    electron-rebuild and MagicMirror v2.18 (and more)
    40 Posts 16 Posters 29.8k Views 21 Watching
    • bugsounetB
      bugsounet Banned
      Hi, because (sometime) i’m kind
      I will offer you a tips for next release of MagicMirror (it’s comes 01/01/2022)
      Some modules need library linked to MagicMirror and do electron-rebuild step.
      • Last electron-rebuild package is actually not really ready for MagicMirror using (install many package not used)
      • Last package is not really ready for raspberry pi, and rebuild build will failed
        • problems with SSL
        • Problems with sub-dependencies (lzma-native can failed on build)
      So ?
      • I just write the new rebuild library dedicated to MagicMirror
      • I will maintened it (For my modules and yours if you want)
      • It will use exactly what MagicMirror needs (and ONLY that)
      • it will replace the electron-rebuild package
      What’s this new library ?
      • This library is magicmirror-rebuild
      • You can use it directly in your package.json file
        "dependencies": {
          "magicmirror-rebuild": "^1.0.0",
      • You can install it directly with this command in a module directory:
      npm i magicmirror-rebuild
      • you can ask the rebuild step of MagicMirror (electron) with this command (in a module root directory)
      ./node_modules/.bin/MagicMirror-rebuild
      Sample with MagicMirror v2.18 and MMM-PIR-Sensor module
      bugsounet@debian:~/MagicMirror/modules/MMM-PIR-Sensor$ npm install
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      > epoll@4.0.1 install /home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
      > node-gyp rebuild
      make : on entre dans le répertoire « /home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build »
        CXX(target) Release/obj.target/epoll/src/epoll.o
        SOLINK_MODULE(target) Release/obj.target/epoll.node
        COPY Release/epoll.node
      make : on quitte le répertoire « /home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build »
      > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor
      > electron-rebuild -e ../../node_modules/electron
      ⠋ Searching dependency tree
      An unhandled error occurred inside electron-rebuild
      Could not detect abi for version 16.0.5 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
      Error: Could not detect abi for version 16.0.5 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
          at Object.getAbi (/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:36:9)
          at new Rebuilder (/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:126:48)
          at rebuildWithOptions (/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:404:23)
          at Object.doRebuild [as rebuild] (/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:427:16)
          at /home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:124:33
          at Generator.next (<anonymous>)
          at fulfilled (/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:6:58)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 255
      npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron`
      npm ERR! Exit status 255
      npm ERR!
      npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script.
      npm ERR!     /home/bugsounet/.npm/_logs/2021-12-23T12_20_03_436Z-debug.log
      So the result is failed !
      1. Let’s install magicmirror-rebuild library
      bugsounet@debian:~/MagicMirror/modules/MMM-PIR-Sensor$ npm i magicmirror-rebuild
      npm notice created a lockfile as package-lock.json. You should commit this file.
      + magicmirror-rebuild@1.0.3
      1. Now try to execute MagicMirror-rebuild script for rebuild
      bugsounet@debian:~/MagicMirror/modules/MMM-PIR-Sensor$ ./node_modules/.bin/MagicMirror-rebuild
      ⠼ MagicMirror Building module: epoll, Completed: 0gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
      ⠴ MagicMirror Building module: epoll, Completed: 0gyp http GET https://www.electronjs.org/headers/v16.0.5/node-v16.0.5-headers.tar.gz
      ⠼ MagicMirror Building module: epoll, Completed: 0gyp http 200 https://www.electronjs.org/headers/v16.0.5/node-v16.0.5-headers.tar.gz
      ⠏ MagicMirror Building module: epoll, Completed: 0gyp http GET https://www.electronjs.org/headers/v16.0.5/SHASUMS256.txt
      ⠧ MagicMirror Building module: epoll, Completed: 0gyp http 200 https://www.electronjs.org/headers/v16.0.5/SHASUMS256.txt
      gyp info spawn /usr/bin/python3
      gyp info spawn args [
      gyp info spawn args   '/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/node_modules/node-gyp/gyp/gyp_main.py',
      gyp info spawn args   'binding.gyp',
      gyp info spawn args   '-f',
      gyp info spawn args   'make',
      gyp info spawn args   '-I',
      gyp info spawn args   '/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/config.gypi',
      gyp info spawn args   '/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/node_modules/node-gyp/addon.gypi',
      gyp info spawn args   '/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/16.0.5/include/node/common.gypi',
      gyp info spawn args   '-Dlibrary=shared_library',
      gyp info spawn args   '-Dvisibility=default',
      gyp info spawn args   '-Dnode_root_dir=/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/16.0.5',
      gyp info spawn args   '-Dnode_gyp_dir=/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/node_modules/node-gyp',
      gyp info spawn args   '-Dnode_lib_file=/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/16.0.5/<(target_arch)/node.lib',
      gyp info spawn args   '-Dmodule_root_dir=/home/bugsounet/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll',
      gyp info spawn args   '-Dnode_engine=v8',
      gyp info spawn args   '--depth=.',
      gyp info spawn args   '--no-parallel',
      gyp info spawn args   '--generator-output',
      gyp info spawn args   'build',
      gyp info spawn args   '-Goutput_dir=.'
      gyp info spawn args ]
      ⠋ MagicMirror Building module: epoll, Completed: 0gyp info spawn make
      gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      ⠸ MagicMirror Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
      ⠼ MagicMirror Building module: epoll, Completed: 0  COPY Release/epoll.node
      ✔ MagicMirror Rebuild Complete
      That you see MagicMirror Rebuild Complete !
