    MM-Navbar - Navigation Bar for Touchscreens to hide/show modules
    47 Posts 11 Posters 52.5k Views 15 Watching
    • tidus5T
      tidus5 @chrisyy
      @chrisyy yes of course :-)
      • cowboysdudeC
        cowboysdude Module Developer @tidus5
        @tidus5 VERY excellent!! Thank you… I can use that :)
          chrisyy
          i added the code to hide all modules on startup :)
          tidus5T 1 Reply Last reply
          • tidus5T
            tidus5 @chrisyy
            @chrisyy
            pretty cool
            im using your code
            MM.getModules().exceptModule(this).exceptWithClass(‘clock’).enumerate(function(module){
            module.hide(1000, function(){
            to create an icon to hide or show all
            for now i can only show all - cant hide all after.
            did you plan to work on that ?
              chrisyy
              Its a possibility.
              Think u are missing a toggle there, i can build u one later and update it.
                chrisyy
                @tidus5
                Can u try this?
                var hideallmodules = true;
                var hideallmodulesbutton = document.createElement(“span”);
                hideallmodulesbutton.className = “wi wi-day-rain-mix navbar”; // change icon here
                wrapper.appendChild(hideallmodulesbutton);
                $(hideallmodulesbutton).on(“click”, function(){
                if(hideallmodules){
                module.show(1000, function(){
                hideallmodules = false;
                }else{
                this is a bit messy, but should work as the rest of the buttons. will publish it to git, when i got time.
                • tidus5T
                  tidus5 @chrisyy
                  @chrisyy Hello
                  amazing!!! thank you
                  just small error added exceptWithClass(‘MM-navbar’) (exceptmodule(this)) didnt work (the nav itself was hidden)
                  thank you so much
                  	$(hideallmodulesbutton).on("click", function(){
                  		if(hideallmodules){
                  			MM.getModules().exceptWithClass('MM-navbar').exceptWithClass('clock').enumerate(function(module){
                  		}else{
                  • tidus5T
                    tidus5
                    @chrisyy yop everything is working perfectly
                    i added a timing of 1000 on every hide/show
                    without i had a little ugly mouvement sometimes :-)
                    again thanks you !!!
                    • TheHyp3T
                      TheHyp3
                      What a great module! Is there a way to get the icons centerd? I´m using a 7" touchscreen display and it looks like the picture below:
                      If I would add more icons they go in a line below.
                      • tidus5T
                        tidus5 @TheHyp3
                        @TheHyp3
                        Hello
                        in navbar.css you can play with
                        .center{
                        position: fixed;
                        left: 45%;
                        • personnaly i removed this class
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @tidus5
                          @tidus5 its never a good idea to manipulate modules code, but after reviewing this module there is no chance to avoid it to have custom buttons. The module owner should change this to config options.
                          I came up with this solution to center them
                          custom.css
                          .MM-navbar .center {
                            left: 50%;
                            -webkit-transform: translate(-50%);
                            chrisyy
                            I have already tested some things and still didnt update and pushed to git.
                            The problem with the creation of buttons out of the config is a for/while that still doesn’t work. Also i would need a library for icons.
                            Ur proplem was indeed an issue, will fix this within git.
                            • TheHyp3T
                              TheHyp3
                              @strawberry-3.141 did a little change on my custome.css in MagicMirror/css. Now its working very well.
                              Heres the code:
                              width: 100%;
                              text-align: center;
                              left: 0px;
                                shashank @chrisyy
                                @chrisyy hi, i installed this module works great, how can i toggle between 2 same modules, example MMM-mails i need to toggle emails between gmail and hotmail , gmail to show hotmail to hide and vice versa
                                C 1 Reply Last reply
                                • tidus5T
                                  tidus5
                                  Hey @chrisyy - hope you are well.
                                  Since the update i have a problem with the hide/show all butt - function not recognized in this line
                                  			MM.getModules().exceptWithClass('MM-navbar').exceptWithClass('MMM-ShipmentTracking').exceptWithClass('clock').enumerate(function(module){
                                  and now the weather and the current weather are not hide at startup - do you have the same problem ?
                                    chrisyy @shashank
                                    @shashank u would need to have 2 of them installed, lets say one is Mail-Gmail, the second is Mail-Hotmail
                                    @tidus5 until now i haven’t tested it and im moving to a new place, so i my mirror aswell as my server is laying in a box right now. I saw that in the new version, there are visibility-locking options. Maybe this will have to do something with it. As soon as it is possible for me to do something, i will take a look and hopefully can fix this.
