    electron-rebuild and MagicMirror v2.18 (and more)
    40 Posts 16 Posters 30.7k Views 21 Watching
    • bugsounetB
      bugsounet Banned @lhops
      @lhops said in electron-rebuild and MagicMirror v2.18 (and more):
      I get an error when " ~/node_modules $ ~/.bin/MagicMirror-rebuild"
      execute ./node_modules/.bin/MagicMirror-rebuild INSIDE the module directory ;)
      not inside other directory ;)
      Note :
      1. every module in MagicMirror is there:
      cd ~/MagicMirror/modules
      1. After change again the directory to your wanted module,
        for MMM-PIR-Sensor module (for example):
      cd MMM-PIR-Sensor
      1. after install magicmirror-rebuild
      npm i magicmirror-rebuild
      1. execute MagicMirror-rebuild program
      1. you will see MagicMirror Rebuild Complete
      2. it’s done ;)
      L 1 Reply Last reply
      • L
        lhops @bugsounet
        @bugsounet
        This is the results of the instructions:
        pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ npm i magicmirror-rebuild
        npm ERR! code EJSONPARSE
        npm ERR! path /home/pi/MagicMirror/modules/MMM-PIR-Sensor/package.json
        npm ERR! JSON.parse Unexpected string in JSON at position 803 while parsing ‘{
        npm ERR! JSON.parse “name”: "Magic-Mirror-Module-PIR-Sen’
        npm ERR! JSON.parse Failed to parse JSON data.
        npm ERR! JSON.parse Note: package.json must be actual JSON, not just JavaScript.
        npm ERR! /home/pi/.npm/_logs/2022-01-10T14_40_47_069Z-debug-0.log
        I am sure you can look at this and see my problem.
        Thank you for all your help!
        bugsounetB 1 Reply Last reply
        • bugsounetB
          If you have modified the “package.json” file … and you do not respect the syntax.
          here is the result ;)
          (Info: it is not like this that we rename a module)
          to correct your issue try this:
          cd ~/MagicMirror/modules/MMM-PIR-Sensor
          rm -rf node_modules package-lock.json
          git reset --hard HEAD
          npm install magicmirror-rebuild --save
          npm remove electron-rebuild
          npm install
          (Sometime, i’m very kind… So kind for me)
          @bugsounet
          • L
            lhops @bugsounet
            @bugsounet
            That did the trick. How can I thank you. It is working like it should!!
            • bugsounetB
              I have open this PR (Pull Request) for commit this change with MagicMirror-rebuild to @paviro to accept it (or not)
                susl @bugsounet
                @bugsounet I followed your instructions but the rebuilding step failed with the following message:
                MagicMirror Building module: epoll, Completed: 0gyp: name ‘openssl_fips’ is not defined while evaluating condition ‘openssl_fips != “”’ in binding.gyp while trying to load binding.gyp
                ✖ MagicMirror Rebuild Failed
                An unhandled error occurred inside electron-rebuild
                node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
                Error: gyp failed with exit code: 1
                Error: node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
                at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/module-rebuilder.js:193:19)
                at processTicksAndRejections (node:internal/process/task_queues:96:5)
                at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:180:9)
                at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:143:17)
                at async /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:141:9
                Do you know what the problem is? Thanks!
                • bugsounetB
                  bugsounet Banned @susl
                  @susl :
                  • Recommended version of npm: v6.14.15
                  • Recommended version of node: v14.x.x or v16.x.x
                  to verify, try this in a terminal (or ssh):
                  node -v
                  npm -v
                    susl @bugsounet
                    @bugsounet
                    node version: v17.3.0
                    npm version: 8.3.0
                    So obviously not the correct version :-( Do you know how I can change the versions?
                      sdetweil @susl
                      @susl you can use n to install or select different versions of node (and npm)
                      to install n
                      sudo npm install n -g
                      then to install or use a version of node
                      n 16
                      to switch
                      n
                      the select from the list
                        susl @sdetweil
                        Thanks a lot. I works now!
                        • cowboysdudeC
                          @bugsounet Thank you for this!! It works like a charm ;)
                            selyjohns
                            Wow, perfect ! Thank you so much !
                            • michael5rM
                              michael5r Module Developer
                              Thanks for doing this - much appreciated!
                              • bugsounetB
                                bugsounet Banned @michael5r
                                @michael5r with pleasure ;l
                                  selyjohns
                                  Hi @bugsounet
                                  Same problem after update to 2.19 :(
                                  During the update, i needed to force because a log say the package-lock.json has been modified. Maybe my error.
                                  Trying to reproduce the procedure, but
                                  pi@MagicMirror:~/MagicMirror/modules/MMM-PIR-Sensor $ ./node_modules/.bin/MagicMirror-rebuild
                                  ⠋ Searching dependency tree
                                  Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                                  Error: Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                                      at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:39:9)
                                      at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:100:48)
                                      at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:249:23)
                                      at doRebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:272:16)
                                      at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:115:45
                                  Did you know how to solve this ?
                                  bugsounetB T 2 Replies Last reply
                                  • bugsounetB
                                    bugsounet Banned @selyjohns
                                    @selyjohns
                                    MMM-PIR-Sensor state is :
                                    This repository has been archived by the owner. It is now read-only.
                                    I will not doing a patch on every update for this @paviro module
                                    Just use another maintened pir module
                                      selyjohns
                                      @bugsounet said in electron-rebuild and MagicMirror v2.18 (and more):
                                      Thank you for this quick reply.
                                      I see, so no solution for this update…Any idea of equivalent module to replace MMM-PIR-Sensor ?
                                      • bugsounetB
                                        @selyjohns I done NO ads in this forum, sorry
                                        • S selyjohns referenced this topic on
                                        • T
                                          tanvir586 @selyjohns
                                          @selyjohns
                                          hi can you try
                                          Cd MagicMirror/modules/MMM-PIR-Sensor
                                          And then
                                          Then
                                          It might work.
                                            sdetweil @tanvir586
                                            @tanvir586 see
                                            https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/25?_=1648232499740
