 100%;
                                  text-align: center;
                                  left: 0px;
                                    shashank @chrisyy
                                    @chrisyy hi, i installed this module works great, how can i toggle between 2 same modules, example MMM-mails i need to toggle emails between gmail and hotmail , gmail to show hotmail to hide and vice versa
                                    • tidus5T
                                      tidus5
                                      Hey @chrisyy - hope you are well.
                                      Since the update i have a problem with the hide/show all butt - function not recognized in this line
                                      			MM.getModules().exceptWithClass('MM-navbar').exceptWithClass('MMM-ShipmentTracking').exceptWithClass('clock').enumerate(function(module){
                                      and now the weather and the current weather are not hide at startup - do you have the same problem ?
                                        chrisyy @shashank
                                        @shashank u would need to have 2 of them installed, lets say one is Mail-Gmail, the second is Mail-Hotmail
                                        @tidus5 until now i haven’t tested it and im moving to a new place, so i my mirror aswell as my server is laying in a box right now. I saw that in the new version, there are visibility-locking options. Maybe this will have to do something with it. As soon as it is possible for me to do something, i will take a look and hopefully can fix this.
                                        second thing: u should not make 3x exceptwithclass, do one and separate the modules with commata.
                                        AlessandroRaA 1 Reply Last reply
                                        • in_a_daysI
                                          in_a_days
                                          I think this module is very cool! My present build is non-touch so I made some small additions (informed by @GinSeng in another thread) and I’m currently using voice to trigger the Navbar. Love it! I’ll be happy to provide code or details if anybody is interested.
                                            shashank @in_a_days
                                            @in_a_days hi, can you please share the code
                                            in_a_daysI 1 Reply Last reply
