    electron-rebuild and MagicMirror v2.18 (and more)
    40 Posts 16 Posters 29.8k Views 21 Watching
    • L
      lhops @bugsounet
      @bugsounet
      That did the trick. How can I thank you. It is working like it should!!
      bugsounetB 1 Reply Last reply Reply Quote 0
      • bugsounetB
        bugsounet Banned @lhops
        I have open this PR (Pull Request) for commit this change with MagicMirror-rebuild to @paviro to accept it (or not)
          susl @bugsounet
          @bugsounet I followed your instructions but the rebuilding step failed with the following message:
          MagicMirror Building module: epoll, Completed: 0gyp: name ‘openssl_fips’ is not defined while evaluating condition ‘openssl_fips != “”’ in binding.gyp while trying to load binding.gyp
          ✖ MagicMirror Rebuild Failed
          An unhandled error occurred inside electron-rebuild
          node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
          Error: gyp failed with exit code: 1
          Error: node-gyp failed to rebuild ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll’.
          at ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/module-rebuilder.js:193:19)
          at processTicksAndRejections (node:internal/process/task_queues:96:5)
          at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:180:9)
          at async Rebuilder.rebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:143:17)
          at async /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:141:9
          Do you know what the problem is? Thanks!
          • bugsounetB
            bugsounet Banned @susl
            @susl :
            • Recommended version of npm: v6.14.15
            • Recommended version of node: v14.x.x or v16.x.x
            to verify, try this in a terminal (or ssh):
            node -v
            npm -v
              susl @bugsounet
              @bugsounet
              node version: v17.3.0
              npm version: 8.3.0
              So obviously not the correct version :-( Do you know how I can change the versions?
                sdetweil @susl
                @susl you can use n to install or select different versions of node (and npm)
                to install n
                sudo npm install n -g
                then to install or use a version of node
                n 16
                to switch
                n
                the select from the list
                  susl @sdetweil
                  Thanks a lot. I works now!
                  • cowboysdudeC
                    @bugsounet Thank you for this!! It works like a charm ;)
                      selyjohns
                      Wow, perfect ! Thank you so much !
                      • michael5rM
                        michael5r Module Developer
                        Thanks for doing this - much appreciated!
                        • bugsounetB
                          bugsounet Banned @michael5r
                          @michael5r with pleasure ;l
                            selyjohns
                            Hi @bugsounet
                            Same problem after update to 2.19 :(
                            During the update, i needed to force because a log say the package-lock.json has been modified. Maybe my error.
                            Trying to reproduce the procedure, but
                            pi@MagicMirror:~/MagicMirror/modules/MMM-PIR-Sensor $ ./node_modules/.bin/MagicMirror-rebuild
                            ⠋ Searching dependency tree
                            Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                            Error: Could not detect abi for version 17.2.0 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
                                at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:39:9)
                                at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:100:48)
                                at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:249:23)
                                at doRebuild (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/rebuild.js:272:16)
                                at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/magicmirror-rebuild/build/cli.js:115:45
                            Did you know how to solve this ?
                            bugsounetB T 2 Replies Last reply Reply Quote 0
                            • bugsounetB
                              bugsounet Banned @selyjohns
                              @selyjohns
                              MMM-PIR-Sensor state is :
                              This repository has been archived by the owner. It is now read-only.
                              I will not doing a patch on every update for this @paviro module
                              Just use another maintened pir module
                                selyjohns
                                @bugsounet said in electron-rebuild and MagicMirror v2.18 (and more):
                                Thank you for this quick reply.
                                I see, so no solution for this update…Any idea of equivalent module to replace MMM-PIR-Sensor ?
                                • bugsounetB
                                  @selyjohns I done NO ads in this forum, sorry
                                  • S selyjohns referenced this topic on
                                  • T
                                    tanvir586 @selyjohns
                                    @selyjohns
                                    hi can you try
                                    Cd MagicMirror/modules/MMM-PIR-Sensor
                                    And then
                                    npm i magicmirror-rebuild
                                    Then
                                    It might work.
                                      sdetweil @tanvir586
                                      @tanvir586 see
                                      https://forum.magicmirror.builders/topic/16074/electron-rebuild-and-magicmirror-v2-18-and-more/25?_=1648232499740
                                        selyjohns @sdetweil
                                        @sdetweil @tanvir586
                                        Yes…Already tested. No fonctionnal
                                          sdetweil @selyjohns
                                          @selyjohns correct.
                                          the author of the magicmirror rebuild tool said he will not fix it for this module.
                                          as the module is in archived status
                                          wishmaster270W 1 Reply Last reply Reply Quote 1
                                          • wishmaster270W
                                            wishmaster270 Module Developer @sdetweil
                                            I generally suggest the same as bugsoutnet…The best way would be to use one of the other PIR modules.
                                            But i also found an solution which worked in my setup. I used the sdetweil script to install the current version of MagicMirror.
                                            In the module directory of MMM-PIR-Sensor you need to delete package-lock.json and the node_modules folder:
                                            rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/node_modules
                                            rm -rf ~/MagicMirror/modules/MMM-PIR-Sensor/package-lock.json
                                            Then you need to replace the whole content of package.json file with the following one that uses the MagicMirror-rebuild library of bugsounet…
                                              "name": "Magic-Mirror-Module-PIR-Sensor",
                                              "version": "1.1.0",
                                              "description": "PIR motion sensor module for the Magic Mirror.",
                                              "repository": {
                                                "type": "git",
                                                "url": "git+https://github.com/paviro/MMM-PIR-Sensor"
                                              "keywords": [
                                                "magic mirror",
                                                "smart mirror",
                                                "PIR-Sensor",
                                                "module",
                                                "motion"
                                              "author": "Paul-Vincent Roll",
                                              "contributors": "https://github.com/paviro/MMM-PIR-Sensor/graphs/contributors",
                                              "license": "MIT",
                                              "bugs": {
                                                "url": "https://github.com/paviro/MMM-PIR-Sensor/issues"
                                              "homepage": "https://github.com/paviro/MMM-PIR-Sensor#readme",
                                              "scripts": {
                                            	  "postinstall": "node_modules/.bin/MagicMirror-rebuild"
                                              "dependencies": {
                                                "onoff": "latest",
                                                "magicmirror-rebuild": "latest"
                                            Then you need to run npm install
                                            npm install