      Your module is now installed correctly
      wishmaster270W C G LusbuebL 4 Replies Last reply Reply Quote 5
      • hedmikH
        hedmik
        Wow, thanks for sharing this!!!
        Now, I’m back on track again :-)
        bugsounetB 1 Reply Last reply Reply Quote 0
        • wishmaster270W
          wishmaster270 Module Developer @bugsounet
          @bugsounet Thanks for this lib. Integrated it into two of my modules yesterday because I couldn’t get them compiled with electron-rebuild.
          • bugsounetB
            bugsounet Banned @wishmaster270
            @wishmaster270 :
            If it can help, it’s perfect ;)
            I have do the same too for rebuild modules
            but don’t forget to delete "electron-rebuild": "v.xxx", from for package.json file ;)
            because this old package is not needed now
            @bugsounet
            • bugsounetB
              bugsounet Banned @hedmik
              @hedmik : i just share (one of) my own library ;)
                cyber152 @bugsounet
                @bugsounet thank you very much, for weeks I am looking for a solution to finally be able to add an essential function to the mirror :thumbs_up:
                • G
                  gonzonia @bugsounet
                  @bugsounet THANK YOU! This saved me a lot of headaches. I went ahead and updated to 2.18 and got the exact error you reference in the exact same module. A quick search and I found your very helpful solution. Thank you for sharing.
                  • L
                    lhops
                    I get an error when " ~/node_modules $ ~/.bin/MagicMirror-rebuild"
                    error=(an unhandled error occurred inside electron-rebuild)
                    unable to find electron’s version number of MagicMirror etc
                    L bugsounetB 2 Replies Last reply Reply Quote 0
                    • L
                      lhops @lhops
                      @lhops
                      Can or has anyone written code for an new MMM-PIR-Sensor module that will work will the new version of MagicMirror. If not is that something that your can do? I wish I knew more about the code I would do it myself.
                      • bugsounetB
                        bugsounet Banned @lhops
                        @lhops said in electron-rebuild and MagicMirror v2.18 (and more):
                        execute ./node_modules/.bin/MagicMirror-rebuild INSIDE the module directory ;)
                        not inside other directory ;)
                        Note :
                        1. every module in MagicMirror is there:
                        cd ~/MagicMirror/modules
                        1. After change again the directory to your wanted module,
                          for MMM-PIR-Sensor module (for example):
                        cd MMM-PIR-Sensor
                        1. after install magicmirror-rebuild
                        1. execute MagicMirror-rebuild program
                        1. you will see MagicMirror Rebuild Complete
                        2. it’s done ;)
                        • L
                          lhops @bugsounet
                          @bugsounet
                          This is the results of the instructions:
                          pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm i magicmirror-rebuild
                          npm ERR! code EJSONPARSE
                          npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor/package.json
                          npm ERR! JSON.parse Unexpected string in JSON at position 803 while parsing ‘{
                          npm ERR! JSON.parse “name”: "Magic-Mirror-Module-PIR-Sen’
                          npm ERR! JSON.parse Failed to parse JSON data.
                          npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
                          npm ERR! /home/pi/.npm/_logs/2022-01-10T14_40_47_069Z-debug-0.log
                          I am sure you can look at this and see my problem.
                          Thank you for all your help!
                          • bugsounetB
                            If you have modified the “package.json” file … and you do not respect the syntax.
                            here is the result ;)
                            (Info: it is not like this that we rename a module)
                            to correct your issue try this:
                            cd ~/MagicMirror/modules/MMM-PIR-Sensor
                            rm -rf node_modules package-lock.json
                            git reset --hard HEAD
                            npm install magicmirror-rebuild --save
                            npm remove electron-rebuild
                            npm install
                            (Sometime, i’m very kind… So kind for me)
                            @bugsounet
                            • L
                              lhops @bugsounet
                              @bugsounet
                              That did the trick. How can I thank you. It is working like it should!!
                              • bugsounetB
                                I have open this PR (Pull Request) for commit this change with MagicMirror-rebuild to @paviro to accept it (or not)
                                  susl @bugsounet
                                  @bugsounet I followed your instructions but the rebuilding step failed with the following message:
                                  MagicMirror Building module: epoll, Completed: 0gyp: name ‘openssl_fips’ is not defined while evaluating condition ‘openssl_fips != “”’ in binding.gyp while trying to load binding.gyp
                                  ✖ MagicMirror Rebuild Failed
                                  node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
                                  Error: gyp failed with exit code: 1
                                  Error: node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
                                  at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/module-rebuilder.js:193:19)
                                  at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                  at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:180:9)
                                  at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:143:17)
                                  at async /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:141:9
                                  Do you know what the problem is? Thanks!
                                  • bugsounetB
                                    bugsounet Banned @susl
                                    @susl :
                                    • Recommended version of npm: v6.14.15
                                    • Recommended version of node: v14.x.x or v16.x.x
                                    to verify, try this in a terminal (or ssh):
                                    node -v
                                    npm -v
                                      susl @bugsounet
                                      @bugsounet
                                      node version: v17.3.0
                                      npm version: 8.3.0
                                      So obviously not the correct version :-( Do you know how I can change the versions?
                                        sdetweil @susl
                                        @susl you can use n to install or select different versions of node (and npm)
                                        to install n
                                        sudo npm install n -g
                                        then to install or use a version of node
                                        n 16
                                        to switch
                                        n
                                        the select from the list
                                          susl @sdetweil
                                          Thanks a lot. I works now!
                                          • cowboysdudeC
                                            @bugsounet Thank you for this!! It works like a charm ;)