                                    second thing: u should not make 3x exceptwithclass, do one and separate the modules with commata.
                                    AlessandroRaA 1 Reply Last reply
                                    • in_a_daysI
                                      in_a_days
                                      I think this module is very cool! My present build is non-touch so I made some small additions (informed by @GinSeng in another thread) and I’m currently using voice to trigger the Navbar. Love it! I’ll be happy to provide code or details if anybody is interested.
                                        shashank @in_a_days
                                        @in_a_days hi, can you please share the code
                                        in_a_daysI 1 Reply Last reply
                                        • AlessandroRaA
                                          AlessandroRa @chrisyy
                                          Hi @chrisyy thank you for this awesome module!
                                          Only problem is that with this module on, the Hide/show all module disappeared. How can I fix it?
                                          Thanks!
                                          • in_a_daysI
                                            in_a_days @shashank
                                            @shashank
                                            For sure. Forgive me if there are several steps.
                                            First thing is to install this module
                                            https://github.com/alexyak/voicecontrol
                                            Go to your MagicMirror/modules folder and type
                                            git clone https://github.com/alexyak/voicecontrol.git
                                            Then install dependencies with
                                            sudo apt-get install python-pyaudio python3-pyaudio sox
                                            Next, install the navbar. Again, make sure you are in the MagicMirror/modules folder and type
                                            git clone https://github.com/chr1syy/MM-navbar.git
                                            Then you will need to go to this website and define your voice commands.
                                            https://snowboy.kitt.ai/
                                            Keep track of the keywords you define and the filenames you produce. Each keyword/command will require you to download a .pmdl file that needs to be copied into the MagicMirror folder on your Pi. I’m only using 3 commands so far - calendar, newsfeed, and weather.
                                            Still with me? Sweet! Lets configure config.js. Go to the MagicMirror/config folder and
                                            nano config.js
                                            Assuming you know where to place a new module in this file, add the navbar module with
        module: 'MM-navbar',
        position: 'fullscreen_above'
                                            Next we will add the voice control call to the same config.js file. There are a couple variables here that will depend on the keywords and filenames you used on the snowboy site. Here is the code I use
        module: 'voicecontrol',
        position: 'bottom_right',
        models: [
        keyword: "Calendar",
        description: "Say 'Calendar' to toggle display",
        file: "calendar.pmdl",
        message: "CALENDAR"
        keyword: "Newsfeed",
        description: "Say 'Newsfeed' to toggle display",
        file: "newsfeed.pmdl",
        message: "NEWSFEED"
        keyword: "Weather",
        description: "Say 'Weather' to toggle display",
        file: "weather.pmdl",
        message: "WEATHER"
                                            Note that the keyword and file need to match the keyword and filenames you used on your Snowboy files. Save and quit out of config.js and we’ll hit the last step. We need to make a couple changes to the navbar code. Navigate to MagicMirror/modules/MM-navbar then
                                            nano MM-navbar.js
                                            First change is at line 13. Right now lines 12-19 look like this
                                            notificationReceived: function(notification, payload, sender){
                                            	if (notification === 'DOM_OBJECTS_CREATED'){
                                            		MM.getModules().exceptModule(this).exceptWithClass('clock').enumerate(function(module){
                                            You will need to modify it to look like this
                                                        if (notification === "CALENDAR"){
        var calendarbutton = document.getElementById('calendar-button');
        calendarbutton.click();
                                                        if (notification === "NEWSFEED"){
        var newsbutton = document.getElementById('news-button');
        newsbutton.click();
                                                        if (notification === "WEATHER"){
        var weatherbutton = document.getElementById('weather-button');
        weatherbutton.click();
                                            Now we’re going down to the section that originally starts on line 32
                                            	wrapper.className = "center";
                                            	weatherbutton.className = "wi wi-day-rain-mix navbar";
                                            	calendarbutton.className = "fa fa-calendar navbar";
                                            	newsbutton.className = "fa fa-newspaper-o navbar";
                                            And change it to
                                                        weatherbutton.id = 'weather-button';
                                                        calendarbutton.id = 'calendar-button';
                                                        newsbutton.id = 'news-button';
                                            Save, close and restart your MM and you should have a working, voice responsive nav bar. I know there are kind of a lot of steps here and typos and omissions are entirely possible. If you have any problems let me know and I’ll try to help. Cheers!
                                            C S 2 Replies Last reply
