    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 553.6k Views 29 Watching
    • Z
      Zoltan @trividar
      @trividar The module works fine if you use the moon pictures that comes with the installation (The temporary fix method). My country is blocked from the navy site so that never worked for me historically
      T 1 Reply Last reply
      • T
        trividar @Zoltan
        @zoltan Thanks thank you for your answer, you are right the module works perfectly.
        Just one more question, how can I set it up, that the information (just next full moon date) is unter the moon picture not on the left side inside the moon?
        Thank you
        Z 1 Reply Last reply
        • Z
          Zoltan @trividar
          @trividar I am not too sure on that one.
          One thing that you can be on the lookout with this module is the following. There is two pictures missing if i remember correctly. You will have to edit your js file to fix this. just compare your available picture names with the names in the js file that is being called
          • cowboysdudeC
            cowboysdude Module Developer @trividar
            @trividar Still down…
              brianlove
              Any updates or is there a way to pull from another source? Mine isn’t working…
              • A
                Anthony Project Sponsor
                @Mykle1 Hello there. I know that this is a very old topic but I want ask you something about a part of code you have inside this modules js and you have comment that we can copy paste this part of code into any module we want to control with voice. I mean this part of code:
                  notificationReceived: function(notification, payload) {
                        if (notification === 'HIDE_MOON') {
                            this.hide(1000);
                            //    this.updateDom(300);
                        } else if (notification === 'SHOW_MOON') {
                            this.show(1000);
                My question is that I must paste the code into the any module’s .js folder or somewhere else? If I paste it into the module’s .js folder won’t it be deleted after next update? Thank you in advance.
                  sdetweil @Anthony
                  @Anthony he is not available currently. yes there is that risk. but you could fork the module repo, add that code to the module .js file , and submit a pull request back to the module author to get that code included.
                  A 1 Reply Last reply
                  • A
                    Anthony Project Sponsor @sdetweil
                    @sdetweil Thank you for your rapid reply. This a very good tool for me where I am not familiar with coding. I will do it. Thank you again.
                      DezHak
                      Super cool, def gonna check this out asap! Thanks for sharing.
                        BD0G
                        I need to update this module. Is there a preferred way to do so?
                          sdetweil @BD0G
                          @BD0G said in MMM-Lunartic:
                          update this module.
                          updating ANY/EVERY module is the same
                          cd ~/MagicMirror/modules/module_name
                          git pull
                          if there is a package.json after git pull, do
                          npm install
                          B 1 Reply Last reply
                            BD0G @sdetweil
                            @sdetweil OK. Perfect. Been out of the game for a while so I might have known that but forgotten.
                            I ran into a commit changes or stash message.
                            pi@MagicMirror:~/MagicMirror/modules/MMM-Lunartic $ git pull
                            Updating c977e14…00655ab
                            error: Your local changes to the following files would be overwritten by merge:
                            MMM-Lunartic.js
                            Please commit your changes or stash them before you merge.
                            error: The following untracked working tree files would be overwritten by merge:
                            package.json
                            Please move or remove them before you merge.
                            Aborting
                            Just sudo git pull ? Then since it mentions the package.json do an npm install?
                              sdetweil @BD0G
                              @BD0G someone has edited the source file…
                              NEVER do this, as your changes WILL be lost
                              ALL configuration is done in config.js
                              git diff
                              to detemine WHAT changes were made…
                              then to restore the file (and lose the changes)
                              git checkout MMM-Lunartic.js
                              same with package.json
                                BD0G @sdetweil
                                @sdetweil pi@MagicMirror:~/MagicMirror/modules/MMM-Lunartic $ git diff
                                diff --git a/MMM-Lunartic.js b/MMM-Lunartic.js
                                index 1520d0a…df2718c 100644
                                — a/MMM-Lunartic.js
                                +++ b/MMM-Lunartic.js
                                @@ -38,9 +38,7 @@ Module.register(“MMM-Lunartic”, {
                                es: “translations/es.json”,
                                de: “translations/de.json”,
                                sv: “translations/sv.json”,
                                •        nl: "translations/nl.json",
                                •        gl: "translations/gl.json",
                                •        ca: "translations/ca.json",
                                @@ -50,16 +48,16 @@ Module.register(“MMM-Lunartic”, {
                                requiresVersion: “2.1.0”,
                                         //  Set locale.
                                •    this.url = "https://mykle.herokuapp.com/moon";
                                • // this.url = this.getUrl();
                                  sdetweil @BD0G
                                  @BD0G no idea how it could get that way
                                  the author is away right now…
                                  so, try this
                                  git stash
                                  to save the two files
                                  then back to the original instructions
                                    BD0G @sdetweil
                                    @sdetweil Got it.
                                    I did git stash and it indicated I needed to set my global identity. Did that. Then git stash succeeded. Then did a git pull and it indicated I needed to remove or move package.json. I moved it . Then did git pull which worked.
                                    Then git checkout MMM-Lunartic.js
                                    and git checkout package.json
                                    Stopped and restarted PM2 and it displays properly and the notification bar above no longer includes that as a module that needs to be upgraded
                                      sdetweil @BD0G
                                      only needed to do those BEFORE the git pull
                                      we did git stash (to save them off to the side (in the stash) ), which also restored the original files
                                        BD0G @sdetweil
                                        @sdetweil :oncoming_fist_light_skin_tone:
                                        • Z
                                          ZeroCool
                                          Very enjoyable module, thank you.
                                          • E
                                            Egnos
                                            Hello people!
                                            Since yesterday the module has stopped working, I no longer see the image of the moon and the various descriptions.
                                            only the header remained and below the writing: “When the Moon hits your eye . . .”.
                                            I know @Mykle1 is currently unavailable, can anyone help me fix this?
                                            Thanks.
                                            StoffbeuteluweS T 2 Replies Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 13 / 14
