    electron-rebuild and MagicMirror v2.18 (and more)
    40 Posts 16 Posters 29.6k Views 21 Watching
      susl @bugsounet
      @bugsounet
      node version: v17.3.0
      npm version: 8.3.0
      So obviously not the correct version :-( Do you know how I can change the versions?
        sdetweil @susl
        @susl you can use n to install or select different versions of node (and npm)
        to install n
        sudo npm install n -g
        then to install or use a version of node
        n 16
        to switch
        n
        the select from the list
          susl @sdetweil
          Thanks a lot. I works now!
          • cowboysdudeC Offline
            @bugsounet Thank you for this!! It works like a charm ;)
              selyjohns
              Wow, perfect ! Thank you so much !
              • michael5rM Offline
                michael5r Module Developer
                Thanks for doing this - much appreciated!
                bugsounetB 1 Reply Last reply Reply Quote 0
                • bugsounetB Offline
                  bugsounet Banned @michael5r
                  @michael5r with pleasure ;l
                    selyjohns
                    Hi @bugsounet
                    Same problem after update to 2.19 :(
                    During the update, i needed to force because a log say the package-lock.json has been modified. Maybe my error.
                    Trying to reproduce the procedure, but
                    pi@MagicMirror:~/MagicMirror/modules/MMM-PIR-Sensor $ ./node_modules/.bin/MagicMirror-rebuild
                    ⠋ Searching dependency tree
                    An unhandled error occurred inside electron-rebuild
                    Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                    Error: Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                        at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:39:9)
                        at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:100:48)
                        at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:249:23)
                        at doRebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:272:16)
                        at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:115:45
                    Did you know how to solve this ?
                    bugsounetB T 2 Replies Last reply Reply Quote 0
                      bugsounet Banned @selyjohns
                      @selyjohns
                      MMM-PIR-Sensor state is :
                      This repository has been archived by the owner. It is now read-only.
                      I will not doing a patch on every update for this @paviro module
                      Just use another maintened pir module
                        selyjohns
                        @bugsounet said in electron-rebuild and MagicMirror v2.18 (and more):
                        Thank you for this quick reply.
                        I see, so no solution for this update…Any idea of equivalent module to replace MMM-PIR-Sensor ?
                          @selyjohns I done NO ads in this forum, sorry
                          • S selyjohns referenced this topic on
                          • T Offline
                            tanvir586 @selyjohns
                            @selyjohns
                            hi can you try
                            Cd MagicMirror/modules/MMM-PIR-Sensor
                            And then
                            npm i magicmirror-rebuild
                            Then
                            It might work.
                              sdetweil @tanvir586
                              @tanvir586 see
                              https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/25?_=1648232499740
                                selyjohns @sdetweil
                                @sdetweil @tanvir586
                                Yes…Already tested. No fonctionnal
                                  sdetweil @selyjohns
                                  @selyjohns correct.
                                  the author of the magicmirror rebuild tool said he will not fix it for this module.
                                  as the module is in archived status
                                  wishmaster270W 1 Reply Last reply Reply Quote 1
                                  • wishmaster270W Offline
                                    wishmaster270 Module Developer @sdetweil
                                    I generally suggest the same as bugsoutnet…The best way would be to use one of the other PIR modules.
                                    But i also found an solution which worked in my setup. I used the sdetweil script to install the current version of MagicMirror.
                                    In the module directory of MMM-PIR-Sensor you need to delete package-lock.json and the node_modules folder:
                                    rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/node_modules
                                    rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/package-lock.json
                                    Then you need to replace the whole content of package.json file with the following one that uses the MagicMirror-rebuild library of bugsounet…
                                      "name": "Magic-Mirror-Module-PIR-Sensor",
                                      "version": "1.1.0",
                                      "description": "PIR motion sensor module for the Magic Mirror.",
                                      "repository": {
                                        "type": "git",
                                        "url": "git+https://github.com/paviro/MMM-PIR-Sensor"
                                      "keywords": [
                                        "magic mirror",
                                        "smart mirror",
                                        "PIR-Sensor",
                                        "module",
                                        "motion"
                                      "author": "Paul-Vincent Roll",
                                      "contributors": "https://github.com/paviro/MMM-PIR-Sensor/graphs/contributors",
                                      "license": "MIT",
                                      "bugs": {
                                        "url": "https://github.com/paviro/MMM-PIR-Sensor/issues"
                                      "homepage": "https://github.com/paviro/MMM-PIR-Sensor#readme",
                                      "scripts": {
                                    	  "postinstall": "node_modules/.bin/MagicMirror-rebuild"
                                      "dependencies": {
                                        "onoff": "latest",
                                        "magicmirror-rebuild": "latest"
                                    Then you need to run npm install
                                    npm install
                                      sdetweil @wishmaster270
                                      @wishmaster270 did u try the upgrade script?
                                      it does delete both file and folder and then npm install
                                        @sdetweil Hi, i did a fresh install and added the module manually. I do not use MMM-PIR-Sensor but some other users had the same problem with MMM-Gestures (which i do not use either). Did a clean install of MagicMirror on a development Pi with your script and added modules manually.
                                        • karsten13K karsten13 referenced this topic on
                                        • O OliWer referenced this topic on
                                          Rags
                                          Awesome. It really works. I had the same issue and it was really frustrating, until i stumbled upon this solution. Great my PIR-sensor module was revived. I just followed the steps mentioned and voila…it has come back to life. Thanks a ton, it is selfless gentlemen like yourself who keep this world going. Kudos.
                                          • T torte22 referenced this topic on
                                            Dresch360 Project Sponsor
                                            Hoping someone can help. Having the same issue with MMM-Reddit since updating to MM v2.20.0 . Spent a couple days scouring this as well as other forums for a fix. I already tried everything from this thread. Still getting the error below, no matter what I try. Any help would be greatly appreciated.
                                            • MM v2.20.0
                                            • Node v16.17.1
                                              -Node-gyp v9.2.0
                                              -NPM v8.15.0
                                            This is the code I get for any rebuild or npm install…etc:
                                            npm ERR! code 1
                                            npm ERR! path /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass
                                            npm ERR! command failed
                                            npm ERR! command sh /tmp/postinstall-fdc6f405.sh
                                            npm ERR! Building: /usr/bin/node /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
                                            npm ERR! gyp info it worked if it ends with ok
                                            npm ERR! gyp verb cli [
                                            npm ERR! gyp verb cli ‘/usr/bin/node’,
                                            npm ERR! gyp verb cli ‘/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js’,
                                            npm ERR! gyp verb cli ‘rebuild’,
                                            npm ERR! gyp verb cli ‘–verbose’,
                                            npm ERR! gyp verb cli ‘–libsass_ext=’,
                                            npm ERR! gyp verb cli ‘–libsass_cflags=’,
                                            npm ERR! gyp verb cli ‘–libsass_ldflags=’,
                                            npm ERR! gyp verb cli ‘–libsass_library=’
                                            npm ERR! gyp verb cli ]
                                            npm ERR! gyp info using node-gyp@3.8.0
                                            npm ERR! gyp info using node@16.17.1 | linux | arm
                                            npm ERR! gyp verb command rebuild []
                                            npm ERR! gyp verb command clean []
                                            npm ERR! gyp verb clean removing “build” directory
                                            npm ERR! gyp verb command configure []
                                            npm ERR! gyp verb check python checking for Python executable “python2” in the PATH
                                            npm ERR! gyp verb which failed Error: not found: python2
                                            npm ERR! gyp verb which failed at getNotFoundError (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:13:12)
                                            npm ERR! gyp verb which failed at F (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:68:19)
                                            npm ERR! gyp verb which failed at E (/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:80:29)
                                            npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/which/which.js:89:16
                                            npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/isexe/index.js:42:5
                                            npm ERR! gyp verb which failed at /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/isexe/mode.js:8:5
                                            npm ERR! gyp verb which failed at FSReqCallback.oncomplete (node:fs:206:21)
                                            npm ERR! gyp verb which failed python2 Error: not found: python2
                                            npm ERR! gyp verb which failed at FSReqCallback.oncomplete (node:fs:206:21) {
                                            npm ERR! gyp verb which failed code: ‘ENOENT’
                                            npm ERR! gyp verb which failed }
                                            npm ERR! gyp verb check python checking for Python executable “python” in the PATH
                                            npm ERR! gyp verb which succeeded python /usr/bin/python
                                            npm ERR! gyp ERR! configure error
                                            npm ERR! gyp ERR! stack Error: Command failed: /usr/bin/python -c import sys; print “%s.%s.%s” % sys.version_info[:3];
                                            npm ERR! gyp ERR! stack File “”, line 1
                                            npm ERR! gyp ERR! stack import sys; print “%s.%s.%s” % sys.version_info[:3];
                                            npm ERR! gyp ERR! stack ^
                                            npm ERR! gyp ERR! stack SyntaxError: invalid syntax
                                            npm ERR! gyp ERR! stack at ChildProcess.exithandler (node:child_process:400:12)
                                            npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
                                            npm ERR! gyp ERR! stack at maybeClose (node:internal/child_process:1093:16)
                                            npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
                                            npm ERR! gyp ERR! System Linux 5.15.61-v7l+
                                            npm ERR! gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass/node_modules/node-gyp/bin/node-gyp.js” “rebuild” “–verbose” “–libsass_ext=” “–libsass_cflags=” “–libsass_ldflags=” “–libsass_library=”
                                            npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Reddit/node_modules/node-sass
                                            npm ERR! gyp ERR! node -v v16.17.1
                                            npm ERR! gyp ERR! node-gyp -v v3.8.0
                                            npm ERR! gyp ERR! not ok
                                            npm ERR! Build failed with error code: 1
                                            npm ERR! /home/pi/.npm/_logs/2022-10-07T02_52_13_196Z-debug-0.log
